Old 10-21-2013, 08:14 AM   #1877
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
Originally Posted by OICU812 View Post
The Advan TC2 are now of interest to me because of their weight and similar looks to my Rotas, plus well and Advan wheel is better quality.
I can't seem to lock down how these would fit. I'm lowered approx an inch to inch and a quarter. Wondering how far these would be tucked in? I think I dislike too tucked as much as too much poke and "really" want to avoid spacers if can for the purpose of running an additional wheel set later.
If anyone has some solid thoughts on how 17x8.5" in 45 offset would for being lowered that would be hugely appreciated!!
Making it easy and taking your current wheel setup (8.5 +43 Front and 9.5 +43 Rear) the new setup with 8.5 +45 Front/Rear would differ from your current setup as follows:
Front: -2mm
Rear: -14.7mm
The - means that it will be more inside the wheel arches
Hope this helps
Killerbee is offline   Reply With Quote
The Following User Says Thank You to Killerbee For This Useful Post:
OICU812 (10-21-2013)
Old 10-21-2013, 10:54 AM   #1878
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
I am scrapping my previous plans for wheels upon further analysis; I will be lowering by ~1.4" with the Eibach sportlines and plan to use Enkei RPF1 17x8" +35 offset with 235/40r17 radials and using 3mm spacers in the front and 9 or 10mm in the rear (the largest I can use and still be safe). I plan on -2° camber rear and -1° camber in the front. Using the fitment calc that is posted in the other thread it appears that will be close to flush and wouldn't have issues rubbing (rubbing seems to be more likely with wider wheels), but if the experts could weigh in I would greatly appreciate it. Lowering the car and setting the camber will be done prior to the wheels so there will be some time where I will be using the 17x7" w/ 215/45r17 oem setup; I have no illusions of that being any kind of flush. I am more interested in getting ready for the end goal. Thanks in advance!
Turkish is offline   Reply With Quote
Old 10-21-2013, 11:57 AM   #1879
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Front: -2mm
Rear: -14.7mm
Hope this helps
Ok not terrible then just perhaps some 5-10mm spacers in back if want same look. Hmmm I'll need to see some with close specs in person I suppose if can first. Thanks kindly.
The Following User Says Thank You to OICU812 For This Useful Post:
Killerbee (10-21-2013)
Old 10-21-2013, 06:28 PM   #1880
OICU812
Just a dude
OICU812's Avatar
Ok so I'd like someone to clear up the math here
Example
17 x 8.0 in (45) offset
17 x 8.5 in (45) offset
Which is more "tucked in" and by how much, what's the simple math here? Many thanks I'm trying to understand this.
Old 10-22-2013, 03:18 AM   #1881
Killerbee
Killerbee's Avatar
Example
Long story http://www.ft86club.com/forums/showp...&postcount=995
Short story: The 17x8.0 will be 0.25" or 6mm more tucked in than 17x8.5
OICU812 (10-22-2013)
Old 10-22-2013, 03:42 AM   #1882
OICU812
Just a dude
OICU812's Avatar
Ok so reality is a 38-39 in a 8.5" would be absolute optimum but yet non existent in wheels I want. Seems the latest wheels are "not" with being lowered in mind.. Thanks so much for all your help bee, I am slowly understanding lol.
Killerbee (10-22-2013)
Old 10-22-2013, 03:59 AM   #1883
Killerbee
Killerbee's Avatar
True. Sadly, most of the time you will be forced to make a compromise when shopping for wheels, as you find very rarely the design/wide/boltpattern/offset that is just perfect for your car.
In your case, you may always go for some spacers to compensate for the offset (a 5mm spacer will get the +45 to a +40) but there are drawbacks with the spacers aswell, so this is basically just advisable if its purely about cosmetics.
And you're welcome, always happy to help out.
Old 10-22-2013, 09:47 PM   #1884
OICU812
Just a dude
OICU812's Avatar
Well this really has me thinking. Now I'm looking at a 18x8.0 (38) offset. Being 1-1.250" lowered and -1.5 camber all around I think will for pretty good. Looking at Advan T5s now which well..no one has had on this car yet.
Old 10-31-2013, 05:06 AM   #1885
OICU812
Just a dude
OICU812's Avatar
Well T5s have been discontinued just when I was settled !!
Now looking at Advan RGD but in 18x8.5" squared all they have is a 33 offset... Not to sure on that with lowered 1.250"?
Only other option is 18x9.5 in 40 offset..
Old 10-31-2013, 11:19 AM   #1886
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
18x8.5 +33 will work well on your car. What is your front camber set at?
18x9.5+40 will be very tight and may not fit unless you are running coilovers.
Slick is offline   Reply With Quote
Old 10-31-2013, 12:45 PM   #1887
juanam0909
Drives: scion fr-s
guys i need help, i tried using the scion frs app but my lap top is acting weird it wont load.
i got a set of 18x8.75 + 35 wheels with 225/40/18 tires, my car is lowered on eibach sportlines aprox: 1.4 inches. do i need to get anything else to fit the wheels ? someone please help !!
juanam0909 is offline   Reply With Quote
Old 10-31-2013, 01:06 PM   #1888
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
you will fit just fine man , take a deep breath and breathe lol im on stock height with 18x9.5 with +33 offset and 265/35/18s and they poke just a tad ... your sunken in more with a smaller wheel and a much smaller tire
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 10-31-2013, 01:38 PM   #1889
juanam0909
Drives: scion fr-s
ya but my car is lowered on aprox 1.4 inches i did see the tired fitment up front kinda tight here what you think ?
Old 10-31-2013, 02:44 PM   #1890
Slick
Slick's Avatar
Yeah, no issues with that setup. You are golden.
The Following User Says Thank You to Slick For This Useful Post:
juanam0909 (11-01-2013)
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
