Old 12-10-2021, 02:22 PM   #15
therealstoly
therealstoly's Avatar
Drives: 2020 BRZ Limited
This is a completely subjective topic. One person's "best" sound may be another's nightmare noise. Also what exhaust is going to be used in conjunction with the header? There are some truly horrible sounding combinations out there.
This times eleventeen billion. I spent hours on YouTube looking up and listening to endless exhaust combinations. The 'in conjunction with' cannot be overstated. My combo is the FT86 UEL, Perrin 2.5", and OFT tune but I wouldn't declare it as the best sounding for you. Was, and is, the best sounding to me.
therealstoly is offline   Reply With Quote
Old 12-11-2021, 11:07 AM   #16
Ace000087
Ace000087's Avatar
Drives: Black 2014 Subaru BRZ Limited
Thanks for the input... I'd like to keep my catalytic converter so I don't have to worry about check engine lights.
Ace000087 is offline   Reply With Quote
Old 12-11-2021, 11:18 AM   #17
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Then you’ll best option would be either FT86 or JDL. UEL headers. I believe they both cost around the same, and I would recommend getting them ceramic coated. Or you can wrap them.
spcmafia is offline   Reply With Quote
Old 12-11-2021, 11:20 AM   #18
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Even with the catted headers you risk ending up with a CEL. Tune is the best way to disable codes and get a little extra power.
Old 12-11-2021, 12:26 PM   #19
If just looking for sound then leave the header alone and consider catback systems instead
saltywetman (12-11-2021), x808drifter (12-11-2021)
Old 12-11-2021, 12:43 PM   #20
Ace000087
Ace000087's Avatar
I already have the Zeta cat-back exhaust, just looking for that "Subaru Rumble" I heard the UEL headers get you that sound?
Old 12-11-2021, 05:00 PM   #21
Calum
That Guy
Drives: 2013 asphalt FRS MT
You do realize that the first gen neons came with a 2.25" stainless exhaust, right? In 96 that base engine was making ~135hp at the crank with a torque curve that looked like a ruler, in a car that weighed about 2400lbs. Not great with the 3.55fd, but not terrible either. You could get the dohc with ~10hp more, but the real treat with the 7300rpm redline and the 3.94fd and about the same torque maybe a couple more. In the same 2400lb car there was legitimate fun to be had.
Throw in a larger throttle body, a long tube header, a tuned ecu, a limited slip diff, a PT cruiser clutch, koni struts, some stiffer springs, and appropriate tires and it would do mid 14s in the ¼ mile and get to within spitting distance of a full g in a corner on mid 90s tires. For the time period it really wasn't that bad.
Drop the power steering and swap in the 16:1 rack and it just came alive with how much information you got through the wheel with great turn in. And that took about 25 pounds out of the car with the pump, bracket, and lines. There was plenty more weight you could pull out, too. There was a solid back seat instead of the one that opened to the trunk for a few less pounds, a side impact bar across the bottom of the back seat in the two door, a damper on the front motor mount, a smaller battery, about 30lbs of wiring that only made it harder to trouble shoot anyway, the spare tire and jack, hood insulation... ~2250-2300lbs really wasn't out of the question.
The Following User Says Thank You to Calum For This Useful Post:
Jdmjunkie (12-11-2021)
Old 12-11-2021, 06:10 PM   #22
Wow I offended the one Neon fan on the forum!
Calum (12-12-2021), NoHaveMSG (12-12-2021), x808drifter (12-12-2021)
Old 12-11-2021, 06:25 PM   #23
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Hey, I can’t enjoy the driving experience fully unless I KNOW the steering column will kill me in a 25mph impact.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Old 12-11-2021, 08:40 PM   #24
Purist
Purist's Avatar
Drives: Subaru BRZ
Heard a trauma surgeon sarcastically suggest that airbags should be replaced with large, metal spikes in order to really modify driver behaviour.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
Old 12-12-2021, 04:18 PM   #25
Calum
That Guy
Lol
The Following 2 Users Say Thank You to Calum For This Useful Post:
NoHaveMSG (12-12-2021), Tcoat (12-12-2021)
ticking sound with el header install. fluffy-reindeer-slayer Engine, Exhaust, Transmission 10 05-11-2021 01:13 AM
Fluterring sound after header and op install j2digit Engine, Exhaust, Transmission 21 04-02-2020 09:28 AM
UEL header rumble sound question FR-Sky Engine, Exhaust, Transmission 41 04-05-2016 02:28 AM
Stock catback w/header sound OK? xDanger_208x Engine, Exhaust, Transmission 59 10-07-2015 01:40 AM
tomei UEL header and overpipe sound mokinbird87 Engine, Exhaust, Transmission 11 04-07-2015 09:05 PM
