Old 06-02-2014, 10:53 AM   #141
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
so after a double header at an airport, with pyrometer testing and logging, the R1R's in 235/40 seemed to like to be around 38 hot...
does this match the experience of others?
Old 06-02-2014, 01:44 PM   #142
rx3
I have the Toyo R888 in 235/40 17 on 8" wide rims and run them at 31 psi (hot) and 35 psi when it's wet. Oftentimes the rear tires don't get as hot as the front tires, so I usually run them at a higher pressure.
What rims and tires (size and type) do the CSP guys run?
rx3 is offline   Reply With Quote
Old 06-02-2014, 02:14 PM   #143
SeanRTR
C-Street AutoX
SeanRTR's Avatar
I thought people were running high 20's / low 30's on R1R's...
Did you get your set shaved or running at full depth?
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
Old 06-02-2014, 02:26 PM   #144
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
I'm not aware of any attempts at a CSP build to-date. I don't expect anyone to make any real effort at this for 3 reasons:
1) CSP is spec-miata class, general consensus is the twins don't have a prayer.
2) A legit build really makes the car pretty much un-streetable and means you have to modify body work to fit appropriate tires.
3) All signs point to SP being the next rule set and classing structure to get completely re-vamped very soon... maybe even displaced in favor of "prepared light" intermingling in prepared classes and/or increased SM classing structure.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
The Following User Says Thank You to Sccabrz192 For This Useful Post:
rx3 (06-03-2014)
Old 06-02-2014, 02:35 PM   #145
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
-1.3/-1.2 camber, 0 toe front, -1.1/-1.1 camber, 1/16th toe in rear, using an IR Pyrometer i was getting colder readings in the center of the tire compared to the outer and inner parts... basically telling me that i need more air
38psi is where they seemed to have balanced out
measurements were taken less than 15 seconds after the completion of a run and with no cone stop box no hard braking was performed at the end.
also 20psi hot? what? lol
Old 06-02-2014, 07:13 PM   #146
mrazny
Drives: BMW 135i, soon to BRZ
Anything you do towards CSP would translate upward into SM...
mrazny is offline   Reply With Quote
Old 06-03-2014, 07:01 PM   #147
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
Where you can then get slaughtered by cheating-bastard-AWD cars like the Evo and GTR.
neurokinetik is offline   Reply With Quote
Old 06-03-2014, 07:26 PM   #148
vroom4
No matter what psi I run on race tires/street tires I always have a near cold inside shoulder. How are you using that part of the tire at all?
vroom4 is offline   Reply With Quote
Old 06-03-2014, 07:36 PM   #149
renfield90
The Stig's German cousin
How much camber do you have?
It's also worth noting that depending on the brand, an IR pyrometer measures a fairly large circle for heat. Not knocking 7th gear's methods at all here, he's shared a ton of valuable data for us all, but a probe pyrometer is usually better. (I just acquired one, if I get anything useful out of it I will share.)
See point number 1 here: http://www.thermoworks.com/blog/2012...d-thermometry/
Points 2 and 3 are irrelevant if you're always measuring the same tire compound and are only trying to ensure that temperatures are even across the tire.
Old 06-03-2014, 08:25 PM   #150
vroom4
I am maxed on stock crash bolts...like the rest of us. I think I got -1.2 on both sides. Seriously, my tires are ready to be flipped on the rim, the inside shoulder is brand new.
Old 06-03-2014, 09:29 PM   #151
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Originally Posted by renfield90 View Post
IR pyrometer measures a fairly large circle for heat..
please note that I was getting down on my knees to do the dirty work
so I was measuring about an inch away from the tire.
most def, but only if your goal is to get accurate readings in terms of absolute temperatures
otherwise, the IR Pyrometer is a great tool to quickly asses the relative distribution of the temperatures. ie, I'm not overly concerned as to what the core tire temperature is, the short stints combined with a lack of any real ability to tune the car means that I've only pressures to play with,
for this, an IR tool is great to quickly figure out whether you've got too little or too much
if you are under inflated the center will be colder or same temp as the inside. I was going off 30 cold, which is what I read online, and it wasn't until I got to 38-39 hot (which translated into around 34 cold) that I was getting the center to start working more.
Old 06-03-2014, 09:33 PM   #152
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
food for though: you could be overdriving your car.
Too much steering input and hard braking during the wrong time could lead to premature tire wear.
but I don't know you as a driver so hard to judge,
Old 06-04-2014, 01:04 PM   #153
mrazny
http://scca.cdn.racersites.com/prod/...s%20FINAL1.pdf
SM, the ruleset that let's you do anything, cheating? Also, slaughter? Oh you meant you'd get slaughtered because you haven't developed to the limit of the class like Panda did, and the twins should just be given classes that they don't need to spend time developing within?
Old 06-05-2014, 06:24 PM   #154
neurokinetik
Ya got me, I must have been thinking of Pro Solo, where AWD has such a huge advantage.
As for the cheating bastard AWD comment, that goes way back to the Audi in Trans Am days, where AWD was banned because it worked too well and was deemed an unfair advantage. I rib my friends for their cheating bastard AWD and their cheating bastard turbos all the time (the latter because of the history of turbo boost level not being policeable in pretty much any form of motorsport).
SCCA Solo C Street Discussion Kido1986 Tracking / Autocross / HPDE / Drifting 4831 07-08-2020 04:52 PM
Let's discuss SCCA Stock Class ayau Tracking / Autocross / HPDE / Drifting 314 04-18-2013 03:03 PM
SCCA RTR Vs C stock theredtape Tracking / Autocross / HPDE / Drifting 7 03-27-2013 04:26 PM
Motion Control Suspension Singles---SCCA Stock legal are done! Sam Strano Tracking / Autocross / HPDE / Drifting 25 01-16-2013 03:42 PM
2012 BRZ/FR-S Stock Class Autocross Discussion EMguy Tracking / Autocross / HPDE / Drifting 183 01-04-2013 04:17 AM
