Old 12-11-2014, 11:51 AM   #1
P&L Motorsports
P&L Motorsports's Avatar
Drives: '13 Turbo BRZ (AT) & '13 FRS
P&L Oil Cooler for Forced Induction Applications!! Compatible with FMICs!!!
The P&L Motorsports Engine Oil Cooler for 2013+ BRZ/FRS is designed for those who want to decrease their heightened engine oil temps that are common on forced induction and/or motorsports applications. Sized appropriately for stock vehicles all the way up to vehicles with large turbo upgrades, this engine oil cooler kit is the solution for hot engine temperatures.
Allowing for an easy installation, this engine oil cooler system is a complete bolt-on kit. We’ve even provided for compatibility with the factory optional foglights and turn indicators. This kit has been designed from the ground up to provide the best solution for vehicles with front mount intercoolers and is compatible with the P&L Motorsports turbo kit and most aftermarket turbo kits.
Included optionally is a motorsports quality fan and wiring harness for vehicles that have foglights, or those that do not want to cut holes in their bumper to provide air flow for the heat exchanger. Our kit has been specially designed with a mounting location of the heat exchanger away from the front mount intercooler on turbocharged applications. Other kits on the market place the extremely hot oil cooler directly in front of the turbo kit’s front mount air intercooler. This placement is entirely counter productive to cooling the air change and should be avoided at all costs!
This engine oil cooler kit can be paired with our P&L Motorsports 2013+ BRZ/FRS Turbo Kit as well as many other kits on the market that utilize front mount intercoolers.
Features:
  • Setrab Heat Exchanger (13 x 5 x 2 inch)
  • -10 AN Stainless Steel Braided Oil Lines and Fittings
  • DEI Heat Sleeve for Oil Lines
  • Oil Filter Sandwich Adapter for Oil Supply
  • Plug and Play Motorsports Quality Wiring Harness (Optional)
  • 300 CFM Motorsports Quality Pull-Through Fan (Optional)
  • Automatic Fan Operation at Oil Temps of 190 Degrees F (Optional)
  • Fan Master On/Off Switch Capable (Available for Special Order)
  • CNC Plasma Cut Mounting Brackets
  • Compatible with Most Aftermarket Turbo Kits and Front Mount Intercoolers
  • Compatible with Factory Fog Lights and Turn Indicators
Includes:
  • -10 AN Fittings
  • DEI Heat Sleeve
  • 300 CFM Fan (Optional)
  • Plug and Play Wiring Harness (Optional)
  • Mounting Brackets
  • All Necessary Hardware for Installation
Applications:
  • 2013+ Subaru BRZ
  • 2013+ Scion FRS
  • 2013+ Toyota GT86 and other RHD Non-USDM Models
https://pandlmotorsports.com/shop/pl...r-2013-brzfrs/
P&L Motorsports is offline   Reply With Quote
Old 12-11-2014, 12:07 PM   #2
Where does the hot air vent "to"?
Old 12-11-2014, 01:01 PM   #3
P&L Motorsports
Mike there is a pretty big opening to outside air directly behind the heat exchanger where the tow hook is. For added ventilation, we would suggest louvering the fender liner.
-Ty
Old 12-11-2014, 01:14 PM   #4
BRZGM3
BRZGM3's Avatar
Drives: CBS brz limited
How many rows is this heat exchanger?
BRZGM3 is offline   Reply With Quote
Old 12-11-2014, 03:01 PM   #5
xwd
The installed picture shows a 15-row one, the last picture by itself shows a 17 row one. So good question.
Old 12-11-2014, 03:21 PM   #6
BRZGM3
BRZGM3's Avatar
There might a few options? Id like bigger than a 15
Old 12-11-2014, 05:26 PM   #7
P&L Motorsports
Wow, I didn't think anyone would notice that!
We are using the (13x5x2) 16 row coolers from Setrab for this kit. I only had a 19 row at the time to take photos with though. I suppose I could technically offer the 19 row as an optional upgrade.
-Ty
Old 12-11-2014, 05:56 PM   #8
BRZGM3
BRZGM3's Avatar
Honestly id like the biggest possible lol. So yes that'd be a good idea
Old 01-13-2015, 08:20 PM   #9
BRZGM3
BRZGM3's Avatar
Any updates?
Old 03-26-2017, 01:27 PM   #10
choi0706
Drives: t
update on larger oil cooler?
choi0706 is offline   Reply With Quote
Delicious Flash & GO Tunes for ALL FORCED INDUCTION Applications - Q&A DeliciousTuning Forced Induction 748 06-18-2025 09:42 PM
Jackson Racing engine oil cooler for NA applications CSG Mike Engine, Exhaust, Transmission 107 12-01-2021 04:03 PM
going forced induction ft86me Forced Induction 14 02-05-2014 08:23 AM
Oil Cooler kit for FI applications, getting one? JoeBoxer Forced Induction 84 01-20-2013 09:48 AM
6AT (+) Forced Induction RYU Forced Induction 18 09-09-2012 11:14 PM
