Old 02-17-2016, 02:57 PM   #1
ptuning
ptuning's Avatar
Drives: White FR-S
PTUNING Flex Fuel Kit w/Bluetooth Module
After extensive R&D, we're finally ready to release our new PTUNING Bluetooth Flex Fuel System. Our kit utilizes the latest compact flex fuel sensor along with a bluetooth-capable flex fuel module. Our flex fuel kit will also be compatible with our future Return-Style Fuel System. This future system will feature a swirl pot/surge tank assembly to allow for 500+whp builds and also prevent fuel starvation on track cars.
http://www.ptuning.com/subdir/partno...=PTP-ENG-90080
We had a few design criteria that we wanted to meet with our Flex Fuel System:
- Hide the flex fuel sensor for aesthetic reasons (all flex fuel sensors are ugly)
- Locate the flex fuel sensor and lines in a location that provides for increased collision protection
- Needs to be compatible with our future fuel return system
The Flex Fuel System will include the following:
- New style compact flex fuel sensor
- Custom laser-cut and CNC-bent PTUNING sensor mounting bracket
- Billet Aluminum OEM-style Quick Connect Fittings
- Ethanol compatible racing-quality fuel lines with AN Fittings
- All necessary electrical connectors to wire up to the factory ECU
- Complete installation and wiring manual
- Bluetooth module for use with Android devices (Can also be wired up to the auxiliary input on P3 Cars Gauges)
- Toan
ptuning is offline   Reply With Quote
Old 02-17-2016, 07:30 PM   #2
k.houan
k.houan's Avatar
Drives: BRZZZ
Will I be able to use this with an open flash tablet?
Sent from my Nexus 6P using Tapatalk
k.houan is offline   Reply With Quote
Old 02-17-2016, 08:51 PM   #3
djliquidsteele
Drives: Scion FR-S
Android devices only?
djliquidsteele is offline   Reply With Quote
Old 02-18-2016, 03:02 AM   #4
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
How does this interface to the ECU?
Sent from my HTC6525LVW using Tapatalk
JDKane527 is offline   Reply With Quote
Old 02-18-2016, 04:22 AM   #5
umpadupa
umpadupa's Avatar
Drives: 94 civic hatch, Whiteout frs
subbed for more info.
works with Ecutek im guessing?
umpadupa is offline   Reply With Quote
Old 02-18-2016, 05:02 AM   #6
steve99
The tablet is just a device to flash rom\tune what you need in the software changes in the ecu to interpret and act on the flex fuel sensor volts.
Shiv is currently working with a guy in australia who has flex fuel coding for opensource Its working A01G and a use rom shiv is testing on his turbo car, but it will need to be ported across to other roms. Its possible this may be added to openflash tunes in the future
Old 02-18-2016, 01:03 PM   #7
ptuning
ptuning's Avatar
Drives: White FR-S
This device will only provide the 0-5V output needed to integrate with your ECU. However, like with all flex fuel kits, you will need the custom RaceROM maps available with ECUTek in order to integrate flex fueling. If OFT is working on developing their own custom ROM features, then it may be possible to do flex fueling down the road.
- Toan
Old 02-18-2016, 01:08 PM   #8
ptuning
ptuning's Avatar
Drives: White FR-S
The Buetooth feature will only work with Android devices, but the ECU (ECUTek) will always be able to read the 0-5V output signal regardless. An IOS version may be available later on down the road. Unfortunately, developing hardware/software for Apple products always take a lot longer to do. :/
- Toan
Old 02-18-2016, 01:20 PM   #9
ptuning
ptuning's Avatar
Drives: White FR-S
This device can be integrated with the factory ECU (currently only ECUTek) using either the CPC pressure sensor or rear O2 sensor input. The ECUTek software uses 16 custom RaceROM maps that allow the tuner to write his/her own maps for fueling, timing, boost, etc. based on measured ethanol content.
We offer in-house dyno tuning as well as various eTunes for NA and FI applications. We often take advantage of just about every available custom RR maps to allow the factory ECU to take on a standalone type of feel in terms of flex-fueling capability. This can include Boost by gear, boost by ethanol content, variable boost cut based on ethanol content and the list goes on and on. The custom RaceROM features pretty much will allow an experienced tuner to take full advantage of this flex-fuel system.
- Toan
Old 02-22-2016, 12:59 PM   #10
Freddy@PTUNING
Freddy@PTUNING's Avatar
Drives: Honda S2000 & Acura RSX Type-S
Send a message via AIM to Freddy@PTUNING
PMs replied.
Freddy@PTUNING is offline   Reply With Quote
Old 02-22-2016, 09:12 PM   #11
speed6sam
Drives: SWP BRZ Limited 6 Spd
Price?
speed6sam is offline   Reply With Quote
Old 02-24-2016, 09:13 AM   #12
Freddy@PTUNING
Originally Posted by speed6sam View Post
Price?
Introductory price of $495 for the month of February (regular price of $595).
http://www.ptuning.com/subdir/itemde...&ModelDesc=FRS
Old 02-24-2016, 05:48 PM   #13
kanundrum
Drives: 2013 Whiteout FR-S
Soon to be installed with a Ptuning Turbo setup I hope!
Old 02-28-2016, 05:31 AM   #14
ZeroTo86
ZeroTo86's Avatar
Drives: '13 FR-S Turbo (Greddy T620z)
Wow such a great price and at the right time too for my Innovate kit! I just placed an order now and if you guys can possibly get it shipped out Monday so it may hopefully arrive Thursday for my dyno tune appointment that would be AMAZING!!
My order# is 980412319. (:
ZeroTo86 is offline   Reply With Quote
Opensource Flex-Fuel Ethanol Content Analyzer with Bluetooth Fiskafan Software Tuning 26 05-13-2020 01:04 PM
e85 w/o flex fuel kit? zkahle Software Tuning 21 10-16-2015 03:26 PM
Flex Fuel Kit? Khorne Software Tuning 65 02-23-2014 09:13 AM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
Flex Fuel? VenomRush Scion FR-S / Toyota 86 GT86 General Forum 12 01-15-2010 02:55 AM
