#155 |
not playing cards
Bullshit.
#156 | ||
Drives: 2015 Series.Blue
Keep in mind that the failure mode of a CF driveshaft is by far the BEST out of all the materials used. It effectively becomes a very large broom ![]() Quote:
The same reason they still put crossdrilled rotors on performance cars... |
| The Following 2 Users Say Thank You to Poodles For This Useful Post: | Captain Snooze (02-17-2015), stugray (02-17-2015) |
#157 | |
| The Following User Says Thank You to Koa For This Useful Post: | cdrazic93 (02-18-2015) |
#158 | |
Kuruma Otaku
This was an aftermarket one, though.
Because titanium. |
| The Following User Says Thank You to Dimman For This Useful Post: | Koa (02-17-2015) |
#159 |
Kuruma Otaku
Also, 44 milliseconds at 100 mph is over 6 feet if my not NASA-level math is correct.
So can we do the fun math again for distance between cars at the end of an acceleration run? Then also braking? Then hard accelerating and hard braking many times over, say a road course?
Because titanium. |
#160 | |
Add lightness!
Drives: 17' WRX
I would regret buying a house in 2007 or hitting a kid with my car. Spending $400 on a well crafted, well thoughtout car part that I lovingly installed on my car to daydream about my .2 second improvement on HPDE day is just part of the hobby. This entire hobby is about setting money on fire. If you think otherwise, you are just deluding yourself. I laugh everytime I hear someone use the word "invest" when they talk about buying shit for their cars. Newsflash: Every aftermarket car part is a horrible use of money. |
| The Following 4 Users Say Thank You to industrial For This Useful Post: |
#161 | |
Drives: '13 Ultramarine FR-S M/T
Mod List:
FT86SF Catted header / Nameless combo pipe with cat and res/ FT86SF V1 CBE / GrimmSpeed Intake / OFT STG 1 GS Tune / Fortune Auto 500's |
| The Following User Says Thank You to Sypher For This Useful Post: | Strife26 (04-17-2017) |
#162 |
Is not fast.
Drives: 2014 Whiteout M/T
Industrial's so close. He almost has it.
"America is all about speed. Hot, nasty, badass speed." - Eleanor Roosevelt, 1936
#163 | |
Because compromise ®
Drives: Red Herring
| The Following User Says Thank You to Captain Snooze For This Useful Post: | cdrazic93 (02-17-2015) |
#164 | |
http://www.wallaceracing.com/drivesh...critical_speed
Mod List:
#165 | |
Kuruma Otaku
I'm just absolutely, positively, metaphorically, dying to make a snarky yet scientifically correct comment about my superhuman ability to differentiate between 6 feet and zero without using a Sciencemaster Mathotron 9000.
Because titanium. |
| The Following User Says Thank You to Dimman For This Useful Post: | Strife26 (04-17-2017) |
#166 | |
The articles notes that removing 15 pounds from a flywheel (where the weight is farther from the center point and the moment of inertia is higher than a driveshaft) can be expected to drop only .08 seconds from a straightaway where acceleration from 60-130mph occurs. While I try to extract as much performance out of the car at the track, .08 seconds is well within my margin of error on any single lap and the difference from 15 pounds off the driveshaft will be much less than .08 seconds since the moment of inertia is lower. Now granted, this is ignoring the cumulative effects of constant acceleration/deceleration that occur each lap that a lower MOI would have. However, it has been mathematically proven in this thread that the MOI delta between the stock and aluminum driveshafts is rather insignificant, so I don't expect the cumulative effects of an insignificant change to become very significant.
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
| The Following 4 Users Say Thank You to Jonsey For This Useful Post: |
#167 |
In the beginning, there was rain. The people thought the gods must've been angry so they sacrificed their kids as offerings and the rain stopped. Some people realized the offerings did SFA and told others to no avail, so the killing of their kids continues until they wipe themselves out.
The end.
#168 | |
Drives: 2013 GBS BRZ Limited
This simplification works for a perfect cylinder assuming a "thin" shell you dont have to "go all integral on it" but you will get better accuracy. It also was within a few percent of an online calculator: http://www.endmemo.com/physics/momentinertia.php and the link posted back a couple pages. 30 lbs driveshaft = 13.6 kg 3" dia (1.5” radius = 3.81 cm = .0381 m) = I = .0381 * .0381 * 13.6 = .01974 kg.m^2 |
| Lightweight aluminum drive shaft installed. | stockysnail | Northwest | 18 | 02-05-2020 12:18 AM |
| Driveshaft Shop Aluminum Drive Shaft. | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 40 | 10-15-2015 10:11 PM |
| Invidia N1 interference with Driveshaft Shop aluminum shaft. | xkalelx | Engine, Exhaust, Transmission | 6 | 03-03-2015 10:43 AM |
| Scion FR-S / Subaru BRZ Drive Shaft Shop Carbon Fiber Drive Shafts In Stock | Anthony@RWHP | Transmission and Driveline | 4 | 12-25-2013 09:09 PM |
