Old 11-05-2012, 05:02 AM   #253
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Originally Posted by Mo707 View Post
Can someone help me here?
Should the offset of the front tires be more than the back?
or the other way around? And will these wheels fit with the stock hight and if i lowered the car an inch (maybe a little more?)
http://www.elementwheels.com/proddet...188gmdr3118gm#
Front offset is typically higher than the rear. Or they can be the same offset with staggered width. Or they could be the same offset and width.
Those wheels will "fit". Just depends how aggressive you want to get. Aggressive being how far you want the wheels to poke outward.
The first selection(s) in the link provided are the most aggressive fitment.
(+35/+15 or +35/+ 28)
While the lower selection in the link provided is the most conservative fitment.
(+48/+38)
The more aggressive the fitment the more negative camber, roll or pull you may need to avoid contact with the fender(s).
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 11-05-2012, 12:55 PM   #254
Mo707
Mo707's Avatar
(+48/+38)
So what would you recommend?
I want to lower it about 1.25 - 1.5 inches.
When it comes to wheels, I know know nothing.
I just don't want anything to scrape. And the websit doesn't have the FR-S on it so I don't know what to do.
Mo707 is offline   Reply With Quote
Old 11-05-2012, 11:26 PM   #255
ill86
ill86's Avatar
Drives: iG FR-S
With all due respect i recommend you study and make your own decisions. In regards to both wheel fitment and suspension geometry and how lowering too much can hurt performance.
It's all a personal preference. I will not tell you what to get.
If all you read above was blah blah blah then consider +48/+38 and play it conservative.
Peace.
Old 11-06-2012, 02:09 PM   #256
flippy
flippy's Avatar
Drives: 2013 Firestorm Scion FRS
Would the stock tires mount on 17x8?
Without any problems?
Originally Posted by bdanisi View Post
Can we close this thread it wasn't intended to become vaginal pun fodder
flippy is offline   Reply With Quote
Old 11-06-2012, 02:10 PM   #257
Foobar
SLO NO MO
Foobar's Avatar
Yes
Sent from my Galaxy Nexus using Tapatalk 2
Old 11-06-2012, 02:23 PM   #258
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
im using them on a 17x9 rim lol
Old 11-06-2012, 02:24 PM   #259
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
see
The Following User Says Thank You to whitefrs For This Useful Post:
flippy (11-07-2012)
Old 11-06-2012, 02:26 PM   #260
Orthow
Drives: 99' SIR Kswapped Racer/Showcar
The answer is yes but a better question would be why?
A 17x8 rim is clearly not your winter rim choice - why reuse the cheap OEM rubber on a Summer/Performance rim?
Personally I would just save up to put on some proper tires as they WILL positively affect the driving experience in almost every way. Better acceleration, grip through corners and braking are all advanced with a good rubber choice.
Orthow is offline   Reply With Quote
Old 11-06-2012, 02:33 PM   #261
Foobar
SLO NO MO
Foobar's Avatar
One reason is because he used his stock rims for winters and his OEMs have plenty of tread left and he's planning on getting 17x8s anyway. He can mount these while he saves up for better 235-40s.
Not a big market out there for these used tires so the best way to save up is to use them.
The Following User Says Thank You to Foobar For This Useful Post:
flippy (11-07-2012)
Old 11-06-2012, 03:02 PM   #262
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Why sell good rubber for dirt cheap when you can burn them up yourself. I'm gonna swap them onto my 17x8s when I get them powdercoated
flippy (11-07-2012)
Old 11-06-2012, 05:24 PM   #263
dj petey
dj petey's Avatar
I put the OE 215/45/17 on a 17x8. They worked exactly as planned. http://www.ft86club.com/forums/showthread.php?t=20489
dj petey is offline   Reply With Quote
The Following User Says Thank You to dj petey For This Useful Post:
flippy (11-07-2012)
Old 11-06-2012, 10:04 PM   #264
R2RO
R2RO's Avatar
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
Will this work? Need feedback.
Hello i recently saw a great deal on some:
Volk Racing Ce28n Time Attacks 18x8.5 +52 offset
I was wondering if it would fit my ride with either a
(Project Kics 15mm P.C.D. Conversion Spacer - 5x100 to 5x114.3) or the (Project Kics 10mm P.C.D. Conversion Spacer - 5x100 to 5x114.3)
I have eibach 1 inch lowing springs, so thats something to take into mind also. So will it fit? i need someone with experince on this subject of offsets and spacers.
R2RO is offline   Reply With Quote
Old 11-06-2012, 10:33 PM   #265
jkonquer
Drives: 2005 Subaru STI
check this out
jkonquer is offline   Reply With Quote
The Following User Says Thank You to jkonquer For This Useful Post:
R2RO (11-06-2012)
Old 11-07-2012, 11:14 AM   #266
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
Audi TT Steelies
Hi folks, I have to get winters tires stat since my star specs are bald. A local guy has a set of 16" steelies off of a 2001 Audi TT Quattro with 205/55/16 Dunlop Winter Sport M3s on them (2 seasons old.) What would it take to make them fit? Is the hub bore going to be an issue or do I just need rings?
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
