Oxyg3n
Old 04-02-2019, 08:03 PM   #183
nitro_alltrac
nitro_alltrac's Avatar
Drives: '17 86
Dropped mine off along with a copy of the TSB at 4 PM yesterday. By 5:30 they had called to tell me that they were going to do the clearance check and reshim if necessary as per the bulletin. It will probably be week to a week and a half depending on if they have to order parts and how long it takes to get them. We'll see how this goes.
nitro_alltrac is offline   Reply With Quote
Old 04-02-2019, 09:21 PM   #184
funpolice
Drives: 2017 brz sportech
Originally Posted by Larphraulen View Post
Just got my car back. The engine note has a noticeably more "rattle in a tin can" type sound to it now but no lights, no misfires, seems to drive ok so I'll take it.
you are brave!
please keep us updated how it goes in the longer run.
i probably have to bring it in this summer. but it took 22 days?
does your car idle fine(vibrates less/less noisy)
funpolice is offline   Reply With Quote
Old 04-02-2019, 10:13 PM   #185
Larphraulen
Drives: 2018 Subaru BRZ 6m; 2012 VW GLI 6m
Originally Posted by funpolice View Post
you are brave!
Well! Looks like I jinxed it.
Coming back home from dinner. 5 degrees Celsius so not really cold; engine was warm. Not only a CEL again but also a traction off light at the same time. I didn't press anything and was moving at the time. Back she goes!
It didn't seem to idle weird though in terms of vibration FWIW.
Larphraulen is offline   Reply With Quote
Old 04-03-2019, 07:48 AM   #186
nitro_alltrac
Drives: '17 86
I've had zero issues other than the light. I had been putting this off but throwing codes three separate times in less than a week led me to believe that something was getting worse. I post my on going results once I get the car back.
Old 04-03-2019, 08:02 AM   #187
chipmunk
Drives: _
O'Reilly and other auto stores do scan the OBD2 for free (at least here in Midwest). Or take it to a Subaru dealer, since it's under 5yr/60k mile warranty.
A catback should not void the warranty.
chipmunk is offline   Reply With Quote
Old 04-04-2019, 05:45 PM   #188
funpolice
do we all agree it's only the 6 speed specific issue?
my cel went away yesterday. came back today. each time it happens, i noticed the temperature changes and the humidity changes. and each time when it happens, it's during idle and the idle gets rough a few times then the light comes on
The Following User Says Thank You to funpolice For This Useful Post:
Larphraulen (04-04-2019)
Old 04-04-2019, 05:57 PM   #189
funpolice
you didn't have the ecm reflashed, maybe that's what's missing.
Old 04-04-2019, 06:38 PM   #190
Larphraulen
Good call! Just dropped it off. Dealer told me they just received the TSB the day after I picked it up before. Plan is to reflash ECM.
Sent from my Z978 using Tapatalk
Old 04-04-2019, 07:53 PM   #191
funpolice
same here. i don't think my car has any performance issue even with the cel on. but it's just annoying and not knowing if this damages the car in the long run
Old 04-04-2019, 07:54 PM   #192
funpolice
best of luck, i think we all want your case to be a success case!
Old 04-05-2019, 03:39 PM   #193
Thedishdoc
Drives: 2015 Scion FRS
Originally Posted by Oxyg3n View Post
Well my OBDII scanner is coming in tomorrow.. But in the meantime I was thinking that although theoretically the catback exhaust itself has no sensor on it, is there still a possibility to get a CEL from changing it out?
No.
2015 Red FRS
Enkie LC5 18" Rims/Michelin 225-45 18 Super Sports
Perrin resonated catback exhaust
FT86 UEL catted header
Stage 2 OFT tune
Thedishdoc is offline   Reply With Quote
Old 04-05-2019, 06:30 PM   #194
nitro_alltrac
Drives: '17 86
I got the car back this evening. Took about 4 days, mostly waiting for the parts to coming in. They had to replace one shim and they did the reflash. On the drive home everything seems fine. I'll run it more this weekend and see how it doing. Right now though, so far so good. Car is running fine and no CEL.
The Following User Says Thank You to nitro_alltrac For This Useful Post:
Larphraulen (04-05-2019)
Old 04-05-2019, 06:48 PM   #195
Scourge
Agent 86
Drives: 2017 Toyota 86
Hopefully the reflash fixes everything but that tin can sound you mentioned earlier is really worrisome... :o
Scourge is offline   Reply With Quote
Old 04-05-2019, 09:28 PM   #196
funpolice
it'll take at least a month to confirm if it's a true fix. cuz if i remember correctly, the longest time the cel was off on my car was probably between 3-4 weeks. it's been 2 years since i bought my 2017 brz and subaru just came up with the 1st more promising attempt fix. they had similar issue with the 1st gen brz/frs and they put in a software fix on the ecm. i waited all these year to avoid the 1st gen brz (or any car 1st gen) and it still got the same problem... sigh...
Help! From check engine light to fouled plugs back to check engine + plugs refouling larchamb Issues | Warranty | Recalls / TSB 44 04-03-2016 09:39 AM
Engine Check light, Traction Control light, cruise control light all on suddenly wqc3241 Software Tuning 2 01-10-2016 07:37 AM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 06:06 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
