Old 07-27-2014, 05:09 PM   #169
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by nunonuna View Post
Just reflashed 2.0 stage 1. 93 oct.
After I reflashed my CAL ID changed to B01C on OFT. OFM still shows A01C as it used to be.
Is that normal?? I did use correct file to flash it which is stg 1 A01C.bin
And all labels of data logging are gone also.
After flashing your ecu, disconnect it and plug it in again before going to realtime data display. The text will re-appear. Just a small bug with the 1.27 firmware that will be fixed in the next fw update.
Old 07-27-2014, 06:14 PM   #170
lucid215
Originally Posted by edeekeos View Post
@Shiv@Openflash
Re-downloaded and re-flashed the new 2.0 tune, and now everything is GOLDEN, really not sure what was going on before. The tune feels great, FT's and AFR are beautiful. This tune feels MUCH smoother than the 1.59. Also, LC is really nice, glad to finally have that available, now to get to the next test and tune at the track. Overall, very happy with this rendition, great work, as always!
I wonder if you accidentally uploaded the stage 2 esc rom. I know shiv accidentally uploaded those to the site but was fixed the next day
lucid215 is offline   Reply With Quote
Old 07-27-2014, 06:17 PM   #171
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
What fuel is recommended for the roms in the folders that don't have an octane number?
Old 07-27-2014, 06:46 PM   #172
Shiv@Openflash
Drives: 2013 FRS
The ESC maps will work just fine on a non-ESC'd car so I don't think that was the problem.
Old 07-27-2014, 07:02 PM   #173
Readytoxplod
Tire Destroyer
Drives: Firestorm+snail
@Shiv@Openflash
Completely new to this and I don't know how to get the new OFT 2.0 files downloaded into my car.
I want to upgrade to stage 1 93, can someone help? I opened Open Flash Manager 1.10 and went to "Upload," and under components "Original File" says "not present" along with the other "Modified #1-5."
-I then tried to select a file for modified #1 and went in my downloads "stage 1 93 oct" folder and selected "Stg1 B01C.bin" from the folder to upload. I then received an error message stating "The file selected is not compliant"
Can anyone help?
Readytoxplod is offline   Reply With Quote
Old 07-27-2014, 07:09 PM   #174
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by Readytoxplod View Post
@Shiv@Openflash
Can anyone help?
If your original file is "not present" then it looks like you never installed the OFT properly. It needs to read your ECU before you can do anything else. There is a video on the front page of www.openflashtablet.com showing this process in detail.
Old 07-27-2014, 07:16 PM   #175
Readytoxplod
Tire Destroyer
ahh it says "error 0x69 while communicating with device"
I reconnected my tablet and the error is gone.
I also checked my ROM and it includes "A00C," I then uploaded the stage 1 93 A00c.bin file. Thanks shiv!
Old 07-27-2014, 08:10 PM   #176
Shiv@Openflash
Drives: 2013 FRS
Now go for a nice Sunday drive!
Old 07-27-2014, 08:27 PM   #177
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Good evening Shiv
I sent you an email about my custom tune, will I be able to gain the benefit of this new 2.01 tune?
Thank you
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 07-27-2014, 08:50 PM   #178
FingR-S
I got sucked into boost..
FingR-S's Avatar
Drives: Whiteout FR-S & Supercharged BRZ
Shiv, I loaded the 2.0 Stage 1 91 Oct tune and everything is working great - as reported by others: smoother acceleration = I would say more linear response than the 1.59 tune. I still have to give another 40 miles or so to get the full effect.
Question: (I've only done this once before)
The files all look the same in their respective folders for example:
In the OTS v2.0 Beta folder/stage 1/Stg 1 700C, the "Stg 1 700C" file looks the same as the "Stage 91oct" folder file called the same "Stg 1 700C"
I want to make sure that I'm viewing the files correctly.
All the maps I uploaded to the OFT look the same "Stg 1 700C".
I went by (remembered) what slot I uploaded them too - 1.59 is in the first slot, 2.0 in the second, and 93oct tune in the third slot - all have the same file name - is this normal?
Since I don't have to reload the 2.01 maps, is there a link to loading the correct XML files - never done it - to get launch control to work etc?
Thank you for all the great work on these tunes!
For sale: 2013 BRZ Vortech Supercharged with nice updates.
Vortech Supercharger - Perrin exhaust - 245 RS3 on RPF1's
FingR-S is offline   Reply With Quote
Old 07-27-2014, 08:56 PM   #179
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
You can rename the files on your pc before loading them to make it more clear.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 07-27-2014, 09:55 PM   #180
FingR-S
FingR-S's Avatar
That's easy - wasn't sure that was ok. Thanks FrsDuke!
Old 07-27-2014, 09:57 PM   #181
wparsons
wparsons's Avatar
^^ This, I rename all mine so it's clear as well.
Put some km's on the stage 1 93 octane tune, noticed something unexpected... even though I filled up with 1/4 tank of 91 left (so not a full tank of 94 octane), I'm getting WAY less mid range knock under load (I always get enough knock when stuck in traffic on the 91 octane tune running 91 octane to drop the IAM down to like 0.5 all the time), with the 93 octane tune the IAM stayed at 1.0 even stuck in traffic with the AC on.
Beyond that, it definitely feels a few hp stronger across the rpm range.
flickr
Old 07-27-2014, 10:08 PM   #182
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
Does the 93 stage 1 change anything other than another HP/tq curves? Eg idle speed, Rev limit, pedal position map, etc? Just curious if some of the changes people are noticing are plecebo?
xxBrun0xx is offline   Reply With Quote
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 10:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
