Old 11-14-2014, 11:12 PM   #127
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by Efferalgan View Post
Hm... Good question. I'm not sure but I guess it rather should be called a custom tune as I ordered it before the FnG was introduced. It's the first version I received together with the EcuTek box from Delicious, so technically it is FnG - I just glashed amd the car goes Sent logs to Delicious yesterday. Hope to get the revised version soon.
Yours was an earlier beta version of Flash & Go, which was not released. You did not have all the features at that time. We now have added a lot more since then and working on dialing in a more general tune for all configurations.
As for the IAT sensor, we can rescale if you like, that would not be an issue. Just let me know the scaling for it and we can adjust the tune for it.
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Efferalgan (11-15-2014)
Old 11-17-2014, 01:27 PM   #128
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Originally Posted by DeliciousTuning View Post
As for the idle, here is what is going on here and I know there is a concern about it, but it is not something to be concerned about. I say that and I am sure you still are but here is the reason.
Currently the hardest part about dialing in this Speed Density tune is the idle, it is literally the hardest aspect to tune in this vehicle especially on turbo applications, auto or manual. What we have done is forced the idle to hang a bit in order to keep the engine from stalling which I know most people prefer if you had to pick one.
Though the rev hang ideal on some turbo applications we have seen this happen and we are working on resolving this in the tune. We are actually speaking to EcuTeK a bit about it, since we have found it has to do with vehicle running blow off valves and maf sensors in the charge pipes. Even though the MAF (being pure SD) should not be affected be have found it still has a small amount of control on the engine for some reason and we are working on seeing if there is something in the custom coding that might be causing the issue or if we can diagnose exactly where in the tune the problem arise from.
On supercharged vehicles this is not a problem, as there is enough steady load on the engine and usually no blow off valves to cause leaks at idle which we are find cause a little of the idle issue also.
Anyway we are working on it.
I would like to also thank everyone for their patience as we been working on catching up, it has just been overwhelming after SEMA, baby 6 weeks ago and Super Lap Battle tomorrow. LOL.
Cheers,
William Knose
We got the idle issue on Aarons car sorted this weekend
Enjoy
[ame]http://youtu.be/OKKUbWKX7n4[/ame]
JDLAutoDesign is offline   Reply With Quote
The Following 2 Users Say Thank You to JDLAutoDesign For This Useful Post:
DeliciousTuning (11-18-2014), texasbound972 (11-17-2014)
Old 11-17-2014, 01:29 PM   #129
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
It literally feels like I'm driving a whole different car! And I LOVE it! Just can't wait for that e85 and dyno! Also the idle code doesn't come up anymore. Thanks JDL you guys are awesome!
texasbound972 is offline   Reply With Quote
Old 11-17-2014, 08:17 PM   #130
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Can you give us more details what was done/changed? Was it just an update to the latest version 13.63 tune? Or were there further updates to it?
Fizz is offline   Reply With Quote
The Following User Says Thank You to Fizz For This Useful Post:
Shit Luck (11-18-2014)
Old 11-17-2014, 11:02 PM   #131
texasbound972
USMC
@JDLAutoDesign care to chime in?
Old 11-18-2014, 11:28 AM   #132
JDLAutoDesign
Drives: 13 FRS
The idle issue was due to a vacuum/boost leak. The hose for the purge valve under the intake manifold was not connected or securely clamped. Its a common problem once you add boost to these cars. That valve wasnt intended to see boost. With its intent to only see vacuum the factory didn't clamp it.
DeliciousTuning (11-18-2014), texasbound972 (11-18-2014)
Old 11-18-2014, 11:32 AM   #133
Shit Luck
Drives: red frs
I wonder if my clamp isn't holding? I will check it tonight.
Shit Luck is offline   Reply With Quote
Old 11-18-2014, 12:05 PM   #134
DeliciousTuning
We have seen these hoses pop off on many forced inductions applications and it will cause the idle issue and power loss people are experiencing.
JDL was kind enough to let us know the "P" code for this exact problem. The code is P0441 - Evaporative Emission Control System Incorrect Purge Flow.
Cheers,
William Knose
Old 11-19-2014, 08:03 AM   #135
Shit Luck
Drives: red frs
I don't have any codes....
Old 11-21-2014, 05:42 AM   #136
aero.kit
Drives: GT86
I have problem with cold start . Log file is send via e-mail .
aero.kit is offline   Reply With Quote
Old 11-21-2014, 08:49 AM   #137
puma
crew chief
puma's Avatar
Drives: Race car FR-S
I have no clue how the ecutek works but is there a map for throttle control? For example, if i want to start closing the throttle in the higher rpm to reduce power, is there a way to do that?
If so, is that map locked with your tune?
puma is offline   Reply With Quote
Old 11-21-2014, 09:55 AM   #138
aero.kit
Drives: GT86
map is blocked to protect intellectual property
Old 11-26-2014, 12:13 PM   #139
DeliciousTuning
Just a quick update.
We are working on a cold start (20 and below) update for the Flash & Go tunes. Should have something out later next week for the mean time that should get things rolling in the correct direction.
Cheers,
William Knose
Old 11-26-2014, 12:14 PM   #140
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Cheers,
William Knose
PMs?
yomny is offline   Reply With Quote
P&L Oil Cooler for Forced Induction Applications!! Compatible with FMICs!!! P&L Motorsports Forced Induction 9 03-26-2017 01:27 PM
Most *fun* forced induction bfrank1972 Forced Induction 45 12-22-2016 11:36 AM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Announcements, Contests, Giveaways 115 02-28-2014 12:38 PM
February Sale. All Delicious Tuning e-tunes are 10% off!!! Infamous Performance Announcements, Contests, Giveaways 19 02-28-2014 12:37 PM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Forced Induction 107 02-13-2014 11:36 AM
