Old 04-11-2016, 01:15 PM   #15
mixtape
Posts in the nude
mixtape's Avatar
Drives: 2016 WRB BRZ
I've been running Diode Dynamics bulbs in my car for a few months with exactly zero issues. I never heard of anyone blowing the BIU by changing the dome light.
Dome: SMD12
Trunk: SMD12
License plate: 63 lumen HP3
2016 Subaru BRZ - World Rally Blue [Build Thread]
Instagram: @mixtography | My Automotive Photography
"Lesbian trees have no wood." - Scoobs McGee
mixtape is offline   Reply With Quote
Old 04-11-2016, 11:48 PM   #16
ed_423
ed_423's Avatar
Drives: 2016 BRZ Limited
didn't want to take the risk, so now everything is led except doors LOL
ed_423 is offline   Reply With Quote
Old 04-11-2016, 11:49 PM   #17
ed_423
ed_423's Avatar
Dome: SMD12
Trunk: SMD12
i did a search before i bought the leds for the purpose of bulb size, and that's when i found out about the BIU issue. if i didn't find that i probably would've just changed it without any worries, and chances are they'll work fine Lol.just that one small percentage of error....
Old 05-11-2016, 04:40 PM   #18
z2two
Drives: Frs
you can avoid blowing the BIU with the door light install by taking these precautions.
unplug the door light harness connector before putting on your new bulb
No not pry out the bulb with the connector in place with a metal tool
the BIU usually blows because the connection is shorted
z2two is offline   Reply With Quote
Door courtesy lights ? huy_tx DIY (Do-It-Yourself) Guides 29 12-11-2019 06:11 PM
JDM Clear Courtesy Door Lamp code Trap63 Cosmetic Modification (Interior/Exterior/Lighting) 0 06-20-2014 05:29 PM
Courtesy Door Light Help Zero90 Cosmetic Modification (Interior/Exterior/Lighting) 5 03-16-2014 08:53 AM
Changing out the door/courtesy lights - problem mikalem Cosmetic Modification (Interior/Exterior/Lighting) 19 02-10-2014 08:39 AM
