go_a_way1
Old 12-01-2014, 06:12 AM   #2591
MadeInSweden
Drives: Nissan GT-R
Originally Posted by Slick View Post
Between those 2 offsets I would choose the +40 since you have coilovers installed and this will tuck the wheels in a bit more.
With the +35, you will need more camber dialed-in to eliminate the poke or rubbing.
Tire size for that wheel should be the 255/35R18 or 245/35R18. A 245/40R18 will be too tall.
Thanks a lot!
My other option is to reuse my 19x8.5" LM reps with an adapter spacer. This will transform my ET48 wheel to a ET30 wheel. So the question is if a 19x8.5" ET30 will fit? What tire size would be best?
Edit: Saw that Michelin Pilot Super Sport makes a 245/30-19. That might be the one to go for?
Nurburgring 07:42 BTG
MadeInSweden is offline   Reply With Quote
Old 12-04-2014, 10:44 AM   #2592
Pkush
I'll admit that I'm too lazy to search the forum for the answer since the search function is garbage
I'm wondering if anyone can chime in on fitting 18x9.5 on an otherwise stock BRZ (series.blue but that doesn't matter) without any fender/coilover modifications?
If not, what modifications would be needed?
Thanks
Pkush is offline   Reply With Quote
Old 12-11-2014, 11:36 AM   #2593
Drewbie
Drives: 2013 Asphalt FRS 6AT
Anyone know if I could run 18x8.5 +35 225/40 front and 18x9.5 +30 255/40 or 35 on sportlines? Or possibly 17x9 +35 235/40 square on sportlines? Thanks
Considering klutch sl5 or sl15 for forst spec and Gram Lights 57DR for second spec.
Drewbie is offline   Reply With Quote
Old 12-22-2014, 04:04 AM   #2594
Nhan55nguyen
Drives: SUBARU BRZ 2013 WRB LIMITED
I need some suggestion for tires for my new wheels
Next set up I'm running is 19x9+38 front and 19x10 +38 rear. I'm not going to be slamming my car it's only going to be lowered 1-1.5 to get rid of the gap. Thanks!
P.s Im on stock fenders
Nhan55nguyen is offline   Reply With Quote
Old 12-23-2014, 12:22 AM   #2595
AZ_Racer_1
Drives: 2013 Scion FR-S Asphalt
XXR 530 18x8.75 35mm
Stock suspension
245/35/18
Square set up
Any fitment problems? Front rubbing?
AZ_Racer_1 is offline   Reply With Quote
Old 12-24-2014, 05:53 PM   #2596
Callandor
Drives: 2014 Subaru BRZ
17x9 rims
Will 17x9 rims fit stock suspension the offset is either 35 or 30? Guy I know has a good led on a set of used rims, but I am unable to test fit them do to driving distance to where they are and would like to know before I drive 3hrs if they are going to fit.
Callandor is offline   Reply With Quote
Old 01-02-2015, 06:50 AM   #2597
Kayshart
Would a 18x8.5 +47 rim fit: lowered 20mm, with -1.5 front camber, without rubbing and touching the springs?
Also, would you recommend 225/40/18 or 225/45/18 tyre?
Thanks for the advice!
Kayshart is offline   Reply With Quote
Old 01-04-2015, 02:09 PM   #2598
hotsaucepanda
Drives: Subaru BRZ
What width are these wheels?
Even with an 18x9 +35, you can fit a 245 on all corners easily. I am running that spec wheel with 255/35R18 currently with no rubbing and -2.2F/-2.0R camber on a 1" drop.
With a 2" drop, you should be okay with 245/35R18 with the proper camber settings.
Thank you. I decided to go with a different set up in the end.
hotsaucepanda is offline   Reply With Quote
Old 01-06-2015, 03:44 PM   #2599
Autocon
Autocon's Avatar
Drives: 2014 Whiteout FRS
17x9 rims on stock suspension with 225x40 all around. Will this have any rubbing issues upfront and will 225 on a 17x9 be ok to take to the track?
Autocon is offline   Reply With Quote
Old 01-06-2015, 04:25 PM   #2600
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
17x9 is probably the best size wheel for the track, IMO.
You could even run a 245/40R17 tire depending on the offset, but no issues at all with a 225/40.
You didn't mention your wheel offset.
You can run a +35 to +45 offset if stock but if you lower with springs then the +45 won't work without spacers. If you lower with coilovers, then no issues.
Slick is offline   Reply With Quote
The Following User Says Thank You to Slick For This Useful Post:
Autocon (01-06-2015)
Old 01-06-2015, 05:43 PM   #2601
Autocon
Autocon's Avatar
Thanks a ton for the info! Yeah the offset is +45 so thats good to know they will be fine on stock for now.
Old 01-07-2015, 04:48 AM   #2602
VakaGT
VakaGT's Avatar
Drives: None
Would 18x9.75 +20 fit in the rear!?
I have a feeling it won't but I really want to run staggered
18x8.75 +33 in front
And
18x9.75 +20 in rear
I'm about to buy in a few days, but if it'll rub. And cause issues I guess I'll get 8.75 +33 all around
Lowered on sportlines about 1.5 inches
Edit:
225/40/18 front
245/40/18 rear
I think
My Build Thread
Instagram: neel.vaka
VakaGT is offline   Reply With Quote
Old 01-07-2015, 03:18 PM   #2603
jaw_knee
Drives: 2014 Scion FR-S Raven
I'm considering the following square set up: 18x9 ET +33. I'm going to lower the car an 1" to 1.5" with some ST Coilovers, and will also be installing rear LCA and, if need be, front camber bolts. So my questions are:
1. Do you guys think 235/40/18 tire would be okay or should i do a 245/40?
2. Would i have to run an excessive negative camber to have a flush appearance?
Thanks
jaw_knee is offline   Reply With Quote
Old 01-07-2015, 04:53 PM   #2604
Defuser
Remember
Defuser's Avatar
Drives: 2015 Asphalt
I am putting 17 x 9 et 42 wheels (OZ Formula HLT) on, I have Eibach Pro springs on.
Questions:
Will I need spacers and/or camber bolts? I've read about 1.325 million posts regarding similar situations, but haven't found an answer.
What tire size would you guys recommend? Tire Rack recommends 245/40, but I'd rather hear from people who drive these cars.
Thanks in advance!
This is my 17th car. Most fun so far!
Defuser is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
