#2591 | |
Drives: Nissan GT-R
My other option is to reuse my 19x8.5" LM reps with an adapter spacer. This will transform my ET48 wheel to a ET30 wheel. So the question is if a 19x8.5" ET30 will fit? What tire size would be best? Edit: Saw that Michelin Pilot Super Sport makes a 245/30-19. That might be the one to go for?
Nurburgring 07:42 BTG
#2592 |
I'll admit that I'm too lazy to search the forum for the answer since the search function is garbage
![]() I'm wondering if anyone can chime in on fitting 18x9.5 on an otherwise stock BRZ (series.blue but that doesn't matter) without any fender/coilover modifications? If not, what modifications would be needed? Thanks |
#2593 |
Drives: 2013 Asphalt FRS 6AT
Anyone know if I could run 18x8.5 +35 225/40 front and 18x9.5 +30 255/40 or 35 on sportlines? Or possibly 17x9 +35 235/40 square on sportlines? Thanks
Considering klutch sl5 or sl15 for forst spec and Gram Lights 57DR for second spec. |
#2594 |
Drives: SUBARU BRZ 2013 WRB LIMITED
I need some suggestion for tires for my new wheels
Next set up I'm running is 19x9+38 front and 19x10 +38 rear. I'm not going to be slamming my car it's only going to be lowered 1-1.5 to get rid of the gap. Thanks! P.s Im on stock fenders |
#2595 |
Drives: 2013 Scion FR-S Asphalt
XXR 530 18x8.75 35mm
Stock suspension 245/35/18 Square set up Any fitment problems? Front rubbing? |
#2596 |
Drives: 2014 Subaru BRZ
17x9 rims
Will 17x9 rims fit stock suspension the offset is either 35 or 30? Guy I know has a good led on a set of used rims, but I am unable to test fit them do to driving distance to where they are and would like to know before I drive 3hrs if they are going to fit.
#2597 |
Would a 18x8.5 +47 rim fit: lowered 20mm, with -1.5 front camber, without rubbing and touching the springs?
Also, would you recommend 225/40/18 or 225/45/18 tyre? Thanks for the advice! |
#2598 | |
Drives: Subaru BRZ
Thank you. I decided to go with a different set up in the end.
#2599 |
Drives: 2014 Whiteout FRS
17x9 rims on stock suspension with 225x40 all around. Will this have any rubbing issues upfront and will 225 on a 17x9 be ok to take to the track?
#2600 | |
Drives: FR-S Firestorm 6MT
You could even run a 245/40R17 tire depending on the offset, but no issues at all with a 225/40. You didn't mention your wheel offset. You can run a +35 to +45 offset if stock but if you lower with springs then the +45 won't work without spacers. If you lower with coilovers, then no issues. |
| The Following User Says Thank You to Slick For This Useful Post: | Autocon (01-06-2015) |
#2601 | |
Yeah the offset is +45 so thats good to know they will be fine on stock for now.
#2602 |
Drives: None
Would 18x9.75 +20 fit in the rear!?
I have a feeling it won't but I really want to run staggered 18x8.75 +33 in front And 18x9.75 +20 in rear I'm about to buy in a few days, but if it'll rub. And cause issues I guess I'll get 8.75 +33 all around Lowered on sportlines about 1.5 inches Edit: 225/40/18 front 245/40/18 rear I think
#2603 |
Drives: 2014 Scion FR-S Raven
I'm considering the following square set up: 18x9 ET +33. I'm going to lower the car an 1" to 1.5" with some ST Coilovers, and will also be installing rear LCA and, if need be, front camber bolts. So my questions are:
1. Do you guys think 235/40/18 tire would be okay or should i do a 245/40? 2. Would i have to run an excessive negative camber to have a flush appearance? Thanks |
#2604 |
Remember
Drives: 2015 Asphalt
I am putting 17 x 9 et 42 wheels (OZ Formula HLT) on, I have Eibach Pro springs on.
Questions: Will I need spacers and/or camber bolts? I've read about 1.325 million posts regarding similar situations, but haven't found an answer. What tire size would you guys recommend? Tire Rack recommends 245/40, but I'd rather hear from people who drive these cars. Thanks in advance!
This is my 17th car. Most fun so far!
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
