#253 | |
VehicleDynamicsSpecialist
Drives: iG FR-S
Those wheels will "fit". Just depends how aggressive you want to get. Aggressive being how far you want the wheels to poke outward. The first selection(s) in the link provided are the most aggressive fitment. (+35/+15 or +35/+ 28) While the lower selection in the link provided is the most conservative fitment. (+48/+38) The more aggressive the fitment the more negative camber, roll or pull you may need to avoid contact with the fender(s).
"The best track modification you can ever make is between the steering wheel and seat." - CSH |
#254 | |
So what would you recommend? I want to lower it about 1.25 - 1.5 inches. When it comes to wheels, I know know nothing. I just don't want anything to scrape. And the websit doesn't have the FR-S on it so I don't know what to do. |
#255 |
Drives: iG FR-S
With all due respect i recommend you study and make your own decisions. In regards to both wheel fitment and suspension geometry and how lowering too much can hurt performance.
It's all a personal preference. I will not tell you what to get. If all you read above was blah blah blah then consider +48/+38 and play it conservative. ![]() Peace.
#256 |
Drives: 2013 Firestorm Scion FRS
Would the stock tires mount on 17x8?
Without any problems?
#257 |
SLO NO MO
#258 |
Love Boost!!!!!!!!
Drives: Whiteout Scion FR-S
im using them on a 17x9 rim lol
#259 |
Love Boost!!!!!!!!
see
| The Following User Says Thank You to whitefrs For This Useful Post: | flippy (11-07-2012) |
#260 |
Drives: 99' SIR Kswapped Racer/Showcar
The answer is yes but a better question would be why?
A 17x8 rim is clearly not your winter rim choice - why reuse the cheap OEM rubber on a Summer/Performance rim? Personally I would just save up to put on some proper tires as they WILL positively affect the driving experience in almost every way. Better acceleration, grip through corners and braking are all advanced with a good rubber choice. |
#261 | |
SLO NO MO
Not a big market out there for these used tires so the best way to save up is to use them. Sent from my Galaxy Nexus using Tapatalk 2 |
| The Following User Says Thank You to Foobar For This Useful Post: | flippy (11-07-2012) |
#262 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
| The Following User Says Thank You to finch1750 For This Useful Post: | flippy (11-07-2012) |
#263 |
I put the OE 215/45/17 on a 17x8. They worked exactly as planned. http://www.ft86club.com/forums/showthread.php?t=20489
| The Following User Says Thank You to dj petey For This Useful Post: | flippy (11-07-2012) |
#264 |
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
Will this work? Need feedback.
Hello i recently saw a great deal on some:
Volk Racing Ce28n Time Attacks 18x8.5 +52 offset I was wondering if it would fit my ride with either a (Project Kics 15mm P.C.D. Conversion Spacer - 5x100 to 5x114.3) or the (Project Kics 10mm P.C.D. Conversion Spacer - 5x100 to 5x114.3) I have eibach 1 inch lowing springs, so thats something to take into mind also. So will it fit? i need someone with experince on this subject of offsets and spacers. |
#265 |
Drives: 2005 Subaru STI
check this out
| The Following User Says Thank You to jkonquer For This Useful Post: | R2RO (11-07-2012) |
#266 |
AutoX Addict
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
Audi TT Steelies
Hi folks, I have to get winters tires stat since my star specs are bald. A local guy has a set of 16" steelies off of a 2001 Audi TT Quattro with 205/55/16 Dunlop Winter Sport M3s on them (2 seasons old.) What would it take to make them fit? Is the hub bore going to be an issue or do I just need rings?
2013 BRZ Limited- GBS - 6MT -VIN #0937 ~~NYR SCCA # 18 C Street R (CSR)~~ "But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
