Old 07-27-2014, 01:23 PM   #155
wbradley
Sarcastic SOB
wbradley's Avatar
Thanks. Seems a bit peppier!
Old 07-27-2014, 01:25 PM   #156
CaptainSlow
CaptainSlow's Avatar
Still unable to get the FFS and LC to work. I deleted the XML files that were released with v2.00 and replaced them with the XML files released with v2.01. Before, the tables would show up, but the FFS/LC options weren't there. Now, with the v2.01 XML files only, I don't get anything to load. Not sure if I need both sets (the ones that started with "RR_" from v2.0 and the ones that started with "OFT_" from v2.01) or if I'm doing something else wrong?
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 07-27-2014, 01:31 PM   #157
CaptainSlow
Nevermind...figured it out.
To get the XML files from 2.01 to work, you have to change the first part from "OFT_" to "RR_". The tunes probably point to that RR_ prefix because that was how it was named in the original 2.0 release. Changed "OFT_ZA1JA01C.xml" to "RR_ZA1JA01C.xml" and it worked, with the LC/FFS tables present at the bottom.
Old 07-27-2014, 01:34 PM   #158
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
You don't necessarily have to rename the new XML files. Just go to XML manager in Rom Raider, deselect old XMLs and select new ones.
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
CaptainSlow (07-27-2014)
Old 07-27-2014, 01:36 PM   #159
CaptainSlow
Ah, OK...I wasn't sure how to do that in the software itself. Thanks!
Old 07-27-2014, 01:54 PM   #160
Jrdad
Jrdad's Avatar
Drives: 2013 Scion FR-S 6M Argento
@Shiv@Openflash will there be a table to adjust the cold start idle, preferably with the excessive valve overlap on initial start?
Jrdad is offline   Reply With Quote
Old 07-27-2014, 02:07 PM   #161
steve99
Drives: FT86
The tables are defined you just need to alter them
http://i.imgur.com/ZBR0Bl6.jpg
post here by @troek
http://www.ft86club.com/forums/showp...&postcount=108
Old 07-27-2014, 03:09 PM   #162
Jrdad
Jrdad's Avatar
post here by @troek
I don't have either maf correction after start table
Old 07-27-2014, 03:31 PM   #163
steve99
Drives: FT86
Just chage the cold start idle and ignition retard as per troek post if you have tose tables if not your out of luck, those tables may only be in the non oft definitions
Old 07-27-2014, 03:37 PM   #164
355rockit
Drives: Sci FR-S, Fer F355, Toy Highlander
Did a 100 mile drive today with the car club today with v2.0 of the Stage 2 UEL tune. Less torquey off the line, but I am happier since it is easier to modulate. Power comes on smoother. One big plus is my mileage is better with the 2.0 OTS vs. 1.59 OTS tune.
355rockit is offline   Reply With Quote
The Following 2 Users Say Thank You to 355rockit For This Useful Post:
DC2R (07-27-2014), Shiv@Openflash (07-27-2014)
Old 07-27-2014, 03:48 PM   #165
themajesticone
themajesticone's Avatar
Drives: '13 UM86
Tried to do a couple pulls last night - going to try and get another run in tonight. Here is my log, how is it looking?
http://datazap.me/u/themajesticone/a...0?log=0&data=1
themajesticone is offline   Reply With Quote
Old 07-27-2014, 03:59 PM   #166
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
@Shiv@Openflash
Re-downloaded and re-flashed the new 2.0 tune, and now everything is GOLDEN, really not sure what was going on before. The tune feels great, FT's and AFR are beautiful. This tune feels MUCH smoother than the 1.59. Also, LC is really nice, glad to finally have that available, now to get to the next test and tune at the track. Overall, very happy with this rendition, great work, as always!
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
The Following User Says Thank You to edeekeos For This Useful Post:
Old 07-27-2014, 04:39 PM   #167
nunonuna
nunonuna's Avatar
Just reflashed 2.0 stage 1. 93 oct.
After I reflashed my CAL ID changed to B01C on OFT. OFM still shows A01C as it used to be.
Is that normal?? I did use correct file to flash it which is stg 1 A01C.bin
And all labels of data logging are gone also.
nunonuna is offline   Reply With Quote
Old 07-27-2014, 04:43 PM   #168
Malt
Drives: 2015 WRX
Entirely normal, just like other CalID's other than A01C before the v2.0 maps (ie 700C, A00C, B00C, etc...) listed A01C there, your A01C will now list the base map in which the new maps are based on (which is B01C). The OFT will not let you flash the wrong map to your ECU.
Malt is offline   Reply With Quote
The Following User Says Thank You to Malt For This Useful Post:
nunonuna (07-27-2014)
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 10:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
