Tracking / Autocross / HPDE / Drifting What these cars were built for! |
#15 |
Drives: Track preped NA FRS
How many lateral Gs and for how long do you guys sustain it to get fuel starvation? I havent hit it myself but I run in fairly small tracks, no long sweepers, just wondering for the future (there is one big track with a long sweeper in my calendar this year).
#16 |
Drives: 2015 Raven FRS
#17 | |
#18 | |
#19 |
Drives: 2015 FR-S Release Series 1.0
You are experiencing fuel starvation. This is a well known issue for left hand turns in boosted cars and there are a few threads with more details and solutions.
I have the Vortech supercharger and have the same issue on turn 3 at Palmer Motorsports Park. It is a sweeping left hander which I am going through at full throttle. If I am below 3/4 tank I see my revs start to drop at full throttle and my AFR goes full lean. This only started happening after I switched to 17x9 with 245 Direzzas and swapped out my sway bars. With these mods our cars are pulling significantly more lateral g's than the fuel tank was designed for. The only solution I have heard of that has been documented to work reliably is a surge tank in the engine bay. This is a cumbersome and expensive modification that requires an additional (noisy) fuel pump and a tank that is vented to atmosphere (get used to smelling gasoline). And of course there is a greatly increased chance of fire when adding fuel lines in the engine bay. I have heard mention of having a Holley Hydramat installed in the fuel tank, or an installing an additional in-tank floating fuel pump but have not seen anyone who has done either of these on the forum yet. Until then I suggest you lift or risk destroying your engine. |
#20 | |
#21 | |
And if I may ask, what spring rates are you using. |
#22 | |
I've since put the sways back on the softest setting to try to alleviate the fueling issue but still if I'm below half tank I get starvation in that one turn at full throttle so now I just ease off early and brake very late into the next corner. I would assume that if you bias damping settings/tire pressure on one side of the car or go with softer sways to increase body roll it might make a difference but at the expense of speed. @CSG Mike would know more about the issue and talked about it in the thread below http://www.ft86club.com/forums/showthread.php?t=33991 |
#23 | |
#24 | |
245 or wider, 200TW or stickier, boost, a stiff suspension, and downforce will get you there. This chassis is incredibly well balanced. Last edited by avishenoy1; 06-02-2017 at 11:37 AM. |
#25 |
This looks like it would help: http://www.radiumauto.com/Fuel-Pump-...T86-P1142.aspx
Definitely not a guarantee against starvation but looks like it would have much better pickup than the oem or a drop in pump. This plus a surge tank would be the full fix for a high horsepower track monster. |
The Following User Says Thank You to avishenoy1 For This Useful Post: | Icecreamtruk (06-02-2017) |
#26 | |
#27 |
Here's the corner where I had the problem. Right after I hit the straight you can hear the engine quit revving and me short shifting.
https://www.facebook.com/steve.joneli?fref=ts |
#28 |
Moto-East has a plug and play surge kit that is the best option on the market right now in my opinion.
http://www.ft86club.com/forums/showthread.php?t=105934
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
The Following User Says Thank You to Jonsey For This Useful Post: | DAEMANO (06-02-2017) |
Left Hand turn fuel starvation on WOT | Huehuecoyotl | Tracking / Autocross / HPDE / Drifting | 105 | 08-05-2021 07:12 PM |
High boost, e85, fuel starvation on a road course: What's everyone doing in 2015? | Xero-Limit | Tracking / Autocross / HPDE / Drifting | 6 | 06-16-2015 12:45 PM |
Fuel Starvation issues? YAY OR NAY? | track_warrior | Tracking / Autocross / HPDE / Drifting | 23 | 10-22-2013 11:19 AM |
Oil starvation in high loads | jdcorbitt3 | Engine, Exhaust, Transmission | 7 | 06-01-2013 10:46 PM |
Fuel Starvation | feldy | Tracking / Autocross / HPDE / Drifting | 1 | 06-09-2012 10:14 AM |
