go_a_way1
Old 05-23-2013, 10:36 AM   #1429
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by stancypants View Post
I am going for stance look so does anyone know if a 18x9.5+20 front and 18x10+15 has ever been tryed i know i will have to do a fender pull in the fornt and rear with some camber. can anyone suggest some tire sizes for me i was thinking like a 225/35 front and rear any suggestions ?
That's a pretty aggressive fitment. CHeck out this thread and see what others have done:
http://www.ft86club.com/forums/showthread.php?t=25171
Slick is offline   Reply With Quote
Old 05-23-2013, 11:02 AM   #1430
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
Probably need widebody
dori. is offline   Reply With Quote
Old 05-23-2013, 12:34 PM   #1431
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
You can get it done with lots of camber, Lower control arms, coilovers and skinny tires
215 or 225
Old 05-23-2013, 12:53 PM   #1432
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Originally Posted by Lee358 View Post
Wheel 17X8 +45 i know will fit tire that the guy has on 235/45/17 i would have to replace the tires right?
FWIW, I ran that tire size and it really made the car feel more sluggish. Granted, the wheels were bigger (17x9) and not light, but they were within a pound or so of stock anyway.
Might as well sell the tires to some WRX guy and pick up either 225/45 or 245/40 as suggested previously. I had really wanted 245/40 but after some spirited driving on 225s, I really don't think this car needs anything wider except for looks. Just get a good compound.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 05-23-2013, 01:49 PM   #1433
taimysho0
Drives: frs
Originally Posted by Slick View Post
Not sure I understand your question.
Your stock tires will fit on these wheels, with a bit of stretch.
If you are buying wheels and they already have 235/45R17, (I think is what you're asking) they will fit although they are taller, and it will alter your gearing by 2.8% (you will be travelling 2.8% faster than your indicated speed). But it will affect your acceleration more because of the gearing, which is not a good thing (unless you don't care about it). But they will fit and not rub.
Better tire size would be 245/40R17 which is almost exactly same as stock.
thanks for the info! i might go that route, however i thought 245 will stick out of the fender well too much in the front on stock height? i noticed my rears have a little bit more space to fit a wider tire so thats why i went with the 245 in the rears. also, whats the reason people go lower profile in the rears by 5mm than in the front and not the same profile for front and rears? thanks!
taimysho0 is offline   Reply With Quote
Old 05-23-2013, 01:50 PM   #1434
taimysho0
Drives: frs
^sorry, quoted the wrong response, meant to quote your response to my post
Old 05-23-2013, 06:33 PM   #1435
stancypants
stancypants's Avatar
Drives: FR-s
215 or 225
i know the fronts can be done no prob but i am wondering about the rear how much camber do you think i would need i dont want to go over neg 4 and i plan on lower control arms
stancypants is offline   Reply With Quote
Old 05-23-2013, 11:38 PM   #1436
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
Thanks guys im looking at a set of rpf1s 17x8 +45 that are already mounted and balanced with those tires but i will buy the wheels without the tires and buy new ones.
Lee358 is offline   Reply With Quote
Old 05-29-2013, 04:54 PM   #1437
kidgogeta
Drives: FRS
will this fit 18.0 x 9.5 +40 gramlights 57 extreme all around with 255 Z2's on swift springs?
kidgogeta is offline   Reply With Quote
Old 05-29-2013, 07:43 PM   #1438
yetiFR-S
Drives: 2013 SCION FRS
hey guys. i just dropped my car around 1.25 all around. i bought 18x8 +35 wheels . i was thinking about a 235/40/18 tires. will this fit. i am not into that slimjim tire look and would rather get performance the looks so i dont want my wall to be to thin. should i go for a 45 wall or should that be fine. open to all suggestions . ty
yetiFR-S is offline   Reply With Quote
Old 05-30-2013, 01:38 PM   #1439
Rabble
Drives: Asphalt FR-S
Any issues with putting 225s on a 17x7 wheel? I know it'll fit but is there a risk of the sidewall buckling under autocross and hugh speed turns?
Sideways is a normal operating condition.
Rabble is offline   Reply With Quote
Old 05-30-2013, 02:43 PM   #1440
Slick
Slick's Avatar
No issues at all, 225s are perfectly well suited to a 17x7.
Old 05-30-2013, 02:49 PM   #1441
sybrite
Drives: 2013 Subaru BRZ
I've been reading many of the threads on wheels, to include the stickies and have gotten decently spun up on it. I must say, I'm not all that tech savvy when it comes to cars, but I just want to ask before I place my order. I believe the XXR 527 in matte bronze would look awesome on my lightning red BRZ.
Ideally I was going to do the 18X8.75 [+35], but they are always out of stock. I was wondering if I will have any issues, or if anyone else has used the +20 offset and would it cause me issues? I haven't lowered the car yet, but will do so in the future. Thanks for the help.
http://www.nlmotoring.com/XXR-527-Wh.../52788547n.htm
And any thoughts on these tires?
http://www.tirerack.com/tires/tires....omCompare1=yes
sybrite is offline   Reply With Quote
Old 05-30-2013, 03:10 PM   #1442
2point0
2point0's Avatar
That's going to poke a bit, especially in front. Might look OK with a good amount of negative camber, though. May rub after lowering, but I couldn't say from experience. My last set was 9" wide +28 so that means yours will have 2.65mm less poke. Mine did not rub at all, but I wasn't lowered. I just was not happy with the look, or the heavy wheels.
I haven't used those tires, but mine were 235 Federals, and those are more like a 245.
I would stick with the +35, personally. Not sure how close you'd be to the front spring perch, though.
The Following User Says Thank You to 2point0 For This Useful Post:
sybrite (05-31-2013)
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
