#211 | |
Sent from my SGH-T999 using Tapatalk
2013 Series 10 FRS #553
#212 | |
If its an Ecutek "stock" rom the tuning parameters are returned to stock specifications but their is a small "signature or license info" in the ROM presumably for ecutek to detect that its had an ecutek tune or license info ect. Hence the ROM provided is not 100% the same as stock if you look with a HEX editor, but will perform in the car as a "stock" ROM. This signature/licience info is put in an area unused by the stock ECU but presumably it looked for by Ecutek software however this extra info is enough for the OFT not to recognise its as a "stock" rom, so shiv will need to add it to the database, I believe they are working on a "stock" rom overwrite/upgrade feature to be released soon Last edited by steve99; 01-25-2014 at 08:27 PM. |
| The Following User Says Thank You to steve99 For This Useful Post: | Shiv@Openflash (01-25-2014) |
#213 |
Just for something different decided to do some economy runs on the new 1.53 tunes to and from work. Pretty flat run no highway light traffic Can average around 6.5 l/100km too work and 7 on the way home diving like a "nun" on stock ROM (no offence to nun's intended) With 1.5x tune it was actually better by about 0.5 litres per 100km. both ways ie 6 and 6.5 l/100km Attribute that to better low down torque so can pull higher gear I have manual was pretty hot too 100F day. http://datazap.me/u/steve99/easy-run...k?log=0&data=1 |
| The Following User Says Thank You to steve99 For This Useful Post: | Shiv@Openflash (01-26-2014) |
#214 |
Drives: 86
Dear @shiv@vishnu
Is the 700K ROM going to be available soon as it is not availabe in 1.42 version. Thank you
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
#215 | |
Drives: Toyota Gt86
Will you revise the stage 2 EL maps in some way, so that who bought these kind of headers will at least take advantages of these add-on? I know you sell OFH and it's UEL etc. but I think a good chunk of ppl that use or will use OFT will buy nameless/jdl v2 EL header as well. Did you think about it? |
| The Following User Says Thank You to Victor Draken For This Useful Post: | 8686 (01-26-2014) |
#216 | |
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
- AdrianG |
#217 | |
Drives: 2015 WRX
#218 |
Drives: 2013 Scion FR-S Raven
I'm running a FA20club.com Equal Length Header with OFT v1.54 Stage 2 successfully, FA20club.com EL header is catted as well, going to remedy that soon with an uncatted header pipe from FA20club.com
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#219 | |
Drives: Toyota Gt86
Unless i read it wrongly I would say that the map Is not really extracting the advantage of very good headers like NP/JDL/HKS. The UEL map are much more refined in my opinion compared to EL one. If I'm wrong shiv will of course explain it. By the way what happened at shiv vendor tag? |
#220 | |
Drives: 2015 WRX
As for his vendor tag being removed, the same thing happened a couple weeks ago. Its most likely a forum bug. |
| The Following User Says Thank You to Malt For This Useful Post: | Victor Draken (01-26-2014) |
#221 |
Drives: 2014 FR-S
unable to get read/ write to work. cal id za1jbooc. flashed it back to stock erased oft and uninstalled ofm and reinstalled everything and tried again still no go. any ideas anyone?
#222 |
Drives: 2013 FRS
How can you flash it back to stock if read/write doesn't work. Not sure I follow. But I can probably help you with more info.
#223 |
Drives: 2014 FR-S
#224 |
Drives: 2014 FR-S
any ideas yet @shiv@vishnu?
| OpenFlash Tablet v1.42b maps now available | Shiv@Openflash | Software Tuning | 159 | 09-13-2016 12:29 AM |
| OpenFlash Tablet: OFT 3-Touch Programming with Preloaded Tune File Database | Shiv@Openflash | Software Tuning | 154 | 12-12-2015 03:26 PM |
| OpenFlash Tablet E85 (and gasoline) Maps now available | Shiv@Openflash | Software Tuning | 401 | 08-13-2014 11:14 PM |
| OpenFlash Tablet: new v1.40b maps, new website, new sales, oh my | Shiv@Openflash | Software Tuning | 122 | 12-14-2013 10:17 PM |
| OpenFlash Tablet Stage 1 v1.2 maps available for download | Shiv@Openflash | Software Tuning | 31 | 10-31-2013 08:45 PM |
