#127 | |
PhoneFlash by EcuTeK
As for the IAT sensor, we can rescale if you like, that would not be an issue. Just let me know the scaling for it and we can adjust the tune for it. Cheers, William Knose Delicious Tuning |
#128 | |
Drives: 13 FRS
We got the idle issue on Aarons car sorted this weekend Enjoy ![]() [ame]http://youtu.be/OKKUbWKX7n4[/ame] |
#129 |
USMC
Drives: 2013 FR-S 6-MT Raven
It literally feels like I'm driving a whole different car! And I LOVE it! Just can't wait for that e85 and dyno! Also the idle code doesn't come up anymore. Thanks JDL you guys are awesome!
#130 |
Senior Addict
Drives: 86 GT
Can you give us more details what was done/changed? Was it just an update to the latest version 13.63 tune? Or were there further updates to it?
#131 |
USMC
@JDLAutoDesign care to chime in?
#132 |
Drives: 13 FRS
The idle issue was due to a vacuum/boost leak. The hose for the purge valve under the intake manifold was not connected or securely clamped. Its a common problem once you add boost to these cars. That valve wasnt intended to see boost. With its intent to only see vacuum the factory didn't clamp it.
#133 |
Drives: red frs
I wonder if my clamp isn't holding? I will check it tonight.
#134 | |
JDL was kind enough to let us know the "P" code for this exact problem. The code is P0441 - Evaporative Emission Control System Incorrect Purge Flow. Cheers, William Knose Delicious Tuning |
#135 |
Drives: red frs
I don't have any codes....
#136 |
Drives: GT86
I have problem with cold start . Log file is send via e-mail .
#137 |
crew chief
Drives: Race car FR-S
I have no clue how the ecutek works but is there a map for throttle control? For example, if i want to start closing the throttle in the higher rpm to reduce power, is there a way to do that?
If so, is that map locked with your tune? |
#138 |
Drives: GT86
map is blocked to protect intellectual property
#139 |
Just a quick update.
We are working on a cold start (20 and below) update for the Flash & Go tunes. Should have something out later next week for the mean time that should get things rolling in the correct direction. Cheers, William Knose Delicious Tuning |
#140 |
Drives: 2013 FRS Whiteout
PMs?
| P&L Oil Cooler for Forced Induction Applications!! Compatible with FMICs!!! | P&L Motorsports | Forced Induction | 9 | 03-26-2017 01:27 PM |
| Most *fun* forced induction | bfrank1972 | Forced Induction | 45 | 12-22-2016 11:36 AM |
| Infamous Performance is now offering dyno tunes by Delicious Tuning!!! | Infamous Performance | Announcements, Contests, Giveaways | 115 | 02-28-2014 12:38 PM |
| February Sale. All Delicious Tuning e-tunes are 10% off!!! | Infamous Performance | Announcements, Contests, Giveaways | 19 | 02-28-2014 12:37 PM |
| Infamous Performance is now offering dyno tunes by Delicious Tuning!!! | Infamous Performance | Forced Induction | 107 | 02-13-2014 11:36 AM |
