Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
12-10-2021, 02:22 PM | #15 |
Drives: 2020 BRZ Limited
This times eleventeen billion. I spent hours on YouTube looking up and listening to endless exhaust combinations. The 'in conjunction with' cannot be overstated. My combo is the FT86 UEL, Perrin 2.5", and OFT tune but I wouldn't declare it as the best sounding for you. Was, and is, the best sounding to me.
12-11-2021, 11:07 AM | #16 |
Drives: Black 2014 Subaru BRZ Limited
Thanks for the input... I'd like to keep my catalytic converter so I don't have to worry about check engine lights.
12-11-2021, 11:18 AM | #17 | |
Drives: 2018 Subaru BRZ
Then you’ll best option would be either FT86 or JDL. UEL headers. I believe they both cost around the same, and I would recommend getting them ceramic coated. Or you can wrap them. Sent from my iPhone using Tapatalk |
12-11-2021, 11:20 AM | #18 |
Drives: 17 Asphalt 86
12-11-2021, 12:26 PM | #19 |
If just looking for sound then leave the header alone and consider catback systems instead
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | saltywetman (12-11-2021), x808drifter (12-11-2021) |
12-11-2021, 12:43 PM | #20 |
I already have the Zeta cat-back exhaust, just looking for that "Subaru Rumble" I heard the UEL headers get you that sound?
12-11-2021, 05:00 PM | #21 | |
That Guy
Drives: 2013 asphalt FRS MT
Throw in a larger throttle body, a long tube header, a tuned ecu, a limited slip diff, a PT cruiser clutch, koni struts, some stiffer springs, and appropriate tires and it would do mid 14s in the ¼ mile and get to within spitting distance of a full g in a corner on mid 90s tires. For the time period it really wasn't that bad. Drop the power steering and swap in the 16:1 rack and it just came alive with how much information you got through the wheel with great turn in. And that took about 25 pounds out of the car with the pump, bracket, and lines. There was plenty more weight you could pull out, too. There was a solid back seat instead of the one that opened to the trunk for a few less pounds, a side impact bar across the bottom of the back seat in the two door, a damper on the front motor mount, a smaller battery, about 30lbs of wiring that only made it harder to trouble shoot anyway, the spare tire and jack, hood insulation... ~2250-2300lbs really wasn't out of the question. |
The Following User Says Thank You to Calum For This Useful Post: | Jdmjunkie (12-11-2021) |
12-11-2021, 06:10 PM | #22 | |
The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
12-11-2021, 08:40 PM | #24 | |
Drives: Subaru BRZ
Sent from my SM-G973F using Tapatalk |
12-12-2021, 04:18 PM | #25 |
That Guy
Similar Threads | ||||
ticking sound with el header install. | fluffy-reindeer-slayer | Engine, Exhaust, Transmission | 10 | 05-11-2021 01:13 AM |
Fluterring sound after header and op install | j2digit | Engine, Exhaust, Transmission | 21 | 04-02-2020 09:28 AM |
UEL header rumble sound question | FR-Sky | Engine, Exhaust, Transmission | 41 | 04-05-2016 02:28 AM |
Stock catback w/header sound OK? | xDanger_208x | Engine, Exhaust, Transmission | 59 | 10-07-2015 01:40 AM |
tomei UEL header and overpipe sound | mokinbird87 | Engine, Exhaust, Transmission | 11 | 04-07-2015 09:05 PM |
