Old 03-29-2016, 11:16 AM   #1
yanfoo
yanfoo's Avatar
Drives: Shinigami 86
205/60R16 will it fit?
I searched. This is NOT really something people do but hey,
I run 205/55R16 as winter rubber, and have someone willing to give me Nokian Hakkapelita for free, but size is 205/60R16. Now these are pretty expensive tires so if I can source some for free...well!
I only want real life experiences, not "yes it should fit" please...
I need to take off my current tires from these 16' rims and don't want to do it and find out it rubs everywhere afterwards...
Thanks all for your help,
edit: oh yeah, stock suspension.
Never drive faster than your guardian angel can fly.
yanfoo is offline   Reply With Quote
Old 03-29-2016, 11:29 AM   #2
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
The new tire will be about an inch taller than stock, so you'll have about a half inch less clearance than the factory 215/45R17.
I think that's fine. Your speedometer will be off by around 4.5%.
murdoc is offline   Reply With Quote
The Following User Says Thank You to murdoc For This Useful Post:
yanfoo (03-29-2016)
Old 03-29-2016, 11:30 AM   #3
irax
irax's Avatar
Drives: 2015 Subaru BRZ WRB
Yes it fits
irax is offline   Reply With Quote
Old 03-29-2016, 11:32 AM   #4
irax
irax's Avatar
Murdoc is right, your fine.
Old 03-29-2016, 11:32 AM   #5
yanfoo
yanfoo's Avatar
Originally Posted by irax View Post
Yes it fits
need to make sure... you tried?
Old 03-29-2016, 11:33 AM   #6
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Do you have a tape measure?
jawn is offline   Reply With Quote
The Following User Says Thank You to jawn For This Useful Post:
go_a_way1 (03-29-2016)
Old 03-29-2016, 11:33 AM   #7
yanfoo
yanfoo's Avatar
Stock tires are 215/45/17 or 24.6 inches in diameter
New tires are 205/55/16 or 24.9 inches in diameter
its going to be off by 1%
no no new tires are 205/60/16
Old 03-29-2016, 11:34 AM   #8
yanfoo
yanfoo's Avatar
I sure can do that but it won't tell me if there is any rubbing from suspension travel...
There is about an inch diff.
Old 03-29-2016, 11:39 AM   #9
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Dang, here I am trying to sell continental winter tires sized 215/55/16 on forester steelies for a hundred bucks, lol.
The Following User Says Thank You to Summerwolf For This Useful Post:
yanfoo (03-29-2016)
Old 03-29-2016, 11:42 AM   #10
yanfoo
yanfoo's Avatar
The winter shoes I have now are still pretty good, but these Nokian are just the BEST you can get. If they fit, I want them!
Old 03-29-2016, 11:51 AM   #11
jawn
jawn's Avatar
People run 265/35/18s, 2 inches lowered. There's a 7mm difference between those sizes.
For reference, these cars stock have less than 65mm of total bump travel in the front, and that's including the 60mm bump stop.
Even if I had fit these tires to my car, without knowing what offset wheels you're running, there's no way to be definitive. If you're running stock offset wheels, you'll be fine. It'll only be problematic if you're running like +60 offset. I ran +53 offset wheels with negative camber and lowered on stock struts all winter.
Cole (03-29-2016)
Old 03-29-2016, 11:58 AM   #12
irax
irax's Avatar
I'm running 245/45/18 which is an inch taller than the 205/60/16...
IT WILL FIT.
The Following User Says Thank You to irax For This Useful Post:
yanfoo (03-29-2016)
Old 03-29-2016, 12:00 PM   #13
yanfoo
yanfoo's Avatar
Makes sense. I'm running Subaru steelies so offset is probably same or close to stock.
The 265/35R18 you're mentioning is still not as tall as a 205/60R16 (642mm vs 652mm)
That 100mm bugs me a little, but I guess I'll just have to try...
Old 03-29-2016, 12:01 PM   #14
yanfoo
yanfoo's Avatar
IT WILL FIT.
Ok well this is proof then. 677mm for yours versus 652mm for mines.
thank you Sir!
A set of clown-shoes: 205/60R16 tires on 16 x 7 wheels.... rogerdalien Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 07-31-2012 12:09 AM
