Old 07-17-2014, 10:32 AM   #127
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
Originally Posted by Shiv@Openflash View Post
The big step from 1.X to 2.0 is justified by the all new maps being based on the newest B01C ROM, instead of the older A01C ROM.
I was about to upload 2.0 to the tablet and flash it... and then realized that there are both A01C and B01C files in the 2.0 Beta zip file off the OFT website.
My car's ROM is based on A01C (at least that's what I've been using on the older flashes). Which 2.0 Beta file should I use for the flash? The A01C or the B01C?
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Old 07-17-2014, 10:34 AM   #128
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Use the same A01C you have always used. All of the v2.0 roms have B01C "guts" inside of them.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
robwbright (07-17-2014)
Old 07-17-2014, 10:36 AM   #129
robwbright
Gotcha. Thanks!
2006 Saab 9-3 2.0t
Old 07-17-2014, 10:42 AM   #130
Robftss
Drives: VW
Hi guys,
Spent several hours on the dyno this evening putting together a nice safe and drivable E85 map for the ESC 1.5+OFH. Worked out quite well. Test car only has Phantom ESC, OpenFlash Header and, of course, OpenFlash Tablet. Stock airbox, stock filter, stock front pipe, stock exhaust.
[/URL]
I'm happy with the nice flat torque curve as well as a lack of power roll-off up top. Makes for a very quick and responsive car. Still quite conservative and safe with AFR hitting mid to high 11s by peak hp (~7000rpm). Running leaner will give another few hp but it will sacrifice some safety margin that is necessary to have due to variances in cars, fuel, conditions.
I'll drive our car around a bit more for testing purposes. Then I'll the tune out to those who want to test
Cheers,
Shiv[/QUOTE]
Thanks Shiv!.... No Unicorns
Robftss is offline   Reply With Quote
The Following 5 Users Say Thank You to Robftss For This Useful Post:
DAEMANO (07-17-2014), enwave (07-17-2014), raven1231 (07-17-2014), Sojhinn (07-17-2014), WRB5titch (07-17-2014)
Old 07-17-2014, 11:37 AM   #131
WRB5titch
Drives: WRBrz
This ! I have been only been putting in a couple gallons of 93 each fill up anticipating this
Likewise!! cept we only get 91 here
EBSC - dt.FF - MXP CompRS
WRB5titch is offline   Reply With Quote
The Following User Says Thank You to WRB5titch For This Useful Post:
Old 07-17-2014, 12:25 PM   #132
raven1231
Originally Posted by Robftss View Post
Hi guys,
[/URL]
Cheers,
Shiv
Thanks Shiv!.... No Unicorns [/QUOTE]
but I like unicorns They're magical and stuff
Old 07-17-2014, 12:26 PM   #133
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta]
Shiv! You're the man! Can't wait to try this out
Should I look into a custom tune from you for the ESC 1.5dump E85 with OFH? Or will there be an OTS that includes minor tuning changes for the OFH?
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
Old 07-17-2014, 01:33 PM   #134
robwbright
New log with the BETA 2.0 map:
http://datazap.me/u/robwbright/07171...og=0&data=1-12
3rd Gear pull:
Boost @ rpm:
4.65 @ 3381
4.5 @ 3658
4.21 @ 3964
4.07 @ 4362
3.63 @ 5228
3.05 @ 6116
2.18 @ 6862
2.03 @ 7131
1.6 @ 7319
1.02 @ 7469
I compared to one of the pulls from the log 3 days ago using the most recent 1.x version. There's a bit more boost on the BETA map.
2006 Saab 9-3 2.0t
The Following User Says Thank You to robwbright For This Useful Post:
Old 07-17-2014, 01:38 PM   #135
raven1231
The E85 tune has the OFH incorporated
enwave (07-17-2014)
Old 07-17-2014, 01:56 PM   #136
bfrank1972
Drives: 2013 FR-S Argento
3rd Gear pull:
Boost @ rpm:
4.65 @ 3381
4.5 @ 3658
4.21 @ 3964
4.07 @ 4362
3.63 @ 5228
3.05 @ 6116
2.18 @ 6862
2.03 @ 7131
1.6 @ 7319
1.02 @ 7469
Wow great boost numbers, can somebody explain to me how a tune changes what boost this system produces? I'm just wondering if these variances are differences based on other factors (battery performance, temperature, etc). Or perhaps if the tune does affect measured boost, could it be actually due to changes in restriction downstream from where boost is measured (ie changes in vvt)?
bfrank1972 is offline   Reply With Quote
Old 07-17-2014, 02:21 PM   #137
enwave
enwave's Avatar
I have to admit, I skimmed and read the bold part, which included "stock exhaust" -- rereading clearly states OFH was in the tune.
Should probably tone my excitement down and pay attention
The Following User Says Thank You to enwave For This Useful Post:
Old 07-17-2014, 02:32 PM   #138
raven1231
Trust me I understand completely
Old 07-18-2014, 05:26 AM   #139
raven1231
I was just thinking today while driving to work how epic the e85 tune will be
I think after this it will finally be time for me to start my cosmetic mods. That way she looks as good as she runs!!!
Old 07-18-2014, 07:53 AM   #140
shif7i7down
Erected Member
Drives: frs
It is 6:52am Friday morning right now.. couldn't sleep, was thinking about the e85 tune too much.....hope today is the big day that shiv releases it.
shif7i7down is offline   Reply With Quote
The Following 2 Users Say Thank You to shif7i7down For This Useful Post:
neutron256 (07-18-2014), raven1231 (07-18-2014)
Phantom TQ250 Dyno FBO (Dual Battery Pack) Shiv@Openflash Forced Induction 23 04-29-2014 01:40 AM
Clutch dump at 5000 RPM? fasteddy BRZ First-Gen (2012+) — General Topics 20 08-22-2013 12:55 PM
External dump and under tray? mrk1 Forced Induction 5 07-30-2013 08:43 AM
Photo dump. CanibeatNoel FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 07-17-2013 01:47 AM
Ricepuddin Picture Dump Ricepuddin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 15 12-02-2012 11:18 PM
