#2199 | |
1. Just put the springs on and get an alignment. 2. Do the springs and the factory camber bolt for the front. It's less than 10 bucks if I recall and will let you get a little more camber up front without making your tires faster. 3. Do the springs, camber bolt, and rear lower control arms (LCAs). This will help everything be "perfect." You'd be just fine with option 1 but at the very least I'd recommend option 2. The bolt is dirt cheap and makes a nice difference in handling. Adding the rear lower control arms in option 3 helps you get rid of a little rear negative camber and make sure everything is nice and even. But it's not 100% necessary. Most vendors that sell our parts should be able to help you out with the above options. We provide alignment recommendations as well so you won't be lost. ![]() - Andy |
#2200 | |
Measure the length of the spring and go from there. If the numbers mean something, they are most likely 6/7inch springs and 8.5/7kg rate. |
#2201 |
Drives: 86 GTS
@Racecomp Engineering @CSG_mike I've now got B6 with STI Pink springs, Raceseng Camber Tops, LCAs, -2 camber front, -1 rear, 0 toe all the way round Whiteline diff and outrigger bushings. Track 2xmonth, canyon carving/fast road 1 week, what bushings would you recommend for that final tighten up?
#2202 | |
Drives: 2017 Cayman S
Thanks Andy. I will go with option 2.
![]() Do you have any vendors in Maryland I can pick up the springs from locally? Can you recommend any local shops (PM if necessary). I think i found your alignment recommendations. Quote:
… and loving it! Maxwell Smart
. Gone but not forgotten 2014 BRZ Limited - 2013 VW Golf R - 2010 Forester XT - 2006 Mazda 3 GT |
#2203 | |
Ft86speedfactory isn't in MD but should have some in stock and then you won't have to pay tax. ![]() - Andy |
#2204 |
Did two "back road" sessions to get tires heated up and from both sessions, the front right tire was 4.0-4.5 degrees F hotter than the other corners.
What us your take on this result?
2013 Asphalt / MT
Olympia, Washington |
#2205 | |
Drives: 2013 Cayenne turbo
The idea behind tire temps is to see if the tire is a consistent temperature across the tread. If it is hot in the center, you have too much pressure. If it is hot on the outer shoulder, you need more negative camber and/or less toe-in. I should have been more specific I guess. It is worth a google for "race tire temperature adjustment" or some such thing to get more details.
Chris
Track, Autocross & Daily Driver build thread - SOLD Another A&DD for my VW GTI - SOLD And finally, my YouTube channel |
#2206 | |
2013 Asphalt / MT
#2207 |
Drives: 86 GTS
Thoughts on this alignment?
#2208 |
Drives: 86 GTS
Whoops, should have said, Raceseng Camber tops, Rear LCAs, STI Pink springs and B6s
#2209 | |
Drives: 2004 Toyota RAV-4 5M
#2210 |
It's not a lot of rear camber (yes I realize that's degrees minutes). With -3 up front you might be lacking in rear grip. Might be okay for auto-x and it might be a heck of a lot of fun. But for the track I'd add some rear camber.
- Andy |
#2211 | |
- Andy |
#2212 | |
Drives: 86 GTS
Cool will dial in another degree - got some new rack bushes to go in, so will need to align after that, The rear is a little more skittish with the current settings. Thanks for the advice. |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
