Old 07-08-2012, 12:18 AM   #15
Lonewolf
Lonewolf's Avatar
Drives: Moped
On my past cars drop-in filters always improved my throttle response and mileage. Hp gains are minimal, but throttle response (which gives the illusion of more power) changes.
Old 07-08-2012, 12:19 AM   #16
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
I got 170 who sae corrected with lighter wheels 16lbs and k&n filter
mechaghost is offline   Reply With Quote
Old 07-08-2012, 01:26 AM   #17
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Asterisked Accolade View Post
Do you think there is more to gain in responsiveness from the filter than real hp?
Yes, the throttle response improvement is noticeable.
But obviously, let's keep in perspective it is just a drop in filter, nothing crazy here, just noticeable.
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
Asterisked Accolade (07-08-2012), Bonburner (07-08-2012)
Old 07-08-2012, 01:29 AM   #18
Sportsguy83
Drives: Limited BRZ
Originally Posted by Snoopyalien24 View Post
With lighter wheels isnt that like 180whp or 203hp?? Awwww yeah!
Gonna add soooooo many STICKERS
Oh no Doubt!!
I put in the filter, and felt meh about it... Then proceeded to install the sticker and BOOM! HUGE improvement! It was so incredible I ordered two more!
The Following 4 Users Say Thank You to Sportsguy83 For This Useful Post:
eddieEndo (06-12-2013), quik1987 (07-12-2012), Snoopyalien24 (07-08-2012), uptown (08-19-2012)
Old 07-08-2012, 01:34 AM   #19
TOMIMOTO
TOMIMOTO's Avatar
Drives: MY00 Impreza 2.5RS
Intake systems in cars below 350 whp are useless. A lot of WRX/STI guys drop in a K&N and call it a day.
TOMIMOTO is offline   Reply With Quote
The Following User Says Thank You to TOMIMOTO For This Useful Post:
sho220 (07-16-2012)
Old 07-08-2012, 09:19 AM   #20
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
It depends on the design of the stock intake. Subaru intakes tend to be pretty good with, as you said, 300-350whp capability. But some cars aren't so lucky. The BRZ/FR-S intake looks really simple so I'm sure it's an efficient design. I just wonder about the opening through the radiator core and the horn behind the bumper.. Seems kind of tight. I wonder if there might be some gains from a free mod there.
Maybe I can find someone's stock airbox to play with.
Old 07-08-2012, 09:49 AM   #21
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
Originally Posted by sportsguy83 View Post
Oh no Doubt!!
Yo dawg, what if, like, you put the stickers on the ENGINE? Wouldn't that like be like amazing?
Snoopyalien24 is offline   Reply With Quote
The Following 3 Users Say Thank You to Snoopyalien24 For This Useful Post:
lazyluka (02-04-2013), quik1987 (07-12-2012), Sportsguy83 (07-08-2012)
Old 07-08-2012, 06:48 PM   #22
xwd
Drop in filters do not generally gain anything with regards to HP but they dont lose any either and do not have to be replaced. I am planning on doing a dyno comparison between the aFE panel filter and the stock one.
Old 07-08-2012, 10:58 PM   #23
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
It depends of the design. My 2.5 rabbit gained 16whp with a cai since the stock filter sits atop the exhaust manifold. A sri would most likely make you loose power because it would be sucking in hot air. It would probably improve sound.
Silverdub is offline   Reply With Quote
Old 07-12-2012, 04:39 PM   #24
narfy
short asian guy
narfy's Avatar
Drives: ZN6, VZN185
TRD now lists PTR43-00085 (number provided by OP) as the drop in air filter for the FR-S...
VZN185 - 32" BFG AT, OME suspension, ARB bumper, lightforce lights, TRD trans cooler, TRD exhaust, budbuilt plates...
ZN6 - stock with HIDs and LEDs...
fng@regencyauto.com
narfy is offline   Reply With Quote
The Following User Says Thank You to narfy For This Useful Post:
Silverdub (07-12-2012)
Old 07-12-2012, 05:30 PM   #25
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
Yes, but if the new filter is $50 and paper filters are $10...you can buy about 125,000 miles worth of paper before you break even.
Admiral Ballsy is offline   Reply With Quote
Old 07-12-2012, 05:59 PM   #26
quik1987
quik1987's Avatar
Drives: Bugatti Veyron
It's different from the TRD Japan one though
Taking racing engine technology developed under the harshest standards and modifying it for commercial use has enabled us to achieve the smooth, clean air flow an engine needs.
For installation, simply remove the standard air filter.
Install as a set with the High Response Muffler Ver.R to create an optimal pairing of intake & exhaust – the difference in smooth engine response will be noticeable immediately.
Sports Air Filter
All Models MS155-00009 1 9,000
quik1987 is offline   Reply With Quote
The Following User Says Thank You to quik1987 For This Useful Post:
Fly Guy (07-12-2012)
Old 07-16-2012, 02:33 AM   #27
quik1987
quik1987's Avatar
Old 07-16-2012, 04:00 AM   #28
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
Is that because the box has an inherent resistance to radiant heat?
It's usually because stock boxes are engineered by...well...engineers.
sho220 is offline   Reply With Quote
Which oil filter for the FA20? ft86Fan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 58 07-09-2012 12:21 PM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
TRD Air Filter tonystewart Engine, Exhaust, Transmission 16 06-21-2012 12:46 PM
Oil Filter Brett Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 05-23-2012 09:53 PM
air filter andy19804 Engine, Exhaust, Transmission 9 04-28-2012 03:35 PM
