Old 06-09-2016, 02:58 PM   #15
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I've got the fumoto valve, and I do my own oil changes.
I found its one of those things that doesn't save that much time, but every time I use it I think, "why didn't I buy this earlier...".
The fact that I don't get oil on my hands/have to dig out the drain plug from a pool of oil is worth it for me lol.
Old 06-10-2016, 12:17 AM   #16
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
Originally Posted by MR2 MK1 to FRS Newbie View Post
Google FUMOTO OIL CHANGE VALVES. Simple, effective, safe and easier if you do your own oil changes. With out removing/replacing the oil pan plug, you virtually eliminate the crush washer issue. A good product.
Product looks awesome in theory but idk. I could see it being very useful if you had to do oil changes very frequently. In my opinion it looks like more margin for error and just another component to fault and cause me issues. Bet its alot less messy thought for sure! Some oil on my hands every 3 months and get me out the house is not much for me to complain about.
Originally Posted by JazzleSAURUS View Post
My only beef with Fumoto valves is you don't get it all out. Usually you can get one that doesn't stick out much past the pan, which is my secondary concern.
Crush washers are cheap (a dollar?), the Fumoto saves you a whopping 30 seconds each oil change for about a one time $15. I don't see there being a huge benefit, but I also don't see the drawbacks as being huge either.
crush washer was like 30 cents at subaru
tofurun is offline   Reply With Quote
Old 06-10-2016, 09:46 PM   #17
Whats that smell?
Whats that smell?'s Avatar
Drives: 2013 Asphalt FR-S
Best $30 i've spent on my car is the Fumoto valve. You don't have to worry about holding the nut on so you won't spill any oil and getting a wrench in there. Plus I literally use 1 finger to drain it and close it. That alone is worth a measly $30. It not really about cost as much as simplicity.
Whats that smell? is offline   Reply With Quote
Do it yourself oil change Wilso Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 27 06-20-2016 02:11 AM
Oil Change Interval Change (Subaru recommended) Flow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 34 09-10-2014 08:27 PM
Where'd the monkey butt red go? n2oinferno Scion FR-S / Toyota 86 GT86 General Forum 12 03-28-2013 05:20 PM
Change oil as often? danscar Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 02-17-2013 06:31 PM
Monkey Butt Red FR-S Evil86 Member's Car Journals 1 06-09-2012 09:49 PM
