Old 03-29-2016, 01:02 PM   #15
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I run 215/65-16 Altimax Arctics on some Subaru RS 5 Spoke wheels in the winter. Plenty of clearance and look super meaty. Those wheels are 16x7 and +53 offset.
I hope that helps you!
JazzleSAURUS is offline   Reply With Quote
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
yanfoo (03-29-2016)
Old 03-29-2016, 01:10 PM   #16
yanfoo
yanfoo's Avatar
Drives: Shinigami 86
Wow it sure does!
685mm total for yours so my 652mm are about 3cm less... will fit perfect!
Thanks for your input!
Never drive faster than your guardian angel can fly.
yanfoo is offline   Reply With Quote
Old 03-29-2016, 01:22 PM   #17
JazzleSAURUS
You got it! These cars have pretty big wheel wells.
Old 03-30-2016, 08:59 AM   #18
Ashikabi
Ashikabi's Avatar
Omg dude. It'll fit. No one has used that exact size of tire but the math says it'll fit with plenty of space
Old 10-18-2022, 07:13 PM   #19
MaxCrowe
Drives: 2022 Red GR86
Originally Posted by yanfoo View Post
Ok well this is proof then. 677mm for yours versus 652mm for mines.
thank you Sir!
hey, how well did it end up fitting? got any pics?
i'm going with this tire as soon as i get my wheels in.
MaxCrowe is offline   Reply With Quote
Old 11-16-2022, 10:41 PM   #20
MikeyBRZ
Drives: 2011 EB F150
Put 205/60/r16 Kelly snowtrakkers on my GR86 today. Clear and no rubbing. This winter will be a hoot!
MikeyBRZ is offline   Reply With Quote
Old 11-17-2022, 08:49 PM   #21
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
A+ for necromancy.
OP hasn't posted at all in 5 years btw.
Also: "Build Thread"
The Following User Says Thank You to Spuds For This Useful Post:
x808drifter (11-18-2022)
A set of clown-shoes: 205/60R16 tires on 16 x 7 wheels.... rogerdalien Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 07-31-2012 12:09 AM
