Old 12-01-2014, 12:59 PM   #2199
Racecomp Engineering
Originally Posted by Agent 86 View Post
I have a question that's probably been asked somewhere in these 100 pages…
I have a 2014 BRZ that I have had for a little over 2 months now. I don't race or autocross, but I do enjoy and appreciate having a car that is responsive and handles well with a reasonable level of ride comfort.
The factory setup meets my needs, but I would like to lower my car a little (for looks) and install a better looking set of wheels (17" or 18").
What can you recommend for my situation? There must be a simple path I can take.
I was considering the RCE Yellow springs, but then I see discussion about adjusting camber, installing crash bolts, bushings and lower control arms and i become paralyzed.
Please provide some suggestions.
3 ways to go:
1. Just put the springs on and get an alignment.
2. Do the springs and the factory camber bolt for the front. It's less than 10 bucks if I recall and will let you get a little more camber up front without making your tires faster.
3. Do the springs, camber bolt, and rear lower control arms (LCAs). This will help everything be "perfect."
You'd be just fine with option 1 but at the very least I'd recommend option 2. The bolt is dirt cheap and makes a nice difference in handling. Adding the rear lower control arms in option 3 helps you get rid of a little rear negative camber and make sure everything is nice and even. But it's not 100% necessary.
Most vendors that sell our parts should be able to help you out with the above options. We provide alignment recommendations as well so you won't be lost.
- Andy
Agent 86 (12-01-2014), fstlane (12-01-2014)
Old 12-01-2014, 01:20 PM   #2200
swarb
Originally Posted by evil_1998 View Post
Hi, I have a set of coilovers but unsure of spring rate.
On the springs they are marked:
160-8.5 (front)
180-07 (rear)
Can someone please tell me the spring rate in kg's?
Thanks
The numbers could just be part numbers. Brand?
Measure the length of the spring and go from there. If the numbers mean something, they are most likely 6/7inch springs and 8.5/7kg rate.
The Following User Says Thank You to swarb For This Useful Post:
evil_1998 (12-01-2014)
Old 12-01-2014, 03:11 PM   #2201
Panman
Panman's Avatar
Drives: 86 GTS
@Racecomp Engineering @CSG_mike I've now got B6 with STI Pink springs, Raceseng Camber Tops, LCAs, -2 camber front, -1 rear, 0 toe all the way round Whiteline diff and outrigger bushings. Track 2xmonth, canyon carving/fast road 1 week, what bushings would you recommend for that final tighten up?
Panman is offline   Reply With Quote
Old 12-01-2014, 03:23 PM   #2202
Agent 86
Drives: 2017 Cayman S
Thanks Andy. I will go with option 2.
Do you have any vendors in Maryland I can pick up the springs from locally? Can you recommend any local shops (PM if necessary). I think i found your alignment recommendations.
3 ways to go:
- Andy
… and loving it! Maxwell Smart
Gone but not forgotten
2014 BRZ Limited - 2013 VW Golf R - 2010 Forester XT - 2006 Mazda 3 GT
Agent 86 is offline   Reply With Quote
Old 12-01-2014, 03:40 PM   #2203
Unfortunately we are out of stock.
Ft86speedfactory isn't in MD but should have some in stock and then you won't have to pay tax.
- Andy
Old 12-08-2014, 12:17 AM   #2204
PNW FRS
PNW FRS's Avatar
Did two "back road" sessions to get tires heated up and from both sessions, the front right tire was 4.0-4.5 degrees F hotter than the other corners.
What us your take on this result?
Originally Posted by bimmer635csi View Post
Tire temps will tell you what you need. Invest in a simple pyrometer to get started. You don't need one with ultra-2000-memories, just a simple instantaneous temp reader and write it down on a sheet of paper. Analyze the temps, then adjust as needed.
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
Old 12-08-2014, 08:54 AM   #2205
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
You were on a counter-clockwise course.
The idea behind tire temps is to see if the tire is a consistent temperature across the tread. If it is hot in the center, you have too much pressure. If it is hot on the outer shoulder, you need more negative camber and/or less toe-in.
I should have been more specific I guess. It is worth a google for "race tire temperature adjustment" or some such thing to get more details.
bimmer635csi is offline   Reply With Quote
The Following 2 Users Say Thank You to bimmer635csi For This Useful Post:
MyRx (12-09-2014), Racecomp Engineering (12-08-2014)
Old 12-08-2014, 06:47 PM   #2206
PNW FRS
PNW FRS's Avatar
Ahhh... OK.. across the tread... will see what I can determine the next time I do a test. I did do some reading on "the net" about temp differentials... so with all this in mind.. I should be able to get a sense of what might need to be further fine-tuned. Thx!!
2013 Asphalt / MT
Olympia, Washington
Old 12-09-2014, 08:01 PM   #2207
Panman
Panman's Avatar
Drives: 86 GTS
Thoughts on this alignment?
Old 12-09-2014, 08:04 PM   #2208
Panman
Panman's Avatar
Drives: 86 GTS
Whoops, should have said, Raceseng Camber tops, Rear LCAs, STI Pink springs and B6s
Old 12-16-2014, 11:20 PM   #2209
ja1217
Drives: 2004 Toyota RAV-4 5M
Yes, 2.5 is good.
With those rates I would probably go with 7 inch springs BUT you may want to check the amount of bump travel in your shocks and then look up the specs on the springs to see if they have at least that much.
The Ohlins are a little tricky since they can't lower the car much.
- Andy
So my revalved dampers should be coming back later this week and I've gotten my 7 inch Hyperco springs already. My next question is how exactly should I install these springs? The 7" springs are about 0.8" shorter than the 200mm springs that they are replacing. I assume I want to adjust the spring preload so that the springs are snug when the dampers aren't compressed at all and then adjust the ride height separately.
ja1217 is offline   Reply With Quote
Old 12-17-2014, 10:02 AM   #2210
It's not a lot of rear camber (yes I realize that's degrees minutes). With -3 up front you might be lacking in rear grip. Might be okay for auto-x and it might be a heck of a lot of fun. But for the track I'd add some rear camber.
- Andy
Panman (12-17-2014)
Old 12-17-2014, 10:08 AM   #2211
Look at the specs on the spring via Hyperco's website and make sure they're total available travel is more than the amount of bump travel that you end up with (so that the spring doesn't fully bind before the shock). You'll probably be okay just going with minimal preload but it's good to check. It may take some trial and error.
- Andy
Old 12-17-2014, 08:53 PM   #2212
Panman
Panman's Avatar
Drives: 86 GTS
- Andy
Cool will dial in another degree - got some new rack bushes to go in, so will need to align after that, The rear is a little more skittish with the current settings. Thanks for the advice.
The Following User Says Thank You to Panman For This Useful Post:
Racecomp Engineering (12-18-2014)
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
