#141 |
Drives: FR-S,GTI
I'm ready. Got 30 gallons of E waiting to be burned.
#142 |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#143 |
Drives: 2013 FRS
OFT: v2.0 E85 Beta (USDM 6MT only) now available for download
Hi guys,
E85 maps are now available for ESC 1.5+OFH. I've just added an E85 folder to the download. As with all v2.0 maps, they are based on the newest B01C ROM. They are currently on available for USDM 6MT. USDM 6AT will follow soon. For the sake of beta testing, when first switching over to E85, run your tank close to empty. This means the needle should be below E (well after the low level light comes one). After for your first tank of straight E85, you don't need to be as strict (the tune will adapt down to E60 without any problem). Also for the first time, flat-foot-shift is enabled as DEFAULT. Just because it's really fun. I set it up to only activate when shifting past 6500rpm. So if you want to experience it, just flat-foot shift at 7000-7500rpm. This means just clutch-in between shifts but stay WOT (don't lift off the throttle). It will grab the next gear with boost and a good deal of ferocity ![]() Enjoy! Cheers, shiv |
#144 | |
Drives: DGM BRZ 6MT
Awesomeeeeee. I just filled my tank, so another week before I can test it out. Can't wait! Sent from my iPhone using Tapatalk
#145 |
[QUOTE=Shiv@Openflash;1854944]Hi guys,
E85 maps are now available for ESC 1.5+OFH. I've just added an E85 folder to the download. As with all v2.0 maps, they are based on the newest B01C ROM. They are currently on available for USDM 6MT. USDM 6AT will follow soon. For the sake of beta testing, when first switching over to E85, run your tank close to empty. This means the needle should be below E (well after the low level light comes one). After for your first tank of straight E85, you don't need to be as strict (the tune will audapt down to E60 without any problem). Also for the first time, flat-foot-shift is enabled as DEFAULT. Just because it's really fun. I set it up to only activate when shifting past 6500rpm. So if you want to experience it, just flat-foot shift at 7000-7500rpm. This means just clutch-in between shifts but stay WOT (don't lift off the throttle). It will grab the next gear with boost and a good deal of ferocity ![]() Enjoy! Cheers, shiv[/QUOTE Woot ill be testing tonight
#146 | |
I'm around a 1/3 so soon for me.
#147 |
I want opinions now! All in seriousness guys who have the 1.5 dump and e85 post your impressions
Sent from my SGH-T999 using Tapatalk
2013 Series 10 FRS #553
#148 |
@Shiv@Openflash can you describe the difference in pull between the ecs 1.5 dump with e85 and the speed by design kit with 91 and the oft tune.
#149 |
That headunit though...
Drives: 2013 Subaru BRZ Limited SSM
I'm at 1/4 and have some driving to do tonight, so I may fill up with E85 this evening. I'll post back if I do. If not, Monday night.
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300 Eibach Pro-Kit + Michelin PSS (stock size) |
| The Following User Says Thank You to enwave For This Useful Post: | jflogerzi (07-19-2014) |
#150 |
I'LL POST RESULTS TONIGHT!
| The Following User Says Thank You to raven1231 For This Useful Post: | jflogerzi (07-19-2014) |
#151 | |
Time Traveller
![]() Will post all!! THANKS SHIV |
#152 |
Drives: WRBrz
Woooooo I'm at a Quarter tank left. Shouldn't be any problems getting that down to empty heheheeh
EBSC - dt.FF - MXP CompRS
| The Following User Says Thank You to WRB5titch For This Useful Post: | raven1231 (07-19-2014) |
#153 | |
Erected Member
Drives: frs
![]() Really want to see what i can do on Gtech.
#154 |
On my way to get some maize
| Phantom TQ250 Dyno FBO (Dual Battery Pack) | Shiv@Openflash | Forced Induction | 23 | 04-29-2014 02:40 AM |
| Clutch dump at 5000 RPM? | fasteddy | BRZ First-Gen (2012+) — General Topics | 20 | 08-22-2013 01:55 PM |
| External dump and under tray? | mrk1 | Forced Induction | 5 | 07-30-2013 09:43 AM |
| Photo dump. | CanibeatNoel | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 11 | 07-17-2013 02:47 AM |
| Ricepuddin Picture Dump | Ricepuddin | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 15 | 12-03-2012 12:18 AM |
