Old 06-13-2016, 12:07 PM   #15
humfrz
Originally Posted by irax View Post
Just don't push in the clutch when you're not driving.....
how is that even a complaint ?
Hush up ! ........
What are you trying to do ....... put some of us out of business ...... ??
humfrz
Old 06-13-2016, 04:01 PM   #16
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
I had this problem too. It makes the noise when you're driving also. This noise is really really annoying.
Sigh-on-Rice is offline   Reply With Quote
Old 06-13-2016, 09:27 PM   #17
Ultramaroon
not playing cards
Ultramaroon's Avatar
It's also a really bad noise. Poor choice of materials and/or treatment on Subie's part.
Engineering fail. I am disappoint.
Old 06-13-2016, 09:33 PM   #18
oppiee
Drives: 2014 Scion FRS (Red)
The issue isnt so much I press the clutch while im not driving its just knowing that it does that. If it becomes a larger problem down the road, id rather deal with it now.
oppiee is offline   Reply With Quote
Old 06-13-2016, 09:52 PM   #19
Sigh-on-Rice
For OP's info, THIS is what my dealer did. Pretty much, they replaced many things inside of the bell housing and then ended up the noise wasn't from there. They lubed the clutch fork mentioned in this thread and that got rid of the noise. Been 9 months since then and still no sign of the noise.
So, it might worth trying it first. info here
Old 06-14-2016, 11:04 AM   #20
oppiee
So i took my car to the dealer, they did some lubrication and cleaning of the fork/clutch assembly, they disconnected the slave apparently. Its now not always making the squeak lol. Ill probably bring it back sometime soon ... I just hope its not the bearing
Old 06-15-2016, 03:22 PM   #21
Kinickie
R.I.P Firestorm
Kinickie's Avatar
Drives: 2013 WRB BRZ Limited
It may be more than just parts needing lube. I brought mine in for the same issue and the dealer tried lubricating everything first. That didn't fix the issue, so I took it back in.
Here's what they ended up doing to actually fix it:
"Fuck your gay car!" - Some Guy
Kinickie is offline   Reply With Quote
Old 06-15-2016, 04:00 PM   #22
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Ever since I removed the boot near the slave and lubed up inside there last year the squeak comes and goes once and a blue moon. Most of the time the clutch will be silent and smooth with only some noise and roughness in certain weather conditions.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 06-16-2016, 04:24 AM   #23
nimble
nimble's Avatar
Drives: 2013 WO FR-S
@Kinickie the description of your issue sounds just like mine. How much did they charge you?
nimble is offline   Reply With Quote
Old 06-16-2016, 07:32 AM   #24
Kinickie
R.I.P Firestorm
Kinickie's Avatar
Nothing, if was covered by the warranty.
Old 06-16-2016, 10:29 AM   #25
stevemp5
Drives: scion fr-s
Took my car Last year for this issue, dealer change all the components of the clutch and lubricate everything.. now the squeak came back!.... Super fun and my car is off warranty now.
stevemp5 is offline   Reply With Quote
Old 06-16-2016, 11:38 AM   #26
nimble
nimble's Avatar
@Kinickie which warranty if you don't mind me asking? @stevemp5 same thing happened to me.
Old 06-16-2016, 01:03 PM   #27
Kinickie
R.I.P Firestorm
Kinickie's Avatar
The car was less than 3 years old and had 28k on it, so it was my regular Subaru warranty.
Old 06-21-2016, 05:51 PM   #28
bhbnuckle
bhbnuckle's Avatar
Drives: 2013 Asphalt FR-S/2003 Honda Accord
which warranty did they cover under?
bhbnuckle is offline   Reply With Quote
Clicking noise from clutch when depressed/released? BaeK Issues | Warranty | Recalls / TSB 30 02-05-2025 06:20 PM
Squeaky clutch V1B Engine, Exhaust, Transmission 24 06-16-2016 04:48 AM
Idle dipping when the clutch is depressed tylerdone86 Issues | Warranty | Recalls / TSB 8 06-03-2016 10:13 PM
Upgraded Clutch now seems like TOB is pressing on pressure plate when not depressed. Rybot Issues | Warranty | Recalls / TSB 35 03-06-2016 09:23 PM
Vibration/Noise when clutch is depressed Ravenlokk Issues | Warranty | Recalls / TSB 17 12-02-2013 11:15 AM
