#15 |
Drives: 15 BRZ LTD, 05 FXT
I run 215/65-16 Altimax Arctics on some Subaru RS 5 Spoke wheels in the winter. Plenty of clearance and look super meaty. Those wheels are 16x7 and +53 offset.
I hope that helps you!
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
| The Following User Says Thank You to JazzleSAURUS For This Useful Post: | yanfoo (03-29-2016) |
#16 | |
Drives: Shinigami 86
685mm total for yours so my 652mm are about 3cm less... will fit perfect! Thanks for your input!
Never drive faster than your guardian angel can fly.
#17 |
You got it! These cars have pretty big wheel wells.
#18 |
Omg dude. It'll fit. No one has used that exact size of tire but the math says it'll fit with plenty of space
#19 |
Drives: 2022 Red GR86
#20 |
Drives: 2011 EB F150
Put 205/60/r16 Kelly snowtrakkers on my GR86 today. Clear and no rubbing. This winter will be a hoot!
#21 |
The Dictater
Drives: '13 Red Scion FRS
A+ for necromancy.
OP hasn't posted at all in 5 years btw.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread" |
| The Following User Says Thank You to Spuds For This Useful Post: | x808drifter (11-18-2022) |
| A set of clown-shoes: 205/60R16 tires on 16 x 7 wheels.... | rogerdalien | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 07-31-2012 12:09 AM |
