Old 01-17-2014, 03:28 PM   #211
that_guy
Dances with Cones
that_guy's Avatar
Drives: 2013 Scion FR-S Raven
Originally Posted by kbye View Post
I don't think it requires too much of a re-design, is it not already plug and play? The issue is that the pipe bends on the forester instead of straight on the brz, no? Would it be possible to just cut it up and re-weld it back on straight?
Don't think you should weld metal this thin (I could be wrong though). Considering it's just bent pipe with some soldered tabs, you'd think someone should be able to make an "OE" kit out of this with a fabbed up pipe replacement.
Anyone have any guesses of suppliers here that might be up for the task?
2013 Scion FR-S - Raven
2011 Scion tC - Cement - SOLD
that_guy is offline   Reply With Quote
Old 01-17-2014, 04:01 PM   #212
kbye
kbye's Avatar
Drives: 2014 FR-S
I suspect the pipe metal is not that thin, otherwise you run the risk of the pipe bending. In fact the mounting tabs you mentioned are welded on and not soldered. Soldering on pipes is usually to seal up a joint to prevent leaks, not to mount or attach metal.
I guess I'll just buy the part and try it out myself however I do agree that I would like to see a shop make a better fitting one for us.
kbye is offline   Reply With Quote
Old 01-17-2014, 05:44 PM   #213
CARNZ
CHECK ENGINE
Drives: 2004 STi
Those water pipes are now off backorder and there are some available in the warehouses. (14050AA970) 3 Available as of 1-17-14
i don't cry about crickets
CARNZ is offline   Reply With Quote
Old 01-20-2014, 01:13 PM   #214
that_guy
Dances with Cones
that_guy's Avatar
I'm curious but does anyone know if the Forester XT oil cooler has a predefined "inlet" and outlet" that must be used in accordance with the coolant flow in this car? According to the Toyota EPC, the factory transmission cooler found on the automatic versions of this car change the lower hardline and introduce a coolant neck at the top, rear of the block for plumbing to the transmission cooler. I'm wondering if these lines could be leveraged to run the oil cooler on manual transmission cars? I wonder if that's how the STI Concept is plumbed as it seems there are no lines running across the front of the block.
I also noted a themostat equipped in the same coolant neck used for the transmission cooler. Would this be needed/beneficial to install?
Also, does anyone know what oil cooler the STI Concept is using? It's not the same as the Forester unit despite having the same tray at the top, evident on new Subaru top mount OE oil coolers. Is there another car that employs this same option?
Old 01-25-2014, 11:15 AM   #215
that_guy
Dances with Cones
that_guy's Avatar
Originally Posted by normancw View Post
FYI, the parts for the T-adapter version (by @xxscaxx) are in stock in Canada - I ordered last Thursday and picked them up today (shipped from Toronto).
Awesome!
Do you have an oil temp gauge? Please post results of the installation and temps if you can.
Old 02-03-2014, 04:11 PM   #216
gbrz
is there a torque spec for the fitting that goes into the block?
gbrz is offline   Reply With Quote
Old 02-03-2014, 04:14 PM   #217
Trac Toy
Trac Toy's Avatar
Thread sealant, and tight.
.o0+Eric+0o.
2016 Chrysler 200S 3.6
2013 FRS 6MT
Trac Toy is offline   Reply With Quote
Old 02-06-2014, 01:06 AM   #218
Sniper2606
Sniper2606's Avatar
I would love to do this since i have the Vortech sc kit, but im too big of a *****,after reading everything here im just confused beyond believe, would love to see a video install
Sniper2606 is offline   Reply With Quote
Old 02-06-2014, 01:08 AM   #219
Trac Toy
Trac Toy's Avatar
I ordered everything from the first page, and it all went together as described. Needed 2 jugs of coolant to refill the system and fooled around withe the heater hose at the firewall until I was happy, but otherwise a very simple install.
.o0+Eric+0o.
2013 FRS 6MT
Old 02-06-2014, 07:51 AM   #220
CARNZ
CHECK ENGINE
Drives: 2004 STi
all you have to do is follow the first post. it's been on my car with no issues since the original posting.
others were concerned with the hose routing or splicing into existing lines instead of buying pieces, but the original way works!
Old 02-06-2014, 09:29 AM   #221
xxscaxx
Drives: 2013 SWP BRZ
No issues here either, and I think I was the first to splice into an existing line. No leaks.
xxscaxx is offline   Reply With Quote
Old 02-06-2014, 12:19 PM   #222
djdnz
1337
Drives: 2013 BRZ WRB S/C
I better get another jug of coolant. Where did you get your heater hose? I couldn't find 3/8" hose at Canadian Tire.
Car Quest Auto Parts is a great source for heater hose.
NAPA, Advance Auto Parts as well are options.
djdnz is offline   Reply With Quote
Old 02-07-2014, 06:59 AM   #223
Trac Toy
Trac Toy's Avatar
I have a hose box, it ha everything I needed. Just odds and ends that I've had over the years.
.o0+Eric+0o.
2013 FRS 6MT
Old 02-15-2014, 02:15 AM   #224
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Weird...
My heater hose pipe is part number 14050AB090 but is otherwise identical to what everyone else has.
I'll be installing tomorrow but wanted to document this for comparison.
-alex
brz, fxt, oil, oil cooler
OEM Oil cooler from the 2.0 DIT Forester Kostamojen Engine, Exhaust, Transmission 119 09-10-2019 05:28 AM
Bought a 2014 Subaru Forester EAGLE5 Other Vehicles & General Automotive Discussions 10 10-02-2013 12:54 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
BRZ 2.0L Turbo in 2014 Forester Sleeperz BRZ First-Gen (2012+) — General Topics 37 03-21-2013 06:42 PM
Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… 2013GTRNate BRZ First-Gen (2012+) — General Topics 12 02-01-2013 12:29 PM
