Old 06-28-2012, 02:43 PM   #1
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
TRD air filter inside!
Since TRD doesnt have an airfilter listed yet in canada for the FR-S i decided to take my stock unit out and open up so boxes at work. Turns out its the exact same thing as a matrix 05. So below is 3 pictures with the part number!
Silverdub is offline   Reply With Quote
The Following 7 Users Say Thank You to Silverdub For This Useful Post:
Astroboy (05-15-2015), dcfr (07-07-2012), Guff (07-12-2012), kmbkk (07-07-2012), pyro530 (07-07-2012), SkullWorks (06-28-2012), Snoopyalien24 (07-08-2012)
Old 06-28-2012, 02:57 PM   #2
SkullWorks
Drives: SSM LT MT BRZ
well done sir
Old 07-07-2012, 09:13 AM   #3
dcfr
dcfr's Avatar
Drives: Ultramarine FR-S
Thanks for the tip. So is it perfect fit?
dcfr is offline   Reply With Quote
Old 07-07-2012, 09:46 AM   #4
thermobox
Drives: 16 Impreza 5dr CWP
Cost?
thermobox is offline   Reply With Quote
Old 07-07-2012, 10:07 AM   #5
Asterisked Accolade
Pedals over Paddles.
Asterisked Accolade's Avatar
Drives: Celica GT-S | 89 Supra | 07' Accent
I presume that a filter alone doesn't do all that much, am i right? I would think for a noticeable change you'd need a SRI or CAI. Personally i'd also heat-wrap it. But anyways, are there any dyno comparisons of stock filter versus the TRD?
2002 Celica GT-S Track Car | 1989 Supra Track Car | 2007 Hyundai Accent AutoX | 2003 Cadillac CTS Daily
Asterisked Accolade is offline   Reply With Quote
Old 07-07-2012, 11:47 AM   #6
ImAwesome
Drives: 99' M3, 13' SWP Brz
Actually you are more likely to see good gains in a modified stock air box with a better filter then you are with a SRI in most cases
ImAwesome is offline   Reply With Quote
Old 07-07-2012, 04:35 PM   #7
Asterisked Accolade
Is that because the box has an inherent resistance to radiant heat?
Old 07-07-2012, 04:35 PM   #8
ImAwesome
in most cases
Old 07-07-2012, 04:40 PM   #9
Asterisked Accolade
in most cases
Then i wonder if just a good heat-wrapping (Which is kind of fun do to) would do the same for the SRI(?) I've heat wrapped my SRIs and on the Celica i actually put in a duct system which runs from the fog light port in the bumper right to the filter. I wonder if that would be as good as the air box-- albeit with much more work/effort.
Old 07-07-2012, 07:47 PM   #10
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Rallysport did a Dyno of an APEXi high flow drop in filter, gains where about 3 HP and 2 TQ.
Old 07-07-2012, 11:56 PM   #11
Asterisked Accolade
That's not bad for just a drop in. I've heard of K&N being 10-12hp(not whp).
Old 07-08-2012, 12:03 AM   #12
Sportsguy83
Drives: Limited BRZ
It depends on the engine. From a V8, probably. On this car, I would not bet anything over 5 HP and that's a big stretch.
I have the KN for our car. there definitely is some gain but I'm sure its 3HP tops.
Old 07-08-2012, 12:08 AM   #13
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
With lighter wheels isnt that like 180whp or 203hp?? Awwww yeah!
Gonna add soooooo many STICKERS
Snoopyalien24 is offline   Reply With Quote
The Following 4 Users Say Thank You to Snoopyalien24 For This Useful Post:
eddieEndo (06-12-2013), number1Tango (02-04-2013), quik1987 (07-12-2012), usptwins (02-05-2013)
Old 07-08-2012, 12:14 AM   #14
Asterisked Accolade
Do you think there is more to gain in responsiveness from the filter than real hp?
Which oil filter for the FA20? ft86Fan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 58 07-09-2012 12:21 PM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
TRD Air Filter tonystewart Engine, Exhaust, Transmission 16 06-21-2012 12:46 PM
Oil Filter Brett Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 05-23-2012 09:53 PM
air filter andy19804 Engine, Exhaust, Transmission 9 04-28-2012 03:35 PM
