Old 05-15-2012, 09:31 PM   #1
EMguy
2012 BRZ/FR-S Stock Class Autocross Discussion
This is probably a little early as the BRZ/FR-S hasn't been classed yet, but it seems a good idea to have a single thread for those competing in stock class autocross.
Here's a quick run down of the hight points of the rules: Link to 2012 rules
-Stock sized wheels (17x7) with +/- 0.25 in (6.35mm) of offset allowance
-Shocks with up to two external adjustments (with stock springs)
-Substituion/removal of either the front or rear sway bar (but not both)
-If offered by the manufacturer, crash bolts are legal (Please Subaru/Scion!)
-Provided it passes sound, exhaust is free after the cat.
-A few other odds and ends
Tires:
The 245/40/17 A6 seems like the natural fit. 225/45/17 and 225/40/17 are other options if the front inboard strut clearance proves too tight.
Any thoughts?
EMguy is offline   Reply With Quote
Old 05-15-2012, 10:53 PM   #2
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
I'll be competing stock class if/when I no longer have a seat in the solstice. I'm reserving all decisions on modifications until I atleast have the car, take some measurements and take a few runs. I dont like making changes until I have a baseline... The only exception to that is wheels... Which as mentioned in the other thread, not a lot of options at the moment. Though I will say i anticipate the 225/40 being fairly useless, sounds like the car is gearing challenged and a shorter sidewall will make it worse.
Sccabrz192 is offline   Reply With Quote
Old 05-15-2012, 11:08 PM   #3
EMguy
Stock Class Legal Wheels
I'm copying over some info from another thread. I'll do my best to keep a running list of some of the stock sized wheels that would work well for autocross.
The stock class rules allow +/- 0.25 in (6.35mm) in offset. So any offset between 42 and 54 is legal. Spacers can be used to acheive maximum offset allowance. Given the relatively tight inboard clearance to the front strut and the fact that you'll want to stuff as much tire as possible in there, I'm thinking that shooting for a 42-43mm offset is probably a good idea.
Lightweight Wheel Options in 17x7, 5x100, ET 42-54:
-Kosei K4R (14 lbs)
-Buddy Club P1 Racing SF (17.4 lbs)
-Team Dynamics Pro Race 1.2 (17.3 lbs)*
-Motegi Traklite 1.0 (14.5 lbs)
*These won't be in stock in the right size, but TD will custom make individual orders to your specs with a 6-8 week lead time. They're reasonable priced, and 17.3 lbs.
Old 05-15-2012, 11:35 PM   #4
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Following bill's lead, you do have some rota options...
GR-A, Boost, and circuit 10 are available in +48
Subzero in a +45
Ill edit this Post if i find others.
Old 05-16-2012, 07:24 AM   #5
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Originally Posted by Moto-P View Post
I can't disclose what's in plan at HRE yet, but something VERY nice for the FRS/BRZ is coming yes
Ideally though, for race track use, I like to use probably something like 18x8.0 or 8.5, with TRD N1/Taikyu- specified tire size of 225/40ZR18 +45~48 on all four to keep the inherent balance and alignment data.
For street, just about anything goes as I am of the 80's tuner mentality, and I like them low, flush, and functional... The last word 'functional' being the key word though. not mad camber and not hellaflush widebody ride on sidewall craziness...no.. LOL! So perhaps a 18x9? 19x9? slightly pulled tire and agressive offset of about +30 on deep rim 3 piece? I dunno. I'm curious what HRE will pull out of the bag (though they are not casually affordable by any means), as well as new line from Volk, Work, SRR, and Enkei as well for this car rumored. Pro-Drive in white would be nice and racy too though!
There seems to be more options coming.. ummmm HRE...$$$$$$
Scooby South is offline   Reply With Quote
Old 05-16-2012, 07:35 AM   #6
Dark_Angle
Dark_Angle's Avatar
Drives: 91 Turbo Mr2
So this means that you cannot go to a 17x8 wheel in the stock class?
Dark_Angle is offline   Reply With Quote
Old 05-16-2012, 07:39 AM   #7
Scooby South
Conedancer
true....you never could...you have to run the Stock Size wheel..in this case 17x7... 17x8 would put you into street touring...
Bill
Old 05-16-2012, 07:40 AM   #8
MTeator
First 86
Nope... Have to stay stock dimensions... You can only play with offset a bit.
Scion First 86 in Lexington KY - Firestorm 6MT - Delivered May 17, 2012
Mods: Motegi 17x7 TrakLites, BFG Rivals, K&N 33-2300 Filter, Nameless Perf. Track Pipe, TRD springs & rear bar, Hotchkis front bar (eh), Kask trailer hitch
MTeator is offline   Reply With Quote
Old 05-16-2012, 07:47 AM   #9
Dark_Angle
Dark_Angle's Avatar
So what class would this boot me to? Theoretically
Old 05-16-2012, 07:48 AM   #10
Dark_Angle
Dark_Angle's Avatar
Sorry I posted too soon. Thanks Scooby South
Old 05-16-2012, 07:48 AM   #11
Scooby South
Conedancer
Whatever Street tire class it gets assigned... assuming right now...STX
Bill
Old 05-16-2012, 09:07 AM   #12
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Based on those comments id be surprised if hres were in a stock legal size.
Old 05-16-2012, 10:00 AM   #13
AX_FRS
Drives: 05 Ford Focus ZX4
Would it be a good idea to get an oil catch can? I heard that the boxer engine has an especially hard time with blow-by. Any thoughts on this?
AX_FRS is offline   Reply With Quote
Old 05-16-2012, 10:04 AM   #14
Scooby South
Conedancer
not necessary...unless you plan to boost the motor...I am pretty confident that the Factory Breather system is sufficient for the 12.5:1 compression the engine is producing...
Bill
Which autocross class? jpdarty7 Tracking / Autocross / HPDE / Drifting 66 06-21-2012 05:53 PM
FORMULA D Round 1 Long Beach 2012 Discussion Thread Kids Heart Off-Topic Lounge [WARNING: NO POLITICS] 0 04-08-2012 02:43 AM
GT5 Stock GT86 Competition - March 2012 Deslock Off-Topic Lounge [WARNING: NO POLITICS] 34 04-01-2012 07:39 AM
2012 Mercedes A-Class Revealed ZetaVI Other Vehicles & General Automotive Discussions 12 03-06-2012 02:15 PM
GT5 Stock GT86 Competition - February 2012 Deslock Scion FR-S / Toyota 86 GT86 General Forum 100 03-01-2012 07:14 AM
