#141 |
#142 |
Is not fast.
Drives: 2014 Whiteout M/T
The thing is though, people defending the magical properties of light weight drive shafts are essentially just arguing that they can feel a perceivable difference over stock. The math alone proves that to be false. Now they're resorting to marketing claims and anecdotal evidence.
Basically, they spent money on a part and they want to believe that it was the best bang for their buck. I would have to imagine that they're the same people who proclaimed up and down that aftermarket intake kits produced SUBSTANTIAL differences over stock or even over an aftermarket air filter. It all just stems from the inability to be satisfied with their own purchases. They need everyone else to agree with their butt dyno claims because then they'll feel validated each time they drop the big bucks on their car. Have y'all tried lightweight seat belt tensioners? They have CF ones that reduce the seat belt pulley weight upwards of 80%. You can really feel the difference in belting speed after you install them.
"America is all about speed. Hot, nasty, badass speed." - Eleanor Roosevelt, 1936
#143 | |
Because compromise ®
Drives: Red Herring
Disclosure. I have a cf drive shaft. Am I pleased with it? Yes, and that's all that matters. But then again, my battery cost me close to AUD$1100.
#144 | |
Drives: GTS 86
As someone here explained, there are few things that you cannot ignore: this debate is much more complex than you or I can wrap their heads around. A software would be able to measure the benefits of it and by the looks of it, there is no doubt about it (BMW and few other car makers are doing it now, regardless of their marketing stuff). Grimmspeed TESTED their product and reported back the results. They are engineers specialized in such area. I would trust them rather than someone that tries to convince vehemently that he is right disregarding the fact that (and i will say it again) this is a more complex problem than one can resolve. There are plenty of cars out there that mathematically (on paper) they look great but they are shit to drive, so the stuff on paper should be taken with a grain of salt! (Ex VW GTI vs R32 0 huge difference on paper, not so big on the track). By the looks of it, this has become more of who's got better insults or who's got more followers. As someone else said: test the car with and without it. I have and I felt a difference. Huge difference? No! Noticeable ? Yes. Add few more things in the mix: wheels, brakes, etc...and you will get even more. Is like arguing whether an intake makes a difference or not. (it does, but you need few other things to make that "difference" more noticeable. I would be grateful if we could keep this convo civilized with no names calling and stuff! You are not making your point more believable by doing that..just sayin'! |
#145 | |
Drives: Red Herring
It is fact (well, I think it's a fact but I could be wrong lol) that the gray stuff upstairs is not rational and is subject to self deception. It is the way things are.
#146 |
Kuruma Otaku
It doesn't matter if you win by an inch or by 44 milliseconds.
Winning's winning.
Because titanium. |
#147 | |
Drives: BRZ Limited
[ame="http://en.wikipedia.org/wiki/Confirmation_bias"]Confirmation bias - Wikipedia, the free encyclopedia[/ame] I also think increased NVH makes people percieve far larger gains than they actually have. Last edited by TheVoiceOfReason; 02-18-2015 at 12:15 AM. |
#148 |
Drives: Red Herring
Yeah, the good ol' "I have a loud exhaust so now I am faster" syndrome.
#149 | ||||||||||
Drives: 2015 Series.Blue
One piece driveshaft doesn't make sense for big power as big power = higher speeds. One can easily go over the critical speed of a one piece driveshaft in this car because of it's low final drive! Quote:
One word: Placebo Quote:
It's not hard for him and math and science is not opinion. Quote:
It's making it LESS safe as it's introducing a critical speed failure mode into the equation. Quote:
As I've already said, the center bearing is NOT for NVH, but for safety to raise the driveshaft's critical speed. Quote:
Well, if it's a BRZ you're only consuming 35w x 2, but that's the headlights only, but you still make a good point ![]() Quote:
1) 0-100MPH is published and he's done all his previous calculations with the same metric. Changing that metric would only confuse people. 2) Turbos have lag (which is quantifiable) and they void warranties meaning they can possibly be more expensive in the long run... Quote:
Axial strength is pretty pointless on a driveshaft. I'll say it again: DRIVESHAFT CRITICAL SPEED IS FAR WORSE. Quote:
RX8: Kinda carbon fiber (carbon reinforced plastic) 350Z: carbon fiber 370Z: same fing car... GTR: Carbon fiber. Z06: Doesn't count as it's a torque tube setup (tranny is in the rear) Most of those are carbon fiber. Carbon fiber is used because it allows them to run a single piece driveshaft without having driveshaft critical speed issues. It's also fragile and has to have shields to prevent foreign objects from hitting it. Quote:
I don't see anyone breaking the stock driveshaft. It's also NOT stronger as (god I feel like I'm beating a dead horse here) driveshaft critical speeds will occur. As none of the driveshaft companies want to give out their specs of the shaft (big surprise as it's probably unsafe), I'm guessing at the specs. If someone wants to get me length, diameter, and wall thickness, it's easy to figure this stuff out... |
#150 | |
Okay brother you're just sayin has been noted. It's not outside of our heads and expertise to wrap our brains around this, though. It's not rocket science. We don't have to throw up our hands and say, "WELL, TOO HARD TO UNDERSTAND HERE!" and try to hide behind that. Physics is a VERY well understood and applied science. The logic and math check out. Let me ask you... what do you think? |
#151 |
Kuruma Otaku
My buddy had a CF driveshaft grenade on him. Wasn't pretty. Not sure but we think it was from a bad fit between the CF tube and metal yoke part covered by too much adhesive.
Ever since then I've been a bit leery of half-engineered driveshafts. Learning that the harmonic stuff is weird, aluminum's fatigue properties, and how welding it adds stress risers while removing initial heat treat strength has been enough for me to get uncomfortable looking at a few aluminum DS in the past. Are these things you're interested in discussing, Stu (in your inside voice)?
Because titanium. |
#152 | |
Add lightness!
Drives: 17' WRX
This discussion is beyond futile here. There are countless books and sources that say reducing rotating mass (to include the driveshaft) is beneficial for a performance car. Almost every OEM does this. There are aftermarket driveshafts available for almost every performance car foreign and domestic, that doesn't come with one. It's not like lightweight driveshafts are something new that came along with the ft86. People in other car communities pay 2-5x more for lighter and more exotic driveshafts. Since we are beyond the polite stage, all the math in this thread is nearly worthless for this discussion. As I've said over and over, you need modeling software specific to this application that the OEMs have to demonstrate mathematically whether this mod is "worth it". I'm not sure why these few guys are so vehemently defending their position that this mod is not "worth it" since none of them have any real world experience with this mod. Don't know why I'm still here. |
#153 | |
Add lightness!
Drives: 17' WRX
http://www.stockcarracing.com/techar..._reducing_moi/ |
#154 | |
Is not fast.
No one has disputed the fact that reducing rotating mass, including the driveshaft, isn't beneficial. The only argument being made by the heretics who believe in math and science is that the benefit of a light weight drive shaft is negligible in the practical scope of the car. It's akin to taking a heavy shit and driving your car naked in hopes that the reduced sprung weight is going to improve your lap times. Technically you've reduced the sprung weight of your car. Does it have a practical benefit? Nope. If the OP wants to buy a light weight drive shaft, good on him. But stop trying to convince yourself that you've purchased a miracle drive line upgrade which'll make you .05 seconds faster in the corners. It just won't.
| Lightweight aluminum drive shaft installed. | stockysnail | Northwest | 18 | 02-04-2020 11:18 PM |
| Driveshaft Shop Aluminum Drive Shaft. | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 40 | 10-15-2015 09:11 PM |
| Invidia N1 interference with Driveshaft Shop aluminum shaft. | xkalelx | Engine, Exhaust, Transmission | 6 | 03-03-2015 09:43 AM |
| Scion FR-S / Subaru BRZ Drive Shaft Shop Carbon Fiber Drive Shafts In Stock | Anthony@RWHP | Transmission and Driveline | 4 | 12-25-2013 08:09 PM |
