Old 04-01-2013, 05:35 PM   #155
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
I've seen two in Australia alone, one turbo & one NA. The turbo setup snapped the rod on decel while slowing down to pull into the owners street, the NA one snapped through normal acceleration at around 6000rpm. Both ended up with the typical block windows
JP is offline   Reply With Quote
The Following User Says Thank You to JP For This Useful Post:
Sportsguy83 (04-01-2013)
Old 04-01-2013, 05:35 PM   #156
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
yeah thats why im staying n/a less headache and im under warr
driftartist is offline   Reply With Quote
Old 04-01-2013, 05:44 PM   #157
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by Frs300 View Post
it was connected on the side....that nipple was venting to atmosphere
Could be ok, in that configuration the pressure source should be before the throttle plate, taking the source straight off the compressor outlet would be the best bet:
http://www.turbomaster.info/eng/appl...ial.php?wg=F41
Old 04-01-2013, 05:57 PM   #158
FA20Club.com
Drives: 2013 White Out FR-S
yup thats why we tap all the garrett covers unlike the precision that come with a fitting already.
FA20Club.com is offline   Reply With Quote
Old 04-01-2013, 08:23 PM   #159
Frs300
Frs300's Avatar
Drives: Pile of junk
Thank you fa20club!!!!!
cant wait to get the car back
Frs300 is offline   Reply With Quote
Old 04-01-2013, 08:29 PM   #160
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
Akuhei's Blog
"Inconceivable"
akuhei is offline   Reply With Quote
Old 04-01-2013, 08:34 PM   #161
Frs300
Frs300's Avatar
im sending it to them
The Following 2 Users Say Thank You to Frs300 For This Useful Post:
akuhei (04-01-2013), Sportsguy83 (04-02-2013)
Old 04-01-2013, 09:03 PM   #162
nelsmar
I could have missed it but did anyone mention if the correct fuel injectors were installed? I had this happen once... Took me a number of pulls to figure out why i was maxing my injector cycle so quickly. It took me about a week before i finally yanked the injectors and realized the 550cc i thought i had were 275's. ( i was messing with the pump, lines, filter, fuel fail...). I felt pretty stupid that i didn't verify before installing. Luckily though the engine didnt go out from it, throttle was cut the moment it started leaning out.
My flickr - Canibeat
Local magazine scout
Old 04-01-2013, 09:22 PM   #163
Inline6
Drives: Single Turbo Supra
The main problem here is that no safeguards were in place. No data logging, no wideband, no boost gauge(which is never ok on forced induction applications), running on a basemap, and pushing the car too hard before its ready.
Not only will you have no idea what the car is doing but you will also have no idea of how to prove what went wrong.
On a High CR motor you have to be extra cautious,like baby steps. Losing traction in first and shifting into second doesn't exact sound like you were taking it easy before you knew it was safe to push it.
I hate it for you ,but if you start mixing boost and high compression then you damn sure better make sure everything is perfect before blasting on it.
Inline6 is offline   Reply With Quote
The Following 2 Users Say Thank You to Inline6 For This Useful Post:
Archetype (04-01-2013), NJA (04-03-2013)
Old 04-01-2013, 09:25 PM   #164
Archetype
Archetype's Avatar
Drives: 2013 BRZ Turbo, 2013 FRS
Amen
Archetype is offline   Reply With Quote
Old 04-01-2013, 09:36 PM   #165
Frs300
Frs300's Avatar
nobody mentioned it but they were correct ones
i had drove it around for almost 100 miles before i got on it good. but yes you are correct in a way it is my fault for not having my failsafe installed
Old 04-01-2013, 09:37 PM   #166
Noob4Life
86 Noob
Drives: Firestorm FR-S
So are we saying running a basemap is not okay? I plan on going with an fa20 club setup and their basemap. I planned on running just the basemap because I dont know of any tuners in my area. I live in a crappy town
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Noob4Life is offline   Reply With Quote
Old 04-01-2013, 09:43 PM   #167
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
I think if you are going to pay $5000 (+$ for install) for a turbo kit on your $27000 car you should be able to pony up another $200 for a custom tune... I think the point of the base map is so you can drive the car safely after install to get tuned. I'm sure there is a decent tuner near you. I've driven to San Fransisco from LA to get tuned before.
industrial is offline   Reply With Quote
The Following User Says Thank You to industrial For This Useful Post:
coyote (04-01-2013)
Old 04-01-2013, 09:44 PM   #168
Frs300
Frs300's Avatar
basemap is fine just dont do what i did and hold off on installing a boost gauge of some sort. install it from the get go..hell i had my wideband/failsafe and shit in the back seat in the box so its not like i didnt have one.
me being lazy turned into almost 10K $$$$$$
The Following User Says Thank You to Frs300 For This Useful Post:
EAGLE5 (04-02-2013)
Swapping the motor. Either 3uz or 2gr diss7 Engine Swaps 34 11-16-2015 04:31 PM
Motor swaps.. Brian S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-19-2012 04:18 PM
BMTV (Best Motor TV) HKS vs TRD vs 86 KyShro FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 05-09-2012 10:48 AM
Will Lotus use the FR-S motor? muffinman Other Vehicles & General Automotive Discussions 26 01-20-2012 09:24 PM
