Old 03-20-2013, 11:59 PM   #141
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Originally Posted by b$m1th91 View Post
The 12v dash illumination wire will actually be to a power source such as ignition switch. this is a positive output relay because terminal 87 the output terminal is the red or power wire to the fogs and is powered from direct battery current. The reason the ground from the fogs goes to the terminal is because rather than the fogs be grounded individually, they are grounded via the relay. Yes this is a positive trigger setup.
Note: I bought this harness, i did not make it and how the switch is internally wired may not look exactly like this diagram i got off the internet and edited to my setup.
Yes I know what a positive trigger setup is, and for the last time, you won't be able to ground the white wire with that. Read my last 2 posts on how you can add a negative trigger via a second relay. That's why PatGT86's diagram is the way to go. No need for a second relay.
HRTROB is offline   Reply With Quote
Old 03-21-2013, 12:25 AM   #142
b$m1th91
b$m1th91's Avatar
Drives: 2013 Asphalt Scion FR-S
Yes, i understand and am not saying it can work. Just clarifying my setup. Unfortunately the harness would be to much work to rewire so i may do the second relay option. Thanks for your help
Current Mods- [Fog lights, Takeda CA Intake, LED swaps(Dome, Reverse, Trunk)..., Painted Calipers Red, Beatsonic Shark Fin Antenna] Future Mods- Takeda Exhaust, Perrin Crank Pulley, Reverse Fog light, Rota torque wheels, Custom Sound System:happy0180:
b$m1th91 is offline   Reply With Quote
Old 03-21-2013, 12:31 AM   #143
HRTROB
HRTROB's Avatar
Drives: Toyota 86
No problem! Let us know how how your install goes!
Old 03-21-2013, 07:15 AM   #144
bpracer
Drives: Asphalt FR-S
I've ordered the parts to do this, hopefully haven't messed up anything.
> BRZ WIPER STALK FOR PREMIUM MODEL - WITH FOG LIGHT SWITCH (shouldn't have the "Auto" spot in the switch)
> A pair of Ebay Outback Fog-lights
> Nigel-JDM wiring harness
> Pair of JDM Toyota light housings (uhg!, back-ordered)
The airbag removal makes me a little nervous, but shouldn't be as bad as dis-assembly of the rear hubs to install longer wheel studs!
Thanks for everyone's help in this thread.
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline   Reply With Quote
Old 03-21-2013, 07:58 AM   #145
pascalbrax
pascalbrax's Avatar
Drives: Toyota GT86
Originally Posted by Sco2355 View Post
Once it all works put it back together and you should be good. Also, if someone with a BRZ or JDM/Euro GT86 can confirm, do y'all's fogs only come on with the headlights or can you turn them on whenever and that indicator still comes on?
Not sure if I understood your question correctly. Anyway, this is the European lights stalk.
(Note there is no kph/mph button...)
This is the European dashboard.
And this is the dashboard with both front and rear fogs on (you can turn on rear fogs light only after front fogs are turned on).
pascalbrax is offline   Reply With Quote
Old 03-21-2013, 08:07 AM   #146
Sco2355
Sob! I need this in my life! Any chance you have the part number for that stalk?
Sco2355 is offline   Reply With Quote
Old 03-21-2013, 08:19 AM   #147
pascalbrax
pascalbrax's Avatar
Drives: Toyota GT86
I was going to link you this one:
http://www.nigel-jdmparts.com/japan-...ng-wheel-stalk
But I see it's missing the rear fog lights icon... Not sure if you have/need them in the US version.
Old 03-21-2013, 08:27 AM   #148
pascalbrax
pascalbrax's Avatar
Drives: Toyota GT86
I plan on hooking up the auto lights later when I do the other conversions (GT86 headlights, seat heaters, dual climate, etc). Just personal preference. The big thing we are finding out is Toyota and Subaru kept a lot of stuff there between the trim levels, just removed the extra bits and some of the wiring to them.
I may sound naïve and I apologize, but why didn't you just import an european 86?
Old 03-21-2013, 08:28 AM   #149
Sco2355
I'm retrofitting a lot of the Euro/JDM spec stuff. I never realized there was an additional button for the rear fog. If you could get me a part number that would be amazing!
Old 03-21-2013, 08:31 AM   #150
Sco2355
US is extremely strict on importing vehicles. Though we have the FRS it would have cost close to double the price of the car to get the model I want and get it imported and "legal". That's also why you see a lot of people saying "should have got the BRZ". At the end of the day, for me at least, it's cheaper to convert my FRS than it would have to buy a BRZ and convert it to an FRS.
Old 03-21-2013, 08:36 AM   #151
pascalbrax
pascalbrax's Avatar
Drives: Toyota GT86
Yep, here's explained how it works:
With the euro stalk, the front fogs have to be turned on for the rears to turn on since they use the same "collar". The collar is spring loaded (momentary contact switch) so with the front fogs turned on, you rotate the collar up to activate the rear fogs then the switch will return to the front fogs "on" position. Rotating the collar up again will switch the rear fog off. The low beams have to be turned on for the rear fogs to light up, while the front fogs can be turned on in parking light mode.
As you can see, there is some sort of logic in the body ecu controlling the activation of the fog lights.
It may sound confused, I can make a video if you want.
Anyway, I may guess that there's no rear fog lights in the JDM version. So, it's your choice which way you want to go. I don't have the euro part number, but you can try to ask in the regional/Europe section of this forum. I'm sorry I can't help you.
Old 03-21-2013, 08:43 AM   #152
Sco2355
It's all good! I'll find it!
Old 03-21-2013, 10:42 AM   #153
Chillz
Drives: Asphalt FR-S & S14
Have you confirmed that the BRZ premium stalk doesn't have the "auto" switch?
Chillz is offline   Reply With Quote
Old 03-21-2013, 10:56 AM   #154
HRTROB
HRTROB's Avatar
Drives: Toyota 86
If you do find it, kindly post the part number here thanks!
Who here has LEDs in their fogs/DRLs in their GT? RZ86 Cosmetic Modification (Interior/Exterior/Lighting) 10 03-30-2013 10:54 PM
Fogs wiring; Will this work? Khánh Cosmetic Modification (Interior/Exterior/Lighting) 12 02-16-2013 12:44 PM
BRZ HID Bulb + HID Fogs delusional DIY (Do-It-Yourself) Guides 4 02-05-2013 05:09 AM
new Camry fogs fit the frs?? hislargeness Cosmetic Modification (Interior/Exterior/Lighting) 3 09-26-2012 03:20 AM
for everyone thinking of using rear fogs xpicer Cosmetic Modification (Interior/Exterior/Lighting) 4 07-04-2012 12:53 AM
