#1877 | |
Drives: GR86 / Supra MK5 MT / MR-S / Z4
Front: -2mm Rear: -14.7mm The - means that it will be more inside the wheel arches Hope this helps
My GR86 Car Journal: https://www.ft86club.com/forums/showthread.php?t=153879 My old GT86 Car Journal: http://www.ft86club.com/forums/showthread.php?t=22222 |
| The Following User Says Thank You to Killerbee For This Useful Post: | OICU812 (10-21-2013) |
#1878 |
Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
I am scrapping my previous plans for wheels upon further analysis; I will be lowering by ~1.4" with the Eibach sportlines and plan to use Enkei RPF1 17x8" +35 offset with 235/40r17 radials and using 3mm spacers in the front and 9 or 10mm in the rear (the largest I can use and still be safe). I plan on -2° camber rear and -1° camber in the front. Using the fitment calc that is posted in the other thread it appears that will be close to flush and wouldn't have issues rubbing (rubbing seems to be more likely with wider wheels), but if the experts could weigh in I would greatly appreciate it. Lowering the car and setting the camber will be done prior to the wheels so there will be some time where I will be using the 17x7" w/ 215/45r17 oem setup; I have no illusions of that being any kind of flush. I am more interested in getting ready for the end goal. Thanks in advance!
#1879 | |
Just a dude
Drives: Scion FR-S 2013
Ok not terrible then just perhaps some 5-10mm spacers in back if want same look. Hmmm I'll need to see some with close specs in person I suppose if can first. Thanks kindly.
| The Following User Says Thank You to OICU812 For This Useful Post: | Killerbee (10-21-2013) |
#1880 |
Just a dude
Ok so I'd like someone to clear up the math here
Example 17 x 8.0 in (45) offset 17 x 8.5 in (45) offset Which is more "tucked in" and by how much, what's the simple math here? Many thanks I'm trying to understand this.
#1881 | |
Short story: The 17x8.0 will be 0.25" or 6mm more tucked in than 17x8.5
| The Following User Says Thank You to Killerbee For This Useful Post: | OICU812 (10-22-2013) |
#1882 | |
Just a dude
Ok so reality is a 38-39 in a 8.5" would be absolute optimum but yet non existent in wheels I want. Seems the latest wheels are "not" with being lowered in mind.. Thanks so much for all your help bee, I am slowly understanding lol.
| The Following User Says Thank You to OICU812 For This Useful Post: | Killerbee (10-22-2013) |
#1883 | |
In your case, you may always go for some spacers to compensate for the offset (a 5mm spacer will get the +45 to a +40) but there are drawbacks with the spacers aswell, so this is basically just advisable if its purely about cosmetics. And you're welcome, always happy to help out.
#1884 |
Just a dude
Well this really has me thinking. Now I'm looking at a 18x8.0 (38) offset. Being 1-1.250" lowered and -1.5 camber all around I think will for pretty good. Looking at Advan T5s now which well..no one has had on this car yet.
#1885 |
Just a dude
Well T5s have been discontinued just when I was settled
!!Now looking at Advan RGD but in 18x8.5" squared all they have is a 33 offset... Not to sure on that with lowered 1.250"? Only other option is 18x9.5 in 40 offset..
#1886 | |
Drives: FR-S Firestorm 6MT
18x9.5+40 will be very tight and may not fit unless you are running coilovers. |
#1887 |
Drives: scion fr-s
guys i need help, i tried using the scion frs app but my lap top is acting weird it wont load.
i got a set of 18x8.75 + 35 wheels with 225/40/18 tires, my car is lowered on eibach sportlines aprox: 1.4 inches. do i need to get anything else to fit the wheels ? someone please help !!
#1888 | |
Drives: Raven Scion FR-S
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
#1889 | |
Drives: scion fr-s
what you think ?
#1890 |
| The Following User Says Thank You to Slick For This Useful Post: | juanam0909 (11-01-2013) |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
