Old 01-26-2014, 06:19 PM   #225
steve99
Originally Posted by Liquid6 View Post
i added the old stage 1 beta tune i got awhile ago from you guys that let me flash it back to stock
Just guessing here , but oft is working on old format tune files where you download rhe complete tune file as you flashed back to stock with old beta version ?
But it does not work ,write greyed out on latest database .dev format 1.5 tunes. ?
This is likely to bex either you ROM is not in the database or your stock rom is not 100% stock ,has any othe tuning device been used eg tactrix or ecuteck as it may have changed stock rom with licence info ?
Old 01-26-2014, 06:30 PM   #226
Liquid6
Liquid6's Avatar
Drives: 2014 FR-S
i dont understand your first question
yes the read/write is grayed out on latest .dev 1.5
i only flashed it once since i received the oft, no other tuning device has been used. its just a little off putting when i would like to use oft for 2nd time since i bought it it doesn't work. i know this is a new device to tune this car with so theres going to be some hiccups.
i don't really know a lot about tuning which is reason i went with oft for the plug and play aspect, but i can't seem to get playing.
Liquid6 is offline   Reply With Quote
Old 01-26-2014, 06:49 PM   #227
steve99
The 1.5 version tunes are released in a different format to all the other previous tunes, the same thing happened to me
I could flash all the old format tunes 1.3 1.4 ect just not the new 1.5 database format tunes.
The old tunes you get the complete ROM files so I believe the OFT just checks the calid(ROM Type) and if it matches sweet it will flash the ROM.
on 1.5 version tunes the OFT actually builds the tunes (add changes only to stock ROM) so the OFT has to be very sure the ROM in your car matches the stock ROM exactly so I suspect it checks checksums in your ROM as well as the CAL-ID against its database of supposedly stock ROM's.
It possible that Shiv had been given a za1jbooc ROM ie your ROM type that is not 100% stock (this happened to me on G01 series ROM) once Shiv replaced the ROM in his database with my 100% stock one all good.
If you can flash older tunes just not the 1.5 tunes then I am pretty sure this will be the problem.
note you have to manually delete the old format tunes from the oft before you load the new database format tunes.
you will need to email shiv a copy of your stock rom from the OFT so he can check it and add it to the database.
Liquid6 (01-26-2014)
Old 01-26-2014, 06:57 PM   #228
Liquid6
Liquid6's Avatar
Drives: 2014 FR-S
The 1.5 version tunes are released in a different format to all the other precious tunes, the same thing happened to me
ok sounds good how do i email my rom? where do i get from i.e. where am i looking and what should i look for.
thanks for your help @steve99
Old 01-26-2014, 07:03 PM   #229
steve99
When you first got your oft first step was to read stock rom, your stock rom will be stored in OFT.
Fire up the openflash manager software on your computer attach OFT and use the "download" option to download the stock rom (will be in slot 1) to your computer.
Its worth saving a copy of you stock ROM outside the OFT as insurance if the OFT should fail .
Old 01-26-2014, 07:05 PM   #230
Liquid6
Liquid6's Avatar
Drives: 2014 FR-S
ok dumb me
thanks again
Old 01-27-2014, 06:23 PM   #231
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
Another of my Stage 1 data logs...
Done on 1.53b, 155 miles after flash, 91 oct, header back + intake mod.
All instances of WOT were in 3rd gear.
Comments appreciated as always.
http://www.datazap.me/u/danklvr/153b...2-7-8-10-11-12
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
Old 01-27-2014, 07:22 PM   #232
jflogerzi
jflogerzi's Avatar
@shiv@vishnu
I got my OFT today. Downloaded the newest beta .dev file. Uploaded it to the OFT. But when I got to read my ECU, it can't probably read it/match it due to unique ecutek info in the ecu. What are the steps? I flashed to a stock rom provided to me by my tuner.
Old 01-27-2014, 07:41 PM   #233
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Shiv can fix that, send him an email
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 01-27-2014, 08:05 PM   #234
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by jflogerzi View Post
@shiv@vishnu
Yes, just email me your original file (Ecutek stock tune read by the OFT). shiv@vishnutuning.com
Old 01-27-2014, 08:05 PM   #235
jflogerzi
jflogerzi's Avatar
It wont read the ecu.
Sent from my SGH-T999 using Tapatalk
2013 Series 10 FRS #553
Old 01-27-2014, 08:13 PM   #236
Shiv@Openflash
Drives: 2013 FRS
Then you either didn't get a stock rom file from your ecutek tuner or ignition power isn't on. Are you able to communicate at all with the ecu? Can u see "ecu info" information?
Old 01-27-2014, 08:15 PM   #237
jflogerzi
jflogerzi's Avatar
I got it. Will send you the file in a bit
Old 01-27-2014, 08:16 PM   #238
Liquid6
Liquid6's Avatar
Drives: 2014 FR-S
just Sent my stock rom to you @shiv@vishnu. Let me know what you think.
Thanks for the help
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 01:29 AM
OpenFlash Tablet: OFT 3-Touch Programming with Preloaded Tune File Database Shiv@Openflash Software Tuning 154 12-12-2015 04:26 PM
OpenFlash Tablet E85 (and gasoline) Maps now available Shiv@Openflash Software Tuning 401 08-14-2014 12:14 AM
OpenFlash Tablet: new v1.40b maps, new website, new sales, oh my Shiv@Openflash Software Tuning 122 12-14-2013 11:17 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 09:45 PM
