Old 05-10-2013, 01:26 PM   #155
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Originally Posted by ayau View Post
I did notice that the rear is a little noisier when going over bumps. It might have to do with the added NVH and the fact that I removed the trunk lining.
There is more noise in the rear, but I have noticed this on the V3's as well on this car. It has been brought up with other coil over options as well. Can not say it bothers me too much.
mines13 is offline   Reply With Quote
Old 05-24-2013, 10:21 AM   #156
swift996
swift996's Avatar
Originally Posted by Hanakuso View Post
I did email Mark earlier this week but i'm still waiting on a response. If you need to check out my car i'm only 30-45 mins away from Eibach.
I'm assuming the R2's are packaged ready to go, but if not, I haven't disassembled them yet.
Did you ever isolate the issue? I'm having a similar problem:
http://www.ft86club.com/forums/showp...&postcount=110
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 05-24-2013, 10:50 AM   #157
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
Sounds like a loose tophat bolt up front. My KW Clubsports did this too. That or a loose sway bar end link on that side, or the sway bar could be contacting the control arm. I'm willing to be it's one of those three.
GTM_Challenge is offline   Reply With Quote
The Following User Says Thank You to GTM_Challenge For This Useful Post:
swift996 (05-24-2013)
Old 05-24-2013, 10:53 AM   #158
GTM_Challenge
Drives: On track
The KWs have a different bump stop design - one with a plastic "curtain" attached. We have found that these do tend to make a little noise under compression.
Old 05-24-2013, 11:59 AM   #159
Hanakuso
I'm going to Eibach this coming Tuesday morning and they want to keep my car till the end of Wednesday. I will keep you updated!
You might be correct, I didn't play around with the tophats but I assume they came torque'd from Eibach.
Another thing I thought was the 3 bolts holding the actual camber plate to the car might be loose. On the R2's they have a lot of play for what I assume caster. I torque'd them but they might be loose.
Hanakuso is offline   Reply With Quote
Old 05-24-2013, 01:43 PM   #160
swift996
swift996's Avatar
AH ok, yeah Mark from Eibach mentioned they are looking at a customers car next week and would update me..I take it that's you.
Old 05-24-2013, 01:52 PM   #161
Hanakuso
Yeah i'm guessing that's me. Up to this point Mark and Eibach has been helpful. They offered a rental car, but i'm not sure if that will work for our schedule. Hopefully they can pinpoint the issues or install error!
The Following 2 Users Say Thank You to Hanakuso For This Useful Post:
CSG Mike (05-24-2013), RYU (05-24-2013)
Old 05-24-2013, 01:59 PM   #162
swift996
swift996's Avatar
I plan to pull it off and check that top nut and tighten it if necessary. If that doesn't fix it, I'll play with the preload. Hopefully I'll get it fixed this evening. My new tires come in today!
The Following User Says Thank You to swift996 For This Useful Post:
Hanakuso (05-24-2013)
Old 05-31-2013, 05:29 PM   #163
kvnchu
Drives: 2005 S2000
Originally Posted by RAWR BRZ View Post
Can I feel it too :P
Richard, you went out SoW last week right? Do you have any updates on the coils?
Scion FR-S '13 - Track Toy
BMW M Roadster '06 - Track Toy
Suzuki GSX-R750 '07 - Track Toy
Lexus IS350 '07 - Sold
kvnchu is offline   Reply With Quote
Old 06-01-2013, 12:24 PM   #164
swift996
swift996's Avatar
Just an update on my end. I did tighten down the top bolts and the noise for the most part went away. I also had to add some pre-load. I realized that my camber plates came from Eibach mounted wrong. So when I get a chance I'm going to pull them back off and rotate them so the camber plates line up correctly.
JoeBoxer (06-01-2013)
Old 06-01-2013, 08:25 PM   #165
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
they actually freely rotate.. or should anyways. so I don't think I'd call the rotation of them wrong.. The installation guide shows the correct orientation.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-02-2013, 01:54 AM   #166
RAWR BRZ
Drives: 2010 BMW M3, 2013 Subaru BRZ
I'll update once I get good seat time... Right now lots of issues with the car...
RAWR BRZ is offline   Reply With Quote
Old 06-02-2013, 11:56 AM   #167
swift996
swift996's Avatar
I'm pulling them off tomorrow. When I received them they wouldn't rotate freely and I didn't want to break anything. Should I keep the tops bolted and rotate the strut assembly? Or pull them off and rotate by hand?
Old 06-02-2013, 12:03 PM   #168
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
you might be able to leave the bottom bolted, just unbolt the top and rotate them. They should spin pretty easily, although they may not if there's a bunch of preload on them, I didn't preload them until after they were bolted up.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 06:30 AM
Eibach Multi-Pro R2 Coilover Review donutfilling Suspension | Chassis | Brakes -- Sponsored by 949 Racing 254 05-08-2016 11:56 AM
Eibach Multipro R1 and front and rear sway bar installed Pekingduck Suspension | Chassis | Brakes -- Sponsored by 949 Racing 43 12-30-2013 10:59 AM
***Time to freak out, Eibach coilover pricing available**** JoeBoxer Brakes, Suspension, Chassis 154 05-16-2013 05:30 PM
Eibach Coilover Options - SEMA 2012 Coverage FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 01-25-2013 07:19 AM
