Old 02-28-2016, 10:01 AM   #15
kcam86
Drives: Asphalt FR-S MT
I just got my flex fuel kit and they were awesome with customer service. Absolutely a pleasure Freddy was very fast and prompt.
kcam86 is offline   Reply With Quote
The Following 2 Users Say Thank You to kcam86 For This Useful Post:
Freddy@PTUNING (02-29-2016), kanundrum (02-28-2016)
Old 02-29-2016, 09:51 AM   #16
Freddy@PTUNING
Freddy@PTUNING's Avatar
Drives: Honda S2000 & Acura RSX Type-S
Send a message via AIM to Freddy@PTUNING
Originally Posted by ZeroTo86 View Post
Wow such a great price and at the right time too for my Innovate kit! I just placed an order now and if you guys can possibly get it shipped out Monday so it may hopefully arrive Thursday for my dyno tune appointment that would be AMAZING!!
My order# is 980412319. (:
Let me follow up on that for you so I can make sure it ships out today for you. Thank you for your purchase
Freddy@PTUNING is offline   Reply With Quote
Old 04-05-2016, 06:10 PM   #17
kanundrum
Drives: 2013 Whiteout FR-S
My E85 Tune that toan did the other day!
The Following User Says Thank You to kanundrum For This Useful Post:
M1K3 (04-05-2016)
Old 04-06-2016, 01:06 PM   #18
sidesleeper
Drives: BRZ series blue
Originally Posted by ptuning View Post
After extensive R&D, we're finally ready to release our new PTUNING Bluetooth Flex Fuel System.
- Toan
After extensive R&D?! Isn't this another company's analyzer? I know I've seen this elsewhere for half the price you're selling it.
Also, just noticed those fuel lines are the cheap non steel reinforced lines.
Last edited by sidesleeper; 04-06-2016 at 01:17 PM. Reason: just noticed the fuel lines...
sidesleeper is offline   Reply With Quote
Old 04-06-2016, 01:31 PM   #19
Freddy@PTUNING
Yes, it is a Flex Converter analyzer. They are used in many flex fuel kits. I hope you don't think that's all this kit consists of. Please present a flex fuel kit for this vehicle that is half the price of ours.
Are you saying that nylon braided lines are cheaper/worse than stainless steel braided lines? Well that is incorrect. Nylon is better for ethanol and the stainless steel lines are very abrasive and are a lot cheaper
The Following User Says Thank You to Freddy@PTUNING For This Useful Post:
kanundrum (04-06-2016)
Old 04-06-2016, 05:29 PM   #20
sidesleeper
Sure, buy the analyzer direct from F.C. with a sensor $245 make your own bracket if you even need one, make your own fuel lines with Russell AN fittings and proclassic II hose. $300 tops.
No, I'm saying that the hose you are using, from Russell (I presume Russell performance proclassic hose) are the cheap fuel hoses that don't have the steel reinforcing in it (proclassic II). They both have chlorinated polyethylene liners with braided nylon sheathing, but yours do not have the steel reinforcing in the hose, as most other flexfuel kit offerings do. Why do you have to use the non steel reinforced... cost and profit, I guess.
It appears your under the impression you're using nylon hose...you're using CPE.
Old 04-07-2016, 01:30 AM   #21
Mrc@ptuning
Mrc@ptuning's Avatar
Drives: S1000RR
Your assumption is incorrect. The fuel hose we are using are not from Russell and these are not the cheap non-SS braided black nylon lines used by some others--that we've seen ruptured. Our fuel hose are specifically designed for use with ethanol fuel. They have a black/blue nylon woven outer covering with a SS braided reinforced inner lining. We opted to use this fuel hose for two reasons, first, they are ethanol compatible and second, although more costly than a conventional SS braided hose, the nylon outer covering prevents abrasion against other metal parts on the vehicle. If you take a standard SS braided line and rub it against a metal part, over time it will wear out the metal part like using a file--not a good thing.
Here's the hose spec:
Construction: smoth bore lightweight synthetic rubber interior with fluorocarbon based liner, single stainless braid reinforced, black nylon woven exterior w/blue trace.
Application: For gasoline, diesel fuel, biodiesel, E85 and other ethanol based fuels Suitable for most "taper" type hose ends. Operating Temperature Range: -30 f to +300 f (-35 c to +150 c).
MrC
Mrc@ptuning is offline   Reply With Quote
The Following 2 Users Say Thank You to Mrc@ptuning For This Useful Post:
kanundrum (04-07-2016), tato.valverde (04-11-2016)
Old 04-07-2016, 06:48 AM   #22
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Lol. Fail.
Old 04-07-2016, 07:31 AM   #23
M1K3
M1K3's Avatar
Drives: vrooom...
cheap fuel hoses
I don't know how you can look at this kit or any kit that Ptuning makes and call it cheap
M1K3 is offline   Reply With Quote
The Following 4 Users Say Thank You to M1K3 For This Useful Post:
Freddy@PTUNING (04-07-2016), kanundrum (04-07-2016), Mrc@ptuning (04-07-2016), SpectreRT (04-22-2016)
Old 04-07-2016, 09:59 AM   #24
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
One thing for sure is, Ptuning make an amazing parts. What you get is top quality & top craftsmanship parts. They don't believe in "cheap" parts or "half-ass job" parts.
If I had corn gas near by, I'll buy this without a hesitation!
The Following 4 Users Say Thank You to ichitaka05 For This Useful Post:
Freddy@PTUNING (04-07-2016), Guff (04-07-2016), kanundrum (04-07-2016), Mrc@ptuning (04-07-2016)
Old 04-15-2016, 08:52 PM   #25
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
So this attaches to the brake master cyl and thus not compatible with RHD?
Old 04-18-2016, 01:47 AM   #26
BRZ RN
BRZ RN's Avatar
Drives: Blue BRZ
so with this kit and tune i can switch with e85 and 93 octane maps right?
BRZ RN is offline   Reply With Quote
Old 04-18-2016, 04:43 AM   #27
steve99
Once you have flex kit and flex fuel tune in the ecu in car you can put any combination of 93 and e85 in the tank and the flex sensor will detect ethanol content and signal the ecu to adjust the timing and fueling for max benifit from you current fuel mix.
note you need and appropiate flex fuel tune (software in ecu) as well as the flex fuel kit hardware for a working flex fuel system
For max performance about 70% ethanol content or greater is required.
no switching or intervention is required its all automated
The Following 2 Users Say Thank You to steve99 For This Useful Post:
BRZ RN (04-19-2016), Freddy@PTUNING (04-18-2016)
Old 04-18-2016, 10:30 AM   #28
Freddy@PTUNING
Correct. The bracket mounts on the master cylinder bolt on the LHD, the master cylinder on the RHD is on the other side, so it will not fit out of the box. However, that's not to say that you couldn't make a bracket that attaches to the firewall and then bolt that bracket to the flex fuel sensor bracket for the RHD vehicle. It's just that without a RHD car in house it's hard to speculate.
Opensource Flex-Fuel Ethanol Content Analyzer with Bluetooth Fiskafan Software Tuning 26 05-13-2020 01:04 PM
e85 w/o flex fuel kit? zkahle Software Tuning 21 10-16-2015 03:26 PM
Flex Fuel Kit? Khorne Software Tuning 65 02-23-2014 09:13 AM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
Flex Fuel? VenomRush Scion FR-S / Toyota 86 GT86 General Forum 12 01-15-2010 02:55 AM
