Old 10-15-2015, 03:11 PM   #1
zkahle
zkahle's Avatar
Drives: 2013 Scion FRS Asphalt
e85 w/o flex fuel kit?
I am planning on purchasing a OFT and OFH to go with my muffler delete as well as to gain some power and fill in the dreaded torque dip in our power band. I have a few questions for you guys that have probably been answered in other threads but I want yalls opinions if you have been running these tunes/setup.
1) Drawback to not using the flex fuel kit. Is it safe and can this harm the car in any way?
2) What tune should I use to get the most out of e85 and a header? And what are the expected gainz?
3) How long will it be before I loose my hearing b/c of headers and muffler delete.
zkahle is offline   Reply With Quote
Old 10-15-2015, 03:15 PM   #2
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Not really, keep it e60 and higher. No harm to car as long as you run the proper tune with correct gas.
The OFT has off the shelf tunes you can use, expect lots of horsepowers.
WHAT? SPEAK UP I CANT HEAR YOU. Jk, I guess you'll find out.
All of this can be found by searching btw, so expect some flak.
The Following 2 Users Say Thank You to continuecrushing For This Useful Post:
Tectoniic (10-15-2015), zkahle (10-15-2015)
Old 10-15-2015, 03:15 PM   #3
raven1231
1) Yes, it's safe.
2) OFT has an E85 UEL tune, which is what you would use with the OFH
3) Depends on your ears.
As far as flex fuel it allows you to not have to run your tank empty all the time to switch which is nice.
zkahle (10-15-2015)
Old 10-15-2015, 03:21 PM   #4
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
I'm going to try and get you started. I know that many people will post a bunch of threads and tell you to search, however there is A LOT to sift through, and sometimes I feel that it's not exactly spelled out. Some of us need the Cliff Notes rather than the entire novel. If I am wrong about ANYTHING, I encourage anyone to correct my errors.
1) Drawback to not using the flex fuel kit. Is it safe and can this harm the car in any way? From what I have read/researched, you can safely run the OFT base tunes with e85 and there is an accounted margin for error (fuel from station to station). Also seems as though it is a waste to go with a flex fuel kit if you aren't FI. Yes, I know there is the "better safe than sorry" argument, but Shiv and other have done a good job at getting us where we need to be, safely.
2) What tune should I use to get the most out of e85 and a header? And what are the expected gainz? Stage 2 Header Tune. Isn't it something like 20-30 HP?
3) How long will it be before I loose my hearing b/c of headers and muffler delete. It all depends on how much your ears can take, it's all relative.
I hope this serves as a brief start.
LOLS2K is offline   Reply With Quote
The Following User Says Thank You to LOLS2K For This Useful Post:
zkahle (10-15-2015)
Old 10-15-2015, 04:22 PM   #5
zkahle
zkahle's Avatar
Thanks guys, I appreciate the non trollish replies. I am looking forward to the gainz! I am planning on doing this as soon as i save up enough money so within the next month or so. Then this summer, shit is gona get real when I go FI. Thanks again.
Old 10-15-2015, 04:26 PM   #6
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
I am running a Tomei UEL with Berk muffler delete (e85 tune) and I love it. I added a Berk Catless front pipe which was replaced within a week. I put back the oem front pipe because it was too loud for my taste.
The Following User Says Thank You to NyC Zn6 For This Useful Post:
zkahle (10-15-2015)
Old 10-15-2015, 04:29 PM   #7
zkahle
zkahle's Avatar
Are you experiencing major resonance between 2-3k rpm? I have the berk as well and that rmp band seems to be when there is the most (boomb). Do the uel headers amplify that or somehow eliminate it?
Old 10-15-2015, 04:46 PM   #8
NyC Zn6
NyC Zn6's Avatar
Not major but there is definitely some resonance at that rpm range. It is not over bearing because the rumble is pure eargasm lol.
zkahle (10-15-2015)
Old 10-15-2015, 04:48 PM   #9
zkahle
zkahle's Avatar
Haha okay, before this i was scared that this might be too loud but you have convinced me otherwise. Do you have a sound clip of your setup (possibly in cabin/behind the car)????
Old 10-15-2015, 04:52 PM   #10
zkahle
zkahle's Avatar
I could even give you my email or some thing to make it easier for you upload a video as opposed to dropbox or youtube... I am just curious what an eargasm sounds like.
Old 10-15-2015, 04:53 PM   #11
NyC Zn6
NyC Zn6's Avatar
Currently at work. I will get a clip for you when I get out.
Old 10-15-2015, 07:06 PM   #12
NyC Zn6
NyC Zn6's Avatar
[ame="https://www.youtube.com/watch?v=QMcKYVdOfvM"]FRS Tomei UEL header & Berk muffler delete - YouTube[/ame]
zkahle (10-15-2015)
Old 10-15-2015, 07:12 PM   #13
phrosty
The main benefit of a proper flex kit is not having to wait for fuel trims to learn your E%. With a tune, transitioning from E85 to 93 is a bit interesting.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
The Following 2 Users Say Thank You to phrosty For This Useful Post:
kch (10-16-2015), zkahle (10-15-2015)
Old 10-15-2015, 07:31 PM   #14
zkahle
zkahle's Avatar
Thank you very much for the video, and that is indeed a eargasm. Also you car looks great.
The Following User Says Thank You to zkahle For This Useful Post:
NyC Zn6 (10-15-2015)
WTB E85 Flex Fuel Kit Wyattkb Want-To-Buy Requests 6 09-20-2015 09:48 AM
flex fuel kit Anthony7515 Want-To-Buy Requests 1 06-25-2015 09:38 PM
Flex Fuel Kit? Khorne Software Tuning 65 02-23-2014 10:13 AM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 10:36 AM
Flex Fuel? VenomRush Scion FR-S / Toyota 86 GT86 General Forum 12 01-15-2010 03:55 AM
