#155 |
There is more noise in the rear, but I have noticed this on the V3's as well on this car. It has been brought up with other coil over options as well. Can not say it bothers me too much.
#156 | |
http://www.ft86club.com/forums/showp...&postcount=110
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#157 | |
Drives: On track
| The Following User Says Thank You to GTM_Challenge For This Useful Post: | swift996 (05-24-2013) |
#158 |
Drives: On track
The KWs have a different bump stop design - one with a plastic "curtain" attached. We have found that these do tend to make a little noise under compression.
#159 | ||
Another thing I thought was the 3 bolts holding the actual camber plate to the car might be loose. On the R2's they have a lot of play for what I assume caster. I torque'd them but they might be loose. |
#160 | |
#161 |
Yeah i'm guessing that's me. Up to this point Mark and Eibach has been helpful. They offered a rental car, but i'm not sure if that will work for our schedule. Hopefully they can pinpoint the issues or install error!
#162 |
I plan to pull it off and check that top nut and tighten it if necessary. If that doesn't fix it, I'll play with the preload. Hopefully I'll get it fixed this evening. My new tires come in today!
| The Following User Says Thank You to swift996 For This Useful Post: | Hanakuso (05-24-2013) |
#163 |
Drives: 2005 S2000
Richard, you went out SoW last week right? Do you have any updates on the coils?
Scion FR-S '13 - Track Toy
BMW M Roadster '06 - Track Toy Suzuki GSX-R750 '07 - Track Toy Lexus IS350 '07 - Sold ![]() |
#164 |
Just an update on my end. I did tighten down the top bolts and the noise for the most part went away. I also had to add some pre-load. I realized that my camber plates came from Eibach mounted wrong. So when I get a chance I'm going to pull them back off and rotate them so the camber plates line up correctly.
| The Following User Says Thank You to swift996 For This Useful Post: | JoeBoxer (06-01-2013) |
#165 | |
Site Moderator
Drives: Stuff
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#166 |
Drives: 2010 BMW M3, 2013 Subaru BRZ
#167 |
I'm pulling them off tomorrow. When I received them they wouldn't rotate freely and I didn't want to break anything. Should I keep the tops bolted and rotate the strut assembly? Or pull them off and rotate by hand?
#168 |
Site Moderator
Drives: Stuff
you might be able to leave the bottom bolted, just unbolt the top and rotate them. They should spin pretty easily, although they may not if there's a bunch of preload on them, I didn't preload them until after they were bolted up.
-Dave
| Coilover Review: FEAL SUSPENSION 441 coilover kit | mr. slim | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 11-28-2019 06:30 AM |
| Eibach Multi-Pro R2 Coilover Review | donutfilling | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 254 | 05-08-2016 11:56 AM |
| Eibach Multipro R1 and front and rear sway bar installed | Pekingduck | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 43 | 12-30-2013 10:59 AM |
| ***Time to freak out, Eibach coilover pricing available**** | JoeBoxer | Brakes, Suspension, Chassis | 154 | 05-16-2013 05:30 PM |
| Eibach Coilover Options - SEMA 2012 Coverage | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 45 | 01-25-2013 07:19 AM |
