go_a_way1
Old 08-01-2013, 11:47 PM   #1653
djdnz
1337
Drives: 2013 BRZ WRB S/C
Originally Posted by ill86 View Post
It will actually understeer (inherently) more. Not oversteer. A square setup will oversteer easier than a staggered. Same with increasing rear track width.
However, there are many other factors that can be adjusted.
Typo on my end!! Yes understeer, I will fix my post.
djdnz is offline   Reply With Quote
Old 08-02-2013, 01:16 AM   #1654
tdotBRZ
tdotBRZ's Avatar
Drives: 2014 BRZ Limited SWP 6MT
Smile wheel+tire debate
Quick question on the tire debate, wondering if you could possibly help me out here
I'm planning on getting Eibach Sportline springs (-1.4" drop) along with Rota Grids or Varrstoen ES2 18x8.5 front, 18x9.5 back. By the way what do you think between the 2 wheels which is better?
And my main question is about the tires for that staggered setup, front 225/40 or 235/35 and back 245/35 or 255/35, what are the advantages and disadvantages of each and which is better? And will I have any rubbing issues with this setup?
Thanks in advance. Much appreciated!!
tdotBRZ is offline   Reply With Quote
Old 08-02-2013, 02:56 AM   #1655
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Volk TE37 made by Rays Engineering is "better"..
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 08-02-2013, 10:00 AM   #1656
tdotBRZ
tdotBRZ's Avatar
without a doubt they are, but this is my DD and cant afford to be riding on gold right now as Volks are 3 times more expensive
The Following User Says Thank You to tdotBRZ For This Useful Post:
ill86 (08-02-2013)
Old 08-02-2013, 01:12 PM   #1657
Karl07
Drives: 2012 86 GTS - Storm Black
Originally Posted by djdnz View Post
You can't rotate them and they will tend to understeer more than if you had square, but with so much front grip you probably won't notice anyway lol.
285's though, are you turbo? Those are wide tires you're looking at.
No it's currently not. Down the track I'll be looking at power, but for now im starting with the platform for handling (wheels, suspension, brakes, bracing).
I was looking at 285s because that's what I was told for the 18x9.5 rear.
And to slick, I was referring to different brands. I have no issue with different sizing, as I purposely bought staggered. But it's just near impossible to find good, non-semi-slick tyres that make both sizes.
Karl07 is offline   Reply With Quote
Old 08-02-2013, 04:05 PM   #1658
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Whatever you do, don't mix brands. Find one you can fit on front and rear (why I love to run square setups). When you start mixing there are too many variables down to rubber compound that reacts differently to temp changes, tread patterns, and so on...
Gone are the days my dad would run knobby winters tires on the rear of his 60's Pontiac Parisienne with all-seasons up front.
As for sizes, I would go for 245/35 up front and 255/35 in the rear. 265 would be larger still and without boost your acceleration will be affected by the taller gearing (not including the additional weight of the larger rubber).
IMO, 285 is overkill unless you're looking at stance/looks (which is okay) or need the extra traction from power adders.
Slick is offline   Reply With Quote
The Following 2 Users Say Thank You to Slick For This Useful Post:
ill86 (08-03-2013), Karl07 (08-04-2013)
Old 08-03-2013, 01:42 AM   #1659
jshadeck
jshadeck's Avatar
Drives: 2013 Scion FR-S Whiteout 6MT
I agree. A 285 will make ur car look faster but will almost definitely make it slower. Stock power, im running a 18x9.5 235 square setup w a gforce tire and on the street (i push my car on the street sometimes on windy roads) i definitely dont need any more traction. Obviously tire choice has just as much to do with that as tire size, just my $0.02
jshadeck is offline   Reply With Quote
The Following User Says Thank You to jshadeck For This Useful Post:
ill86 (08-03-2013)
Old 08-03-2013, 10:36 AM   #1660
ill86
ill86's Avatar
Drives: iG FR-S
Too much tire and/or wheel is the most common modification error on 86.
Keep wheel weight and tire weight down. Compare specs when shopping for tires. Cross reference with the Tire Rack and tire manufacturers.
Old 08-04-2013, 03:04 AM   #1661
Karl07
Thanks guys.
I want the looks, but I'd prefer the performance more.
That's why my mod list is starting with handling, then a bit of looks, then power when my warranty is out.
Those tyre sizes make it a lot easier...toyo, Michelin, Pirelli, Bridgestone, and heaps more do both...it seemed that 285 was rare as.
Old 08-04-2013, 10:44 AM   #1662
terenshu
Drives: rav4
hello! just would like to know if im going to have any problems with this setup, if yes suggestions would be greatly appreciated! im aiming for something that is close or better to stock performance and ride quality.
aiming for 225/45/17 17X7.5 e40 with eibach pro springs.
thank you!
terenshu is offline   Reply With Quote
Old 08-04-2013, 11:11 AM   #1663
Slick
Slick's Avatar
thank you!
No problems, not too different from the factory setup so just choose good tires an you'll see a nice improvement.
Old 08-04-2013, 02:24 PM   #1664
Willow
Drives: Subaru BRZ ltd
Thanks for all the help and info!
Willow is offline   Reply With Quote
Old 08-07-2013, 06:51 AM   #1665
white_knight
white_knight's Avatar
Drives: 2013 86 GTS - Pegasus White
Hey guys!
I need your help regarding my new staggered setup:
Wheels/Tyres
Rays Gram Lights 57Xtremes
18x8.5 +33 / 225/40/18 (F)
18x9.5 +40 / 255/35/18 (R)
Suspension
Eibach Pro Kit (1" drop)
At the moment, there is some poke going on. It could also do with a little more drop (about half an inch) so I've bought a set of Eibach Sportlines to do the trick.
My question is, do you think the extra 0.5" drop would sort out the poke? Or would you recommend I get camber bolts?
Thanks in advance
white_knight is offline   Reply With Quote
Old 08-07-2013, 11:44 AM   #1666
ill86
ill86's Avatar
Drives: iG FR-S
Originally Posted by white_knight View Post
Hey guys!
Wheels/Tyres
Suspension
Thanks in advance
That's difficult to answer without hard data..
Did you align after pro kit?
How much poke in mm?
How much camber currently?
What are your goals?
If I'm forced to guess, no, you will not fix the poke with your new spring selection.
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
