BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#169 | |
Drives: Crapcan
Even with full exhaust and a tune this car does not start to make power until above 4k RPM and it doesn't really start to pull really well till around 5k. In the video he is right at 4k on top of the fact that he is at high elevation ![]()
#170 | |
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
Stock torque dip matters, even on the track, and that was demonstrated by Justin majorly pulling on the stock car. Downshifting would have lost the PP BRZ even more time. He was in the right gear. |
#171 | |
Drives: Crapcan
I know situations arise that are not worth shifting down for, but torque dip excluded, in this example the car still is not going to pull well because you are out of the RPM range where the car makes the most power.
#172 | |
Old Guy
#173 |
5252rpms is where the hp and the torque are always the same.
Sent from my SM-G975U using Tapatalk |
The Following User Says Thank You to p1l0t For This Useful Post: | NoHaveMSG (02-25-2020) |
#174 |
Drives: Crapcan
Then explain it? Don't cop out. Having a constructive discussion is what adults do. There have been no name calling or derogatory remarks.
Your claim is that the mod'd car is pulling on the stock car because the stock car has torque dip. My counter, is that even at the RPM's they are running that the car doesn't make power in that range anyway.
#175 | |
Old Guy
@NoHaveMSG , I think you have been respectful, thank you. However, this discussion I believe goes beyond the scope of this specific thread.
To this tangent, I will end with the original point directly relevant to the thread was: Quote:
A shift costs time that is / can be greater than sitting in the torque dip. Same with letting the car bang off the limiter before a braking zone. Therefore, in this case at that point on the track, the car *is* in the RPM band it needs to be in (for the current setup) and the torque dip does affect drivability. You lose more time shifting. In either situation, a car (STX prepped BRZ w/ACE headers and no more dip) with the same gearing and tires was superior proving the torque dip, even on full tilt, is a problem that needs to be rectified. Yes, the STX BRZ had "some" additional engine performance from a tune, but as noted, nothing affected the performance in this situation as much as just the torque dip. That was the large, noticeable elephant in the room -- not STX prep vs DS prep levels. Thanks for allowing the tangent, OP. |
#176 | |
Drives: Crapcan
![]() My solution was to gear the car down and extend over rev up top to keep the car higher into the RPM range without downshifting.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | dowroa (02-25-2020) |
#177 | |
What is the actual difference in the power levels? My stock PP 86 was about 115kw, when it was tuned it was about 145kw., which would then walk past stock twins. Kinda the point of tuning really.......his "evidence" = apples are not oranges Unless I'm not picking up what your putting down.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
#178 | |
The guy w/o an FRS or BRZ
Drives: '23 GR86 Premium 6MT Halo White
The Following User Says Thank You to ROFL it's Waffle For This Useful Post: | soundman98 (02-26-2020) |
2018 Toyota Camry Spied: Normalness in a New Generation | gymratter | Other Vehicles & General Automotive Discussions | 95 | 10-12-2020 12:19 AM |
Toyota uBox Concept EV created by students for the demanding generation Z | cwpbrz-ji | Other Vehicles & General Automotive Discussions | 38 | 05-05-2016 08:11 PM |
Subaru to Install New Generation of Engine Technology in 2016 | 86geek | BRZ First-Gen (2012+) -- General Topics | 13 | 03-20-2015 03:49 PM |
Second generation BRZ planned, says Subaru boss | jenzan | BRZ First-Gen (2012+) -- General Topics | 6 | 07-08-2014 11:36 AM |
FS: Toyota Lexus Generation 5 Navigation Discs | tonystewart | Miscellaneous | 8 | 11-17-2013 09:07 AM |
