#2465 |
Heading to Road Atlanta bump!
#2466 |
Drives: 10 Series Scion FR-S
#2467 |
For those wondering how the car sounds after eliminating the cat
[ame="https://www.youtube.com/watch?v=FrwfZXEa9ww"]FT86SF uncatted UEL + Full exhaust drive - YouTube[/ame] before: [ame="https://www.youtube.com/watch?v=6RMwFg52Cq8"]FT86Speedfactory Catted UEL Header + full exhaust street run - YouTube[/ame] |
| The Following User Says Thank You to Cartman For This Useful Post: | chas3wba0 (04-06-2015) |
#2468 |
Marine Electrician
Drives: Toyota TRD86, 2014
What would it cost to get this thermal coated`?
Looks so damn awesome, If I weren't going to Japan for 3 weeks this year, i would already have put down my order for it.. But gotta wait until after the trip to see if I got any spare cash left. Cheers from Norway
My Toyota TRD86 can be found here:
http://www.ft86club.com/forums/showthread.php?t=63303 |
#2469 |
Drives: 2015 GT-R, 1993.5 Supra, 1995 XJR
After ~10,200mi I received P0420 catalyst efficiency below threshold. I had merged onto the freeway still during warm up and not hot footing it around when it triggered. Cleared it, hope it doesn't come back. I suspect un-metered air getting in before the O2 it's always sounded slightly... off like there was a tiny exhaust leak since new.
2015 GT-R Pearl White with Ivory, Premium | Stock, DD 1995 Jaguar XJR | Turquoise Metallic | I6 4.0L | Eaton M90, 11psi | 4L80E | 1 of 12 of 400 1993.5 Supra Turbo | Baltic Blue | 6spd | 3.77 Torsen LSD | SP57 | RPS manifold | ViPEC V88 | 525/500rwhp/tq |
#2470 |
is it just me or does it sound better with the cat? without the cat is pretty raspy. did you eliminate all cats in your exhaust and is there a resonator?
#2471 |
It can go either way, very subjective. I personally run with both cats (high flow though) specifically for no CEL, stinkiness, and sound.
#2472 |
Only the header cat, still have high flow cat in fp... I preffer the catless sound, it sounds raspy, but at the same time its a bit louder, and the drone has been eliminated for me.
#2473 |
Drives: GT86
(deleted to save space, quoted below and deemed unuseful by forum (p)resident)
#2474 |
Drives: DGM BRZ Limited
Turning off the light doesn't fix the issue here with this header. If you disable the light, this will cause you to not pass an inspection, correct?
#2475 | |
Drives: GT86
| The Following User Says Thank You to Trettiosjuan For This Useful Post: | sato (04-20-2015) |
#2476 |
Drives: Fast
Once again, a catted header does not prevent the P0420 code. This is a high flow cat. You will most likely throw this code when you are highway cruising. The only way to get around this is to tune it out or delete the rear O2. This will cause you to fail inspection instantly on the evap system if it is turned off. This is why a tune is crucial to having a header. You can flash back to stock for inspection time, then flash right back to your tune when done. Complete waste of money if you bought this thinking it was a stock replacement on a stock tune and functioned the same way.
| The Following User Says Thank You to 2016 Camaro SS For This Useful Post: | Teseo (04-21-2015) |
#2477 | |
Drives: Scion FR-S
| The Following User Says Thank You to kodyo For This Useful Post: | Teclis (05-10-2015) |
#2478 |
Drives: GT86
| Tags |
| catted uel header, ft86speedfactory header, is my order ready yet? |
| Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 107 | 03-29-2016 10:48 AM |
| catted header or catted front pipe? | gabeg86 | Engine, Exhaust, Transmission | 28 | 10-13-2015 12:32 PM |
| P&l EL catted and coated header. | wootwoot | Engine, Exhaust, Bolt-Ons | 8 | 10-11-2013 12:50 AM |
| Catted UEL Header | Cjymiller | Engine, Exhaust, Transmission | 20 | 05-24-2013 12:01 PM |
| ***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE | FT-86 SpeedFactory | Engine, Exhaust, Bolt-Ons | 12 | 10-24-2012 10:12 PM |
