Tracking / Autocross / HPDE / Drifting What these cars were built for! |
05-23-2016, 11:52 AM | #141 |
Dismember
Drives: 2013 Red Scion FR-S
The safety side is really expensive. Don't forget a fire extinguisher. You can get a Lemons/Chumpcar for $2-4k with a fully built, welded cage and a lot of development time put in. For $10k, you can get a track car that will outpace almost every twin.
05-23-2016, 12:06 PM | #142 |
Drives: 2013 Scion FR-S Firestorm
That's a good point. And $10K is basically also the amount I mentally told myself I didn't want to go past for the complete job. But I was only estimating costs in my own mind and didn't know how realistic it was. The thing is, I have so much invested in the FRS already. And I have expenses like a BBK and wheels and tires that I never would have bought and installed if I wasn't doing track events with the car. And I LIKE the car. It's so well balanced and I think it's a great car with which to build skill and experience. So i don't want to go and buy another track car where I'm going to have to learn all of it's own particular idiosyncrasies all over again. Like I said, I don't really turn wrenches. Aside from simple things. And I don't really enjoy that aspect of it. I just want to drive. So I'd rather stick with my car so long as I can work it within my budget.
05-23-2016, 02:32 PM | #143 |
Dismember
Get a dolly. Tow the car backwards. Things WILL break. That's what going fast does to cars.
05-23-2016, 03:30 PM | #144 | |
Drives: Nevermorange FRS
I bought my 2003 Expy for $3800. Spent another $1800 on tune-up, brakes, ECU Tuner and fresh fluids. Pulls my 7500lb 20' fully loaded enclosed just fine. Tow capacity is 8600lbs with W/D hitch. I think if you had $8k you could find a very decent vehicle to pull 7500+lbs. You'd be surprised what the tow rating is on some vehicles when you include a towing package and correct diff gearing. Navigator, Expedition, Armada, Titan, Tundra, Durango etc. You don't need a crazy big diesel pusher to tow. Stay within your tow vehicle's capacity, use a W/D hitch with sway control (like the Equalizer), keep trailer tires inflated to maximum rated pressure when cold and don't exceed 65mph. There isn't a single Trailer Tire rated for speeds above 65mph.
SCCA T4 - FRS
05-23-2016, 05:40 PM | #145 | |
So we're buying a Highlander. It's not ideal but it's a compromise. Frankly it's bigger than my wife wanted. And a bit smaller than I would have liked for towing. But it's middle ground we can both live with. And at least this way I'm getting started. One step at a time. |
The Following User Says Thank You to jjaisli For This Useful Post: | ZionsWrath (05-23-2016) |
05-24-2016, 09:49 AM | #146 | |
Drives: 2004 Toyota RAV-4 5M
You can definitely save some money by stripping the interior of the car your self. I did almost all of mine (I ended up paying someone to strip the dash and HVAC system as I was running out of time before my first track event) and I was kind of surprised at how easy it was. The front seat bolts can be a pain (they are some sort of weird reverse-torx nut) and I ended up stripping one of them when I was trying to use a breaker bar. I ended up buying an impact wrench and the rest came out with no issues though. As for what to strip, it really comes down to how far you want to go. I went pretty much all the way with my car (you can see most of it in the video I will link below) and removed all the interior, dash, and HVAC system in my quest to save weight. The funny thing is I only lost maybe 20lbs due to the weight of the cage. Anyways, if you are going for a full roll cage you will probably need to have all the interior panels, carpets, headliner, removed and you will have to at least temporarily remove the dash. Many people put the dash back in with a few minor modifications to allow the roll cage to pass through it. I think I ended up spending close to $7,000 on safety equipment this year doing pretty much everything you described: Roll cage (which does pass NASA specs): $2600, which included custom seat mounts because I was too tall for the standard Sparco seat mount. Seats, harnesses, HANS, helmet, steering wheel: ~$3,300 if I remember correctly Various labor for dash removal, seat and harness install, roll cage painting: Around $1000 All safety equipment I ordered from OG Racing and if you want contact info for my cage guy, feel free to PM me. He operates out of western MD, pretty close to Summit Point. Here's the video of my car from this weekend at VIR: [ame="https://www.youtube.com/watch?v=xQAMailfcmA"]Fastest Lap @ VIR - 2:11.232 - YouTube[/ame] My strip job is probably more of the crowbar variety though |
The Following User Says Thank You to ja1217 For This Useful Post: | jjaisli (05-24-2016) |
05-24-2016, 11:36 AM | #147 |
Hi Josh. Of course I remember you. Nobody forgets the 'fast' guys.
This was extremely helpful as you've essentially gone through the same process and we both live (relatively) in the same region. I'm happy to know my seat of the pants estimate wasn't too far off the mark. Considering that I'd probably like the dash put back in (I have visions going to grab the next gear and having my hand tangled up in that mess of wires) and I'd prefer to have a few custom bezels for the doors, I was probably right to estimate a bit higher. But at least I know I wasn't off in fantasy land with a maximum $10K cap from start to finish. I'm actually going to be down at VIR in less than 2 weeks. But I won't be trying to equal that time. Just out of curiosity, is the speed off a bit on the display or did you change the gearing or were you just short shifting? I've never seen you go into 6th. EDIT: I'm actually kind of surprised that you only dropped 20-lbs after removing all the trim and radio and AC and going with lighter seats. I guess I was just underestimating the weight of the cage. Do you notice a big difference in the way the car responds with the additional chassis bracing? |
05-24-2016, 12:24 PM | #148 | |
The roll cage definitely stiffened the chassis up and the proper fixed seats really help transfer the feeling of the car moving about underneath you. I have found my self being able to anticipate the cars behavior much better than I have before and with the addition of the rear wing and splitter, the car feels more hooked up then ever before, even in the slow turns where there isn't much advantage from the aero. As for the weight, I still have some room to go and might be able to get another 100lbs. out of it by doing things like stripping out the doors (crash supports, power windows, etc), removing unnecessary wiring, maybe replacing the bumpers with aluminum or something light (need to look into the safety aspects of this more thought). I wish I had the cash to go for carbon fiber replacement parts, but that stuff is just so expensive. |
05-24-2016, 01:44 PM | #149 | |||
I'd still prefer a dash though. LOL |
05-24-2016, 01:55 PM | #150 | |
05-24-2016, 03:40 PM | #151 | |
Drives: Used to Drive:Grand-Am GS #54 E36M3
You sound like an upper intermediate driver: capable of going pretty fast, but without the experience and skills necessary to anticipate and deal with potential problems. This is a stage most drivers go through. My own thinking on this subject is that besides experience, it is car control skills that are lacking, and that the race track is not the place to learn them. After I ruined my car, I began an intensive effort to improve my skills. I did this at the 4-day course at the Team O'Neil Rally School, with a pro driver in the winter at Toronto Motorsports Park, with the same pro in the summer on a wet skid pad at Shannonville, and at multiple winter car control clinics put on in the Northeastern US by Audi clubs. Really, any opportunity to practice car control on a slippery surface at speeds that allow you to build your skills is worth the investment. Additionally, they are a ton of fun, and you meet good people. While my talent for this hobby is average at best, I credit all that effort with saving me during a full-on tank slapper at T6 at the Glen in 2013. Even at the time, I didn't know what I did to save it, but save it I did, staying on-line and dropping only 12 MPH in the process. In the middle of it, when I was once again staring straight at the Armco, I had the momentary thought "Oh, nooooo, NOT AGAIN!!!" |
The Following 3 Users Say Thank You to dradernh For This Useful Post: |
05-24-2016, 04:22 PM | #152 |
Drives: 13 Subaru BRZ, 02 Audi TTQ
Just curious which ones you went to, I go to most of them every year. I bring my TT though.
05-24-2016, 04:40 PM | #153 | |
I said "clubs", but I should have said "club", as I've never made it to the NEQ events: http://www.neqclub.org/. They are a great group as well. |
05-24-2016, 04:42 PM | #154 | |
Drives: 2013 WRB BRZ 6MT
It's funny you mentioned Shannonville because that off track event was on turn 4 of the long track there. Going too fast caused me to track out too far and I hit the dirt on the exit with my rear wheel. A rut right there caused the rear to go up when the tire hit pavement again and I started to slide the opposite direction, right towards the tire wall. |
