Old 05-31-2020, 01:36 AM   #18439
Chuckls
Moutain Runner
Installed Toms Clear lens.
Chuckls is offline   Reply With Quote
Old 05-31-2020, 11:52 AM   #18440
Zacharary
Drives: 2018 Subaru BRZ
Put on my Works ABM
Zacharary is offline   Reply With Quote
Old 05-31-2020, 12:11 PM   #18441
melvin_213
Drives: Subaru BRZ ‘14
Originally Posted by lvwds.tm View Post
Added some leather pieces to my peasant spec. Gauge hood is being ordered this week.
Installed tS bumper vents.
Any info on where I can get those knee pads for the center console? Local Subaru dealership doesn’t have any in stock
melvin_213 is offline   Reply With Quote
Old 05-31-2020, 07:10 PM   #18442
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by LatentWagen View Post
3 days, and nobody has done anything?!
Swapped in spare engine. Installed verus anti-starvation fuel flapper thing.
Did full nut and bolt check on the car since I have an event coming up. Found bad right rear wheel bearing Fuuuuuuuuu.......... WTF is with me and wheel bearings 3 Right Fronts, 1 left front, and now this one.
LatentWagen (05-31-2020)
Old 05-31-2020, 07:19 PM   #18443
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
https://www.ft86speedfactory.com/toy...trim-1981.html
Old 05-31-2020, 07:29 PM   #18444
LatentWagen
Drives: '17 BRZ / CBS + PP
Our bearings suck. What are your wheel and alignment specs? Or are you just putting a ton of heat into the brakes and cooking them? Sounds more like the latter, if you're tracking.
A 5x114.3 swap would beef up your failure point, since they have beefier bearings IIRC... or, since it's a probably a heat thing, maybe titanium brake shims and/or two-piece rotors, to keep heat from from cooking that grease into ineffectiveness. Two piece rotors would probably cost more than the 114.3 swap, but they sure would look cool and do a ton to reduce rotating/unsprung mass. I ran DBA 5k's on my spec B and loved them.
LatentWagen is offline   Reply With Quote
Old 05-31-2020, 07:31 PM   #18445
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
Originally Posted by Capt Spaulding View Post
Finished the installation of my OEM oil temperature regulator. Car runs, no leaks or explosions so far.
What route did you take with the hoses? Did you happen to take any pics during the install?
tehShirt is offline   Reply With Quote
Old 05-31-2020, 07:41 PM   #18446
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
-3.2F, -2.2 rear and zero toe. Running BBK with two piece rotors already. Stock wheels on the street with 10mm spacers in the front to clear brakes. Track wheels are 17X9 +38. I don't get it, I am not doing anything different then anyone else.
I think it is a conspiracy by "big bearing" to make me spend more money on bearings so they can take my money and keep me down.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
LatentWagen (05-31-2020), norcalpb (06-01-2020)
Old 05-31-2020, 08:03 PM   #18447
lvwds.tm
ネバーコンテント
lvwds.tm's Avatar
Drives: '17 BRZ 6MT
FT86SF or you can order them through the dealer. They also pop up on eBay. I bought mine from a member here.
IG: lawds.tm
lvwds.tm is offline   Reply With Quote
Old 05-31-2020, 11:41 PM   #18448
LatentWagen
Sounds like you're pretty far down the path. At a certain point, they do become regular wear items like pads or rotors. Big bearing wins again!
I think I have a set of titanium shims from TiC kicking around, might be worth a shot.
The Following User Says Thank You to LatentWagen For This Useful Post:
NoHaveMSG (06-01-2020)
Old 06-01-2020, 09:21 PM   #18449
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
Today filled the tank 105th time and got my second highest MPG (36.9). Tracking with Fuelly. Average on Fuelly and the dash is also very close for the 25k tracked. Happy BRZ owner
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
The Following User Says Thank You to Busybee For This Useful Post:
Dadhawk (06-02-2020)
Old 06-01-2020, 10:21 PM   #18450
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Ordered a new bumper to be repainted and eventually clear bra and ceramic coated.
MS, CSCS, TSAC-F, CPT
Old 06-01-2020, 11:06 PM   #18451
soundman98
ProCrastinationConsultant
soundman98's Avatar
how do we convince the rest of the population to start using clear bra's?
NoHaveMSG (06-02-2020)
Old 06-01-2020, 11:41 PM   #18452
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Ended up being a bad spherical joint on my toe arm. Much easier fix.
LatentWagen (06-03-2020), soundman98 (06-01-2020)
