Old 03-13-2015, 04:22 PM   #2465
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Heading to Road Atlanta bump!
FT-86 SpeedFactory is offline
Old 03-13-2015, 06:23 PM   #2466
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
Originally Posted by nunonuna View Post
Any update yet??
Have been busy, it's not often I have a chance to drive 2 hours to go to the dyno.
Cartman is offline
Old 04-04-2015, 07:53 PM   #2467
Cartman
Cartman's Avatar
For those wondering how the car sounds after eliminating the cat
[ame="https://www.youtube.com/watch?v=FrwfZXEa9ww"]FT86SF uncatted UEL + Full exhaust drive - YouTube[/ame]
before:
[ame="https://www.youtube.com/watch?v=6RMwFg52Cq8"]FT86Speedfactory Catted UEL Header + full exhaust street run - YouTube[/ame]
Cartman is offline
The Following User Says Thank You to Cartman For This Useful Post:
chas3wba0 (04-06-2015)
Old 04-05-2015, 05:10 AM   #2468
Teclis
Marine Electrician
Teclis's Avatar
Drives: Toyota TRD86, 2014
What would it cost to get this thermal coated`?
Looks so damn awesome, If I weren't going to Japan for 3 weeks this year, i would already have put down my order for it.. But gotta wait until after the trip to see if I got any spare cash left.
Cheers from Norway
Teclis is offline
Old 04-09-2015, 01:40 PM   #2469
JaguarXJ6
JaguarXJ6's Avatar
Drives: 2015 GT-R, 1993.5 Supra, 1995 XJR
After ~10,200mi I received P0420 catalyst efficiency below threshold. I had merged onto the freeway still during warm up and not hot footing it around when it triggered. Cleared it, hope it doesn't come back. I suspect un-metered air getting in before the O2 it's always sounded slightly... off like there was a tiny exhaust leak since new.
2015 GT-R Pearl White with Ivory, Premium | Stock, DD
1995 Jaguar XJR | Turquoise Metallic | I6 4.0L | Eaton M90, 11psi | 4L80E | 1 of 12 of 400
1993.5 Supra Turbo | Baltic Blue | 6spd | 3.77 Torsen LSD | SP57 | RPS manifold | ViPEC V88 | 525/500rwhp/tq
JaguarXJ6 is offline
Old 04-09-2015, 04:02 PM   #2470
ryoma
ryoma's Avatar
before:
is it just me or does it sound better with the cat? without the cat is pretty raspy. did you eliminate all cats in your exhaust and is there a resonator?
ryoma is offline
Old 04-09-2015, 04:42 PM   #2471
JaguarXJ6
JaguarXJ6's Avatar
It can go either way, very subjective. I personally run with both cats (high flow though) specifically for no CEL, stinkiness, and sound.
Old 04-09-2015, 05:38 PM   #2472
Cartman
Cartman's Avatar
Only the header cat, still have high flow cat in fp... I preffer the catless sound, it sounds raspy, but at the same time its a bit louder, and the drone has been eliminated for me.
Cartman is offline
Old 04-11-2015, 06:56 PM   #2473
Trettiosjuan
Drives: GT86
(deleted to save space, quoted below and deemed unuseful by forum (p)resident)
Trettiosjuan is offline
Old 04-13-2015, 07:04 PM   #2474
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Turning off the light doesn't fix the issue here with this header. If you disable the light, this will cause you to not pass an inspection, correct?
Coheed is offline
Old 04-20-2015, 06:32 PM   #2475
Trettiosjuan
Drives: GT86
Originally Posted by Trettiosjuan View Post
Update from another user:
- For a long time I thought that this header made my car quieter, too much so, but it didn't make sense to me so I thought it was just in my head. Then I realised that running E85, which I've done consistently shortly after installing the headers, means lower EGT's which means quieter exhaust. All good, ordered a Tomei Ti catless front/test pipe from FT86SF and we'll see what that does with this header and the (quiet, like Q300?) catback.
It works, easier to get heat in it, this is how it sounds with the Tomei Titanium uncatted frontpipe and Milltek resonated catback:
The Following User Says Thank You to Trettiosjuan For This Useful Post:
sato (04-20-2015)
Old 04-21-2015, 12:03 PM   #2476
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
Once again, a catted header does not prevent the P0420 code. This is a high flow cat. You will most likely throw this code when you are highway cruising. The only way to get around this is to tune it out or delete the rear O2. This will cause you to fail inspection instantly on the evap system if it is turned off. This is why a tune is crucial to having a header. You can flash back to stock for inspection time, then flash right back to your tune when done. Complete waste of money if you bought this thinking it was a stock replacement on a stock tune and functioned the same way.
2016 Camaro SS is offline
The Following User Says Thank You to 2016 Camaro SS For This Useful Post:
Teseo (04-21-2015)
Old 04-21-2015, 06:50 PM   #2477
kodyo
Drives: Scion FR-S
Except it will run on a stock tune without issues. I ran mine for 4.5 months/7600 miles without a single CEL and factory tune. That includes ~8x 3+ hour car trips of nothing but highway cruising. Once I installed OFT Stage 1 tune, that's when it started to throw a CEL (which I tuned out).
kodyo is offline
The Following User Says Thank You to kodyo For This Useful Post:
Teclis (05-10-2015)
Old 04-22-2015, 06:48 AM   #2478
Trettiosjuan
Drives: GT86
Are there any numbers on the flow rating of the original vs. this one?
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 11:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 01:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 01:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 01:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 11:12 PM
