Old 05-31-2020, 07:41 PM   #18439
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by LatentWagen View Post
Our bearings suck. What are your wheel and alignment specs? Or are you just putting a ton of heat into the brakes and cooking them? Sounds more like the latter, if you're tracking.
A 5x114.3 swap would beef up your failure point, since they have beefier bearings IIRC... or, since it's a probably a heat thing, maybe titanium brake shims and/or two-piece rotors, to keep heat from from cooking that grease into ineffectiveness. Two piece rotors would probably cost more than the 114.3 swap, but they sure would look cool and do a ton to reduce rotating/unsprung mass. I ran DBA 5k's on my spec B and loved them.
-3.2F, -2.2 rear and zero toe. Running BBK with two piece rotors already. Stock wheels on the street with 10mm spacers in the front to clear brakes. Track wheels are 17X9 +38. I don't get it, I am not doing anything different then anyone else.
I think it is a conspiracy by "big bearing" to make me spend more money on bearings so they can take my money and keep me down.
Old 05-31-2020, 08:03 PM   #18440
lvwds.tm
ネバーコンテント
lvwds.tm's Avatar
Drives: '17 BRZ 6MT
Originally Posted by melvin_213 View Post
Any info on where I can get those knee pads for the center console? Local Subaru dealership doesn’t have any in stock
FT86SF or you can order them through the dealer. They also pop up on eBay. I bought mine from a member here.
IG: lawds.tm
lvwds.tm is offline   Reply With Quote
Old 05-31-2020, 11:41 PM   #18441
LatentWagen
Drives: '17 BRZ / CBS + PP
Sounds like you're pretty far down the path. At a certain point, they do become regular wear items like pads or rotors. Big bearing wins again!
I think I have a set of titanium shims from TiC kicking around, might be worth a shot.
LatentWagen is offline   Reply With Quote
Old 06-01-2020, 09:21 PM   #18442
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
Today filled the tank 105th time and got my second highest MPG (36.9). Tracking with Fuelly. Average on Fuelly and the dash is also very close for the 25k tracked. Happy BRZ owner
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
Old 06-01-2020, 10:21 PM   #18443
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Ordered a new bumper to be repainted and eventually clear bra and ceramic coated.
MS, CSCS, TSAC-F, CPT
Old 06-01-2020, 11:06 PM   #18444
soundman98
ProCrastinationConsultant
soundman98's Avatar
how do we convince the rest of the population to start using clear bra's?
Old 06-01-2020, 11:41 PM   #18445
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Ended up being a bad spherical joint on my toe arm. Much easier fix.
Old 06-02-2020, 12:26 AM   #18446
weederr33
weederr33's Avatar
Show by example!
Old 06-02-2020, 01:22 AM   #18447
Oxyg3n
Oxyg3n's Avatar
Drives: 2017 BRZ - WRB
Originally Posted by Stephen W. View Post
I'm sorry, I know I'm old and not as bright as I once was but... You have a 2018 BRZ with what looks to be the exact same head unit that is in my tS. That unit comes with Apple CarPlay and Android Auto. So, why the need for the phone dash mount?
Kenwood looks good and if you like it better than that's money well spent for you. However, I fail to see why you'd change when the stock unit does the same thing.
Does the one piece dash trim have the same size cutout as the stock piece? I installed an aftermarket 6.95in Sony AX5000 and had to get a bracket to fill the gaps. Looks a lot cleaner with your one piece!
Oxyg3n is offline   Reply With Quote
Old 06-02-2020, 01:31 AM   #18448
BA9092
Captain Slow
BA9092's Avatar
Drives: '18 BRZ Limited PP 6MT ISM
The single piece dash trim has the cutout to accommodate the 200mm head units without the need for the side brackets to fill the gaps. But you must search for the 200mm head units specifically if you don't want to use the brackets.
BA9092 is offline   Reply With Quote
Old 06-02-2020, 01:43 AM   #18449
whiskeyfox
Drives: 2015 BRZ
installed coilovers and 18x9.5 +38 ambit wheels with nankang NS-25 265/35/18 tires. rides way better than my old setup can't believe it was $900 for the wheels and tires. rides better than my stock suspension with some bridgestone tires. need an alignment but honestly can't tell while driving. drives straight and no change from before I installed the coilovers....probably have some messed up toe or something though.
whiskeyfox is offline   Reply With Quote
Old 06-02-2020, 04:21 AM   #18450
ItsReiko
ItsReiko's Avatar
Drives: 2017 subaru brz
Ended up also swapping in the STI push to start button I bought in Japan last month (excuse the dust.. I just aircan sprayed it last week ):
Do you feel this piece was worth the high price? Also do you know which model you got? There are close to 6 different ones on ft86speedfactory and they all look basically the same but some has a status light and others do not.
Been tempted to get this for a long time..
ItsReiko is offline   Reply With Quote
Old 06-02-2020, 07:23 AM   #18451
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Got mine for ~$96 shipped from a dealer. Should have seen if my dealer would price match another and got it for $85.
83031CA023
dragoontwo is offline   Reply With Quote
Old 06-02-2020, 09:16 AM   #18452
grumpysnapper
grumpysnapper's Avatar
Ive got two sets of Rays CE 28 (16 x 7 J+33) , one set is powder coated in a titanium finish, but my favourite now is these that have just arrived back....
grumpysnapper is offline   Reply With Quote
