Old 07-19-2014, 10:49 AM   #141
WNDSRFR
Drives: FR-S,GTI
I'm ready. Got 30 gallons of E waiting to be burned.
The Following 2 Users Say Thank You to WNDSRFR For This Useful Post:
DAEMANO (07-19-2014), raven1231 (07-19-2014)
Old 07-19-2014, 10:50 AM   #142
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Awesome.
Installed Mods:
Old 07-19-2014, 04:00 PM   #143
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
OFT: v2.0 E85 Beta (USDM 6MT only) now available for download
Hi guys,
E85 maps are now available for ESC 1.5+OFH. I've just added an E85 folder to the download. As with all v2.0 maps, they are based on the newest B01C ROM. They are currently on available for USDM 6MT. USDM 6AT will follow soon.
For the sake of beta testing, when first switching over to E85, run your tank close to empty. This means the needle should be below E (well after the low level light comes one). After for your first tank of straight E85, you don't need to be as strict (the tune will adapt down to E60 without any problem).
Also for the first time, flat-foot-shift is enabled as DEFAULT. Just because it's really fun. I set it up to only activate when shifting past 6500rpm. So if you want to experience it, just flat-foot shift at 7000-7500rpm. This means just clutch-in between shifts but stay WOT (don't lift off the throttle). It will grab the next gear with boost and a good deal of ferocity
Enjoy!
Cheers,
shiv
The Following 9 Users Say Thank You to Shiv@Openflash For This Useful Post:
DAEMANO (07-19-2014), fenton (07-19-2014), Jac (07-19-2014), Robftss (07-19-2014), shif7i7down (07-19-2014), Sojhinn (07-19-2014), TM (07-19-2014), WNDSRFR (07-20-2014), WRB5titch (07-19-2014)
Old 07-19-2014, 04:13 PM   #144
TM
TM's Avatar
Drives: DGM BRZ 6MT
Originally Posted by Shiv@Openflash View Post
Hi guys,
Enjoy!
Cheers,
shiv
Awesomeeeeee. I just filled my tank, so another week before I can test it out. Can't wait!
TM is offline   Reply With Quote
Old 07-19-2014, 04:17 PM   #145
raven1231
[QUOTE=Shiv@Openflash;1854944]Hi guys,
For the sake of beta testing, when first switching over to E85, run your tank close to empty. This means the needle should be below E (well after the low level light comes one). After for your first tank of straight E85, you don't need to be as strict (the tune will audapt down to E60 without any problem).
Enjoy!
Cheers,
shiv[/QUOTE
Woot ill be testing tonight
Old 07-19-2014, 04:17 PM   #146
Sojhinn
Sojhinn's Avatar
Hi guys,
Enjoy!
Cheers,
shiv
I'm around a 1/3 so soon for me.
Installed Mods:
Old 07-19-2014, 04:39 PM   #147
jflogerzi
jflogerzi's Avatar
I want opinions now! All in seriousness guys who have the 1.5 dump and e85 post your impressions
Sent from my SGH-T999 using Tapatalk
2013 Series 10 FRS #553
Old 07-19-2014, 04:42 PM   #148
jflogerzi
jflogerzi's Avatar
@Shiv@Openflash can you describe the difference in pull between the ecs 1.5 dump with e85 and the speed by design kit with 91 and the oft tune.
Old 07-19-2014, 04:44 PM   #149
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
I'm at 1/4 and have some driving to do tonight, so I may fill up with E85 this evening. I'll post back if I do. If not, Monday night.
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
The Following User Says Thank You to enwave For This Useful Post:
jflogerzi (07-19-2014)
Old 07-19-2014, 05:28 PM   #150
raven1231
I'LL POST RESULTS TONIGHT!
Old 07-19-2014, 06:18 PM   #151
DAEMANO
Time Traveller
Hi guys,
Enjoy!
Cheers,
shiv
Will post all!!
THANKS SHIV
Old 07-19-2014, 07:15 PM   #152
WRB5titch
Drives: WRBrz
Woooooo I'm at a Quarter tank left. Shouldn't be any problems getting that down to empty heheheeh
EBSC - dt.FF - MXP CompRS
WRB5titch is offline   Reply With Quote
The Following User Says Thank You to WRB5titch For This Useful Post:
Old 07-19-2014, 08:41 PM   #153
shif7i7down
Erected Member
Drives: frs
Still at half tank, I'm beginning to think it might be easier Just to siphon the gas out and use it for the lawn mower..
Really want to see what i can do on Gtech.
shif7i7down is offline   Reply With Quote
Old 07-19-2014, 08:42 PM   #154
raven1231
On my way to get some maize
Phantom TQ250 Dyno FBO (Dual Battery Pack) Shiv@Openflash Forced Induction 23 04-29-2014 02:40 AM
Clutch dump at 5000 RPM? fasteddy BRZ First-Gen (2012+) — General Topics 20 08-22-2013 01:55 PM
External dump and under tray? mrk1 Forced Induction 5 07-30-2013 09:43 AM
Photo dump. CanibeatNoel FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 07-17-2013 02:47 AM
Ricepuddin Picture Dump Ricepuddin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 15 12-03-2012 12:18 AM
